#57 |
Drives: 2014 Raven FR-S 6spd
#58 | |
DrivinginDreams...Cloud86
Drives: Toyota GT86
#59 | |
The Perrin filter for instance is great at filtering out nearly all contaminants whilst providing increased airflow and a nicer sound. |
#60 | |
Drives: 2005 Toyota Camry
- fuel "chirp": don't bother with fixing it. It's not a mechanical problem and won't affect your car in any way, and the fix isn't a fix. - the rest of the issues: have them run a VIN and apply any TSBs that are outstanding As for individual problems, it's simple: just tell them you have these issues, that you are aware of current fixes. If the dealer doesn't want to service them, tell them you will take your labor work somewhere else. That's all that needs to be said. None of this "worst dealer ever" stuff. We're not driving Ferraris, we're not limited to one dealer in an area. -alex |
#61 |
Drives: "13 FT86 GT Tornado Grey 6MT
F'n Ethanol
Sucks that you guys in So. Cal. can't get proper fuel for your cars.Damn Ethanol, They tried to mandate it in one state here in Australia but only on regular unleaded so you can still get the High Octane 98 that hasn't been jumped on by some politician or farmers co-op. Some say Ethanol is OK to use in modern vehicles. Usually they are people who don't care about YOUR car. I prefer to run on Fuel the car was designed to run on. Sorry , back to discussion. |
#62 | |
Ethanol has been in American fuel for nearly 10 years now and auto manufacturers were made aware of the switch, it didn't happen overnight. This car was designed to use fuel containing up to 10% ethanol, and I'd be surprised if it was any different between regions aside from ECU tuning. |
#63 |
Don't really know how they've spun it to you guys in the States.
We've had this gear in our fuel for probably longer than 10 years as well. Coming from an Engineering background, the way I understand it is Ethanol is an Alternative fuel. Petrol engines are generally designed to run on petrol and then modified and tuned to allow this Alternative fuel to be used. (eg. "E10 can be used in this vehicle.) Some engines are designed to run on Ethanol and wear a badge that might say "E85". (up to 85 % Ethanol)* Not our cars* There's no mechanical reason to introduce Ethanol to Petrol as you get less Economy when using an Ethanol blend compared to straight Petrol so it is not as efficient. It's not for environmental reasons because if you use more fuel due to inefficiency how is that helping the Planet. I think the reason we have ethanol is purely financial. Helps prop up the farming sector by making unwanted crops into alternative fuel. Too bad they can't turn those unwanted crops into real food and feed some people but you'll never make Billions doing that will ya. Petrol in a Petrol Engine..Seems pretty straight forward to me, but I'm old and simple. Will probably be better when all us old buggers drop off and you kids can run your cars on mung bean juice or Possum tears or whatever. Cheers. |
#64 |
Drives: 2013 Firestorm
Go- it helps pollution and that's why most major cities don't have no ethanol gas. The engine hate ethanol. That is why the car runs better on non ethanol than ethanol. And yes the crickets have to do with ethanol in the as.
#65 | |
2 wheel member
Drives: JZA80, 997.1, Taco
#66 | |
........yep, maybe then they will go back to the old multi-fuel engines used in 5 ton trucks in the Army back in the 60's..... hell, they would run on anything that was liquid and would burn .... ![]() humfrz |
#67 |
Drives: FR-S 6MT
That's what marketing would like you to believe.. It's BS.
| The Following User Says Thank You to Mikem53 For This Useful Post: | Chad86 (11-23-2013) |
#68 |
Drives: Toyota GT86
#69 |
Drives: Scion FR-S Coupe
There is this additive that can be used along with your gas to rid it of the Ethanol; I use it in my Aircooled HP VW engines in the Fall and winter.
Star brite Star Tron Enzyme Fuel Treatment Gas Additive Hope it helps you also |
#70 | |
Drives: Whiteout FR-S
the only time my car idles above 600 is when it's still warming up or if the fans are on and it jumps to about 1k rmp for a few seconds and falls back to 600 intermittently; which most likely to avoid stalling out from the excess power consumed to blow the air |
| 2 weeks from getting a brz | tr1x5tuh | Southern California | 16 | 10-31-2013 10:27 PM |
| Not even three weeks | gr8scott | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 05-21-2013 11:01 AM |
| Another 8 weeks!! | Wesley | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 09-21-2012 07:25 PM |
| had my frs for two weeks..this is what happens | bcmakesiteasy | Scion FR-S / Toyota 86 GT86 General Forum | 98 | 08-07-2012 11:20 AM |
