Old 10-02-2013, 06:40 PM   #57
gmsii
gmsii's Avatar
Originally Posted by Sonolin View Post
Yea I also noticed looking at the compressor map this would be at the very start of the efficiency range (which is quite large). I'm new to this stuff but that's what it looked like to me at least.
And that's all without overspinning the blower which you'll need to do to get the most out of the Vortech.
The main thing I'm concerned with is heat... I've heard mixed opinions on heat with a rotrex unit but I'm hoping its manageable and it looks like they are track testing it so that's good news...
Heat is absolutely not an issue with the Rotrex...from our observations, the operating oil temp of the rotrex is usually between 140-170
The person who we worked with to develop the ecu tune for this kit also developed the tunes for two other kits on the market. He noted our intake air temps were the lowest he had seen by far.
gmsii is offline   Reply With Quote
Old 10-02-2013, 07:52 PM   #58
Calum
That Guy
Drives: 2013 asphalt FRS MT
Who was it?
Old 10-02-2013, 08:00 PM   #59
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
C30-94 made 292 rwhp on CA 91-octane in my 1.8L 1zz MR-S (which makes about 125 whp stock)
uspspro is offline   Reply With Quote
Old 10-02-2013, 08:06 PM   #60
OrbitalEllipses
Drives: Attitude
Originally Posted by Calum View Post
Who was it?
I suppose you wanna know who shot JFK too...
Old 10-02-2013, 08:38 PM   #61
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Wow, that's quite the gain!
PRO86 | STL | LuckyDog
Old 10-02-2013, 08:54 PM   #62
Sonolin
Is that being driven hard at the track? That's one of my main applications for this. I really like the supercharger I just want to run 300-340whp on the track hard without too much heat issues. I know the Vortech can get there but from what I heard even with upgraded oil cooler + radiator there is still heat issues. I would think a rotrex would generate more heat than the Vortech unit no? I would think all the extra friction inside a Rotrex unit would make heat moreso of a problem.
I can't wait for this to be released and 3rd party reviews start popping up though. I'm really interested in this S/C system (or the Jackson Racing supercharge system which uses the same blower from what I understand).
Sonolin is offline   Reply With Quote
Old 10-02-2013, 11:18 PM   #63
Dezoris
Dezoris's Avatar
So this unit needs an external oil reservoir and also requires coolant lines? Certainly has good things going for it. How much testing was done on track, which tracks and can you show logs from your testing
to prove IATs, oil temps and coolant temps?
Old 10-02-2013, 11:47 PM   #64
Raven604
classic Dezoris post...
Raven604 is offline   Reply With Quote
Old 10-03-2013, 12:19 AM   #65
uspspro
The Rotrex has a self contained oiling system. Meaning it circulates it's own fluid. The supercharger has an inlet and oulet port. They come with a small aluminum reservoir with heat sink fins that you can place anywhere in the engine bay. Most installs will have a cooler inline (similar to a trans cooler), but on low boost applications, the reservoir may provide enough cooling.
Old 10-03-2013, 12:30 AM   #66
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
way better pics, from: http://cms.kraftwerksusa.com/id/950/...harger-System/
Old 10-03-2013, 01:34 AM   #67
gmsii
gmsii's Avatar
the rotrex has its own self contained oiling and cooling system...ideal operating temp is approximately 180, but can go up to 210 i believe....if oil temps get too high during track use, the rotrex oil cooler can simply be upgraded to a larger unit to bring those temps down.
as for track use durability, it should be noted that sport car motion record holding time FF time attack cars use rotrex without sc overheating problems...also hondata record holding landpspeed car does not have overheating problems...you can also see plenty off other cars and race cars that use rotrex chargers on the kraftwerks website or facebook page
Old 10-03-2013, 06:10 AM   #68
Calum
That Guy
meh, I'm more interested in knowing it wasn't JV that tuned this kit.
Old 10-03-2013, 10:28 AM   #69
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Max power for the included compressor, the c30-94, is 435 hp. Considering that's probably crank hp so taking away 20% for drive line losses that's 348 whp max with this compressor. Finally, someone picks a compressor that isn't too small out of the box.
Keep up the good work.
I could swear I saw skatery with a 360whp e85 pull at elevation. Pretty sure that was with a vortech...
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 10-03-2013, 10:29 AM   #70
Adeets
OEDC
Adeets's Avatar
So what's this chargers max psi out on stock charger?
My BRZ FI Build
[TX] DFW General Discussion feedbag Southwest 1488 06-18-2022 07:25 PM
HKS GT Supercharger (Rotrex) in development! madfast Engine, Exhaust, Transmission 206 12-14-2012 03:28 PM
ROTREX SC Brainstorming MANDALAY Forced Induction 61 12-11-2012 05:57 PM
Rotrex kit - why no build? MindtheGap Engine, Exhaust, Transmission 5 10-26-2012 07:01 PM
