Old 10-25-2014, 04:12 PM   #57
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by Reaper View Post
Castrol is old school tech with new marketing. Motul or amsoil still rains supreme. If youre not tracking or on e85 you can bump you oci up drastically with either. As long asbits not their race oil. Nothing wrong with Toyota oil either.
Do you think it's a bad to still be running the 0w20 synthetic oil by Toyota in an frs pushing 257whp.
Astroboy is offline   Reply With Quote
Old 10-25-2014, 04:27 PM   #58
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by Manji View Post
We have tried several different grades of oil. All Motul.
H Tech 0w20
H Tech 5w30
300v 0w20
300v 5w30
After analysing all, we now run 300v 5w30 in both NA and turbo applications.
Our results mimick Toyota Racing NZ, who run 5w30 in the TR86 race cars.
Stick with 0w20 if your car is mostly a street vehicle, and is NA. It will provide marginally better fuel economy. Which is essentially why it is the factory fill weight.
Whar if my car is mostly street used but also turbochargerd?
Old 10-25-2014, 04:32 PM   #59
Fastbrz
Drives: Wrb brz
I would imagine 5w30 would be best. It's what I have used when it was stock and when I went forced induction. 22,000 miles and counting no issues.
Fastbrz is offline   Reply With Quote
Old 10-25-2014, 05:10 PM   #60
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
I use 5w30.
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
Old 10-25-2014, 09:59 PM   #61
Astroboy
Astroboy's Avatar
Drives: None
Do u daily drive it? What part of Texas are you from.
Old 10-26-2014, 09:54 AM   #62
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Castrols base stock is made using a process that many top oil companies used to do years ago but have stopped and moved on.
Old 10-28-2014, 08:48 PM   #63
Poodles
Drives: 2015 Series.Blue
Outdated info and doesn't cover their European line.
Old 10-29-2014, 10:55 AM   #64
bluesubie
Go with a Euro xW-30 like Euro Castrol 0W-30 or Motul X-Lite 0W-30. Skip any oil labeled as Resource Conserving/GF5 because they all pretty much shear to a 20 grade after hard driving in a turbo, which is what they are designed to do.
Brand doesn't matter. You can also blend your own xW-30 by combining Mobil1 0W-20 and M1 0W-40. Mobil1's 0W-30 is a bit light which is why I wouldn't run it (unless you add some M1 0W-40 to it or Mobil1 Racing 0W-30).
-Dennis
bluesubie is offline   Reply With Quote
Old 10-30-2014, 12:16 AM   #65
Astroboy
Astroboy's Avatar
Drives: None
-Dennis
Carp, I already went with Motuls 8100 5w30. And winter is arriving here in Dallas. Should I worry
Old 11-10-2014, 05:26 AM   #66
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
After looking around I think I'll be going with Amsoil Signature Series 0W30 for my FI build. Has anyone had any experience with them on this engine?
Seems to have good balance of HTHS 3.1, high TBN 12.5, low NOACK 7.6 and VI is 170. But they're like US$15/quart.
Redline is even more expensive down here....their 5w30 is around US$20/quart.
A cheaper Ester based alternative for us would be an Penrite Racing 5w30 (US$60 for 5 litres) but I can't really find much reviews about it. Plus they don't provide any HTHS value for it, and their zinc levels are pretty high.
Fizz is offline   Reply With Quote
Old 11-10-2014, 10:10 AM   #67
bluesubie
Just keep your intervals short on SSO. I tried 7,500 mile intervals in my EJ turbo and it was a bit much for the oil based on uoa's. I've stuck with at least a 3.5 HTHS oil, and shorter intervals, in my turbo since then.
I don't think there's a problem with running high zinc levels as a lot of people run Motul 300V and Red Line. For the cost, I would go with Penrite Racing, as long as it has enough detergents for the street.
Holy mackerel. It has double the zinc of Red Line and Motul 300V!
http://www.penriteoil.com.au/pis_pdf...ULY%202014.pdf
This oil is more like Red Line Racing as opposed to regular Red Line. It does say on road and off road so I presume it has enough detergents for the street.
-Dennis
Old 11-11-2014, 03:42 PM   #68
pleong
Drives: 2013 Whiteout FR-S
I'm running AMSOIL 15w50 Racing oil. I'm pushing ~515whp and it's held up really good.
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
Old 03-05-2015, 01:38 AM   #69
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Just received my OUA and the report doesn't seem very good. Here are the details:
Engine: 13,000 miles (FI since 11,000 miles)
Engine oil: Redline 5w30 (2000 miles on this oil)
water 0
lead 1
calcium 2603
oxidation 123
boron 0
zinc 1048
molybdenum 140
copper 2
fuel dilution 2
Viscosity at 100 9.6
phosphorus 0
magnesium 8
tin 0
nickel 2
TBN 9.1
nitration 11
sodium 5
aluminium 3
silicon 29
iron 9
FTIR soot 9.7
chromium 0
"Silicon is at 29ppm. Silicon is a highly abrasive material and can cause accelerated wear. Check air intake system. Viscosity @40 decreased to 54cst. 2% Fuel Dilution Detected. The presence of fuel can indicate faulty injectors, pumps or liners leading to poor combustion. Excessive idling/incorrect timing could also be a possibility. Oxidation and Sulphation are elevated. Oxidation is caused by abnormal combustion, high temperatures, oil aeration and high levels of copper. This can increase oil viscosity and leave piston deposits causing piston rings to stick."
@bluesubie @viscositosis.rex
Old 03-05-2015, 10:04 PM   #70
Astroboy
Astroboy's Avatar
Drives: None
water 0
lead 1
calcium 2603
oxidation 123
boron 0
zinc 1048
molybdenum 140
copper 2
fuel dilution 2
phosphorus 0
magnesium 8
tin 0
nickel 2
TBN 9.1
nitration 11
sodium 5
aluminium 3
silicon 29
iron 9
FTIR soot 9.7
chromium 0
So what are going to do? Switch to a different grade?
Best oil for turbo engine whitefrs Forced Induction 36 10-09-2014 02:45 PM
Engine Noise on Turbo FRS whitefrs Forced Induction 23 04-18-2013 10:30 AM
1.6L DI TURBO ENGINE quik1987 BRZ First-Gen (2012+) — General Topics 39 11-30-2011 06:01 PM
FT-86 / FR-S engine will be Toyota 2l turbo!! Slide Engine, Exhaust, Transmission 114 07-07-2011 11:58 PM
Do you want a turbo engine for the FT-86? Read here Ramo BRZ First-Gen (2012+) — General Topics 86 06-23-2011 09:39 PM
