#57 |
Drives: FRS
| The Following User Says Thank You to RFB For This Useful Post: | 2016 Camaro SS (05-27-2015) |
#58 | |
Drives: Currently 2018 Taco
Flashpoint comfortably above threshhold. No oxidative thickening!! (This is the key point) The great Sustina is hanging tough. Low zinc. Signature higher phosphorus albeit still SN. Assist to boron & moly. Highly refined group 3 base stock. Sustina is da kine. I'll say it again and again. 1. Sustina 0W20. 2. Pennzoil Platinum w/PurePlus 0W20. 3. Mobil 1 Yellow Cap 0W20. 4. All other motor oils. (personal favorites) Really appreciate your work mav !!!!!! |
| The Following User Says Thank You to viscositosis.rex For This Useful Post: | mav1178 (06-08-2015) |
#59 |
#60 |
Hi bluesubie!
Not sure I am following you as to what is in dispute. It is generally accepted that Sustina falls under the Group III category. Certainly it is not merely dino (Group II), PAO (Group IV) or ester based (Group V). Sustina spokespeople and the Eneos website have explained that there is only one way they can achieve such a high viscosity index and also an SN rating. They must extensively refine the base oil to obtain efficient, uniform molecule size and shape. Then they must use a judicious amount of special viscosity index improvers. But you already knew all this. ?? |
#61 | |
From a marketing standpoint, they called the 5W30 "Synthetic" when it was predominately Group III and relabeled it as "Fully Synthetic" when they reformulated it to Group IV/V. |
#62 |
Drives: FRS
Our group has been using Sustina 0-50 for the track, and street, for several years INSTEAD of 0-20, because of the high temps in our boxer motors when pushed.
We use the thinner 0-20 in winter.
#63 |
Drives: 2013 FR-S Whiteout MT
So would You recommend a 5w-30 sustina for southern california? What conditions would a 5w-30 be suitable for?
When in doubt, throttle out!
#64 |
Drives: FRS
#65 | ||
Drives: 2005 Toyota Camry
Any range that meets the factory requirements will be fine. Heavier weight is just a hit on gas mileage. Quote:
-alex |
#66 | |
Drives: FRS
Sorry, don't know about your driving habits, but if you have a twin I'm sure you drive aggressively at some point. We track regularly, and follow our Nippon brothers example re. Eneos. Gas mileage is not a concern on the track, but I noticed no gas mileage difference when I learned about the 50 w. and started using it Your report is overdue on this forum since your report will show some of the benefits of Sustina over oil without Eneos additives and others can benefit. Although more expensive, we found the heavier Sustina 50 is the oil for our twins in summer.
#67 | |
As for my comment about you ignoring what I've posted... again: what is it about thicker oil that is better than thinner oil? Oil weight should be dictated by temperature needs (ambient) or pressure needs (PSI under track conditions). To suggest 0W-50 just because "the FA20 runs hot" doesn't tell me anything about why you need 0W-50 in the first place. -alex |
#68 | |
I am especially interested in the behavior of Group III, GTL, PAO, and ester oils in GDI engines. Maybe bluesubie can ask Tom in NJ or MolaKule to elaborate. I've never received much feedback from Eneos North America. Hell, I should be their poster boy for durability. And mav for such stellar robustness. All in the super lightest of motor oils. Last edited by viscositosis.rex; 06-10-2015 at 01:10 PM. |
#69 | |
Drives: FRS
I think you answered your own question already - " what is it about thicker oil that is better than thinner oil? Oil weight should be dictated by temperature needs (ambient) or pressure needs (PSI under track conditions)."
#70 |
Sarcastic SOB
Sorry if Im jumping in at the wrong time, but the literature with the HKS GT supercharger recommends a minimum of 0W42 HKS oil. So, I use PAO based M1 0W40
| Bore of FR-S rims versus TC1? | stocktc1 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 08-05-2015 12:28 PM |
| Selling FR-S FireStorm Auto. 4K miles. paid 27.5K with factory options. | kk2hgo | Cars for Sale/Trade | 1 | 12-21-2012 05:55 PM |
| BRZ versus FRS: which is a firmer ride | PeterB | FR-S / BRZ vs.... | 22 | 12-19-2012 04:07 AM |
| FR-S versus Chevy truck :( | Cjm005 | Scion FR-S / Toyota 86 GT86 General Forum | 29 | 12-10-2012 01:35 AM |
| Size Comparison: FR-S versus tC and GT-R | CSSM | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 58 | 03-05-2012 11:28 PM |
