Southern California SoCal
Old 03-21-2019, 08:07 PM   #1
ric342
FR-S driver
ric342's Avatar
Drives: ULTRAMARINE Scion FR-S
valve spring procedures
Correct me if im wrong, but to fix the recall all the pulleys including the waterpump pulley need to be removed right? I ask, because not even 2k miles into the fix my almost new waterpump pulley is making noise. I take it to the dealer and they say that the pulley is bad. I had replaced them not six months prior to the recall. My thoughts are that the tech used a gun to tighten them and damaged it, and now im facing the consequences. What are your thoughts?
mod on
ric342 is offline   Reply With Quote
Old 03-21-2019, 08:29 PM   #2
humfrz
Why did you replace the pulleys?
Did you replace them with OEM pulleys or aftermarket light weight pulleys?
humfrz
Old 03-21-2019, 08:41 PM   #3
ric342
FR-S driver
ric342's Avatar
humfrz
ya, i bought the greddy pulley kit belt was due and I figured that I would kill 2 birds with 1 stone.
mod on
Old 03-21-2019, 08:46 PM   #4
humfrz
Since they were aftermarket, the dealer may not accept responsibility -
However, you could ask them.
humfrz
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 09:32 PM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-08-2019 11:38 PM
valve spring issue? nikitopo Issues | Warranty | Recalls / TSB 1037 05-01-2019 10:55 PM
BRZ Valve Spring Recall mrhemi Issues | Warranty | Recalls / TSB 6 03-01-2019 03:35 PM
Valve Spring Recall venturaII New England 13 02-25-2019 07:41 PM
