Old 09-02-2016, 06:04 PM   #57
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Well, there you have it. Tuning is what breaks rods, not the additional pressure caused by forced induction. Nor does fi increase the likelihood of having an internal engine issue.....
Old 09-02-2016, 06:24 PM   #58
You infer things that I am not saying. Don't misquite or twist what I am saying.
Old 09-02-2016, 06:52 PM   #59
Summerwolf
Panda Trueno
Summerwolf's Avatar
Ahhhh. Not trying to twist anything, I feel my overall statement was correct and you said it is tuning issues.
Old 09-02-2016, 06:53 PM   #60
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
it is completely dependent on the tune of both systems. Most people are not going FI with the intention of relieving stress on the rods, but it is entirely feasible and possible.
The CSG BRZ has over 54k miles at 400whp, and it's not driven easy. How could that possibly be?!?
Pixie Dust?
MS, CSCS, TSAC-F, CPT
Old 09-02-2016, 09:00 PM   #61
Nope, still changing what I'm saying.
I said it is *tune dependent*.
Old 09-02-2016, 09:43 PM   #62
Summerwolf
Panda Trueno
Summerwolf's Avatar
Ok...... so depending on tune fi doesn't increase pressure on connecting rods.
Old 09-02-2016, 10:02 PM   #63
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
again you're insinuating that the rods can't handle increased pressure
I just want to know what you are basing your assertion on that the rods can't handle increased pressure???
As I stated in my original response, increased power always includes an increased risk in failures...
Your assertion that these cars are known for rod failures though leads me to believe that you're basing this fear of rod failure with FI on these known rod failures.
If that IS your assertion, then it just doesn't hold up.
You can't keep changing the standard by which your assertions are being measured...
First you said that these cars are known for rod failures, then you said it increased the likelihood of failure because of increased pressures...
Well, which is it? Are you generally asserting that increased cylinder pressures are more likely to result in failure? Duh!!! no one is arguing against that, we're merely arguing against the level of increased risk (with a proper tune).
Or are you sticking with your original assertion that the known rod failure issue leads you to believe that FI isn't safe at all in this platform.
You don't get it both ways.
Jaden
Jaden is offline   Reply With Quote
Old 09-02-2016, 10:15 PM   #64
Summerwolf
Panda Trueno
Summerwolf's Avatar
Again you're not getting it. Change your sn to pennywise.
Jaden
My first quote is that FI is the way to make power, when you make power you exponentially increase the likelihood of rod failure.
Basically.... when you increase stress to the motor (fi) you will bring out the weak points and will wind up building a motor in the quest for "high hp." Build a motor, increase your power potential and also your potential for issues.... it is a never ending spiral.
I have seen plenty of cars make power on stock bottom ends, but everyone that does acts like they walk on egg shells.
Need some input LOOK!! skavengers412 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-21-2016 12:50 PM
Clutch Input dabocx Forced Induction 221 01-19-2016 06:20 PM
2015 FRS AUX input? rushofmusic Scion FR-S / Toyota 86 GT86 General Forum 12 12-13-2014 11:01 AM
Looking for SUV Input ap5512 Other Vehicles & General Automotive Discussions 16 09-23-2014 02:48 PM
Going Supercharged - Need Input! mothespaceman Forced Induction 46 09-15-2014 09:25 AM
