Old 06-03-2019, 02:53 PM   #57
Fast13FRS
Fast13FRS's Avatar
Drives: 2013 Scion FRS
BTW, your President is visiting 'Un-Known' this week. I think he's enjoying himself.
Yeah we let him out every now and again he needs some tea & krumpets
Fast13FRS is offline   Reply With Quote
The Following User Says Thank You to Fast13FRS For This Useful Post:
JD001 (06-03-2019)
Old 06-03-2019, 03:03 PM   #58
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Give him a thwack in the plums for us when he stops by for tiffin.
Old 06-04-2019, 12:12 AM   #59
humfrz
Oh, my
Old 06-04-2019, 12:03 PM   #60
Riftur
Riftur's Avatar
The only place that the recall work is mandatory is California. Just skip it.
Hey Tcoat,
My 13 FRS has almost 50k hard driven miles on it currently without any major issues. I am worried the car will not be the same reliable beauty it is when I get it back. If someone decides not to have the valve-spring replaced and it fails, are you just screwed at that point? I just got my recall notice in the mail last month and I have not gone through the threads yet to know if people have had any issues after the work is done.
Riftur is offline   Reply With Quote
Old 06-04-2019, 12:24 PM   #61
humfrz
Originally Posted by Riftur View Post
Hey Tcoat,
humfrz for Tcoat
Riftur - I suggest you start here:
http://www.ft86club.com/forums/showthread.php?t=133095
My 2013 has 25,000 easy miles and I'm passing on the recall.
humfrz
Riftur (06-04-2019)
Old 06-04-2019, 12:26 PM   #62
Hey Tcoat,
If you read the recall there is language there that indicates Toyota would reimburse persons that had an engine failure due to the springs and had the engine repaired as a result. That would point to them repairing a damaged engine if it failed without the fix. Of course, the burden will be on you to prove the valves failed, which shouldn't be too difficult.
Of course, there is no guarantee on that.
Riftur (06-04-2019)
Old 06-04-2019, 12:28 PM   #63
Riftur
Riftur's Avatar
humfrz for Tcoat
humfrz
Thanks for pointing me in the right direction.
The Following User Says Thank You to Riftur For This Useful Post:
humfrz (06-04-2019)
Old 06-04-2019, 12:29 PM   #64
maslin
Benz Tech
Drives: 2017 BRZ Premium
Hey Tcoat,
Did they call you to set an appointment and you told them you're refusing to have the work done? Or did you get a piece of junk mail you threw out and didn't even bother reading?
If you go to the dealer for other work and refuse to have the recall performed it will be documented.
maslin is offline   Reply With Quote
Old 06-04-2019, 12:31 PM   #65
My 2013 has 25,000 easy miles and I'm passing on the recall...
On the other side, I'm over 6,000 miles past when I had the recall done, and no issues so far. That said, had I not been an "early adopter" I'd be very tempted to not do it, particularly given my car had over 136,000 miles on it at the time I had it done. It is very unlikely I was going to suffer the spring failure.
humfrz (06-04-2019)
Old 06-04-2019, 12:47 PM   #66
Riftur
Riftur's Avatar
I got the recall notification in the mail but I do not consider it junk mail. No one called.
Old 06-04-2019, 12:50 PM   #67
Riftur
Riftur's Avatar
If I had that many miles on the car I would actually be happy for them to do the work. I would see it more as a refresh of the engine.
Old 06-04-2019, 12:56 PM   #68
maslin
Benz Tech
If your valve spring fails in 2 years and the dealer refuses the repair, stating that you were informed and refused the recall... You see where I'm going?
It was junk mail, didn't even read it. No one called, I have no idea what a valve springer retainer replacement even is. Please fix my engine, I'll pick it up when it's done.
I've performed recalls on 40 year old cars. When the car comes in to the dealer, the recall is to be performed, whenever that may be.
The Following User Says Thank You to maslin For This Useful Post:
Riftur (06-04-2019)
Old 06-04-2019, 01:06 PM   #69
Riftur
Riftur's Avatar
Oh wait, valve what?? Mail? I have no clue what your talking about.
Thanks,
maslin (06-04-2019)
Old 06-04-2019, 01:23 PM   #70
aemravan
for this particular topic I would definitely lean towards the "if it aint broke, don't fix it" side considering all the horror stories that keep surfacing.
None of the parts the gets replaced under the recall would "freshen up the engine" if they were taken off to begin with. So best case scenario is you replace springs that probably wouldn't have failed anyway, worst case scenario you end up with a spun bearing due to blockage that they deny to repair.
aemravan is offline   Reply With Quote
The Following User Says Thank You to aemravan For This Useful Post:
jeffchap (06-04-2019)
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 10:32 PM
Valve spring failure sandy s Issues | Warranty | Recalls / TSB 15 05-07-2019 10:00 PM
valve spring procedures ric342 Southern California 3 03-21-2019 09:46 PM
BRZ Valve Spring Recall mrhemi Issues | Warranty | Recalls / TSB 6 03-01-2019 04:35 PM
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 05:20 AM
