Drives: Scion FRS
Clutch Input
So im looking to order a clutch for forced induction, can anyone here thats put a clutch in their car provide some input? Experience, feel, would you buy again exc exc?
I Love custom Turbo kits
Drives: Limited BRZ
I'll start driving the Clutchmasters FX300 this weekend. Will input feedback here ASAP.
i've been looking for the same info.
Drives: Pile of junk
i have the fx400 drove it for about 100 miles before motor gave out.
short time driving it,,,feel was good clutch pedal was a little bit stiffer than stock but wasnt to to bed. it is LOUD on deceleration. driving in town stop and go traffic wasnt bad either other than how loud it is but nothing you can do about that other than crank up the volume on stereo and just smile when ppl look at you like your car is about to fall appart like they did to me. on stock tires the fx400 will spin tires like no tomorrow even with me taking off slow i could feel tires wanting to break traction. |
NASA SpecE30 Racer
Seems most have the Clutchmasters FX400 or the ACT 6 puck sprung. From the reviews I have read they both perform very similarly. Don't let anyone tell you they are "just like OEM" or have "OEM drivability". They don't. My ACT 6 puck is pretty in or out. There is very little slip and you need to have the RPM high enough because when it grabs it takes about 1000 RPM with it and you will stall if you try to let the clutch out just off idle. Then there is the chatter at lower RPM like when you have your A/C turned on and are idling. If you have moderate power goals, then I would stick with an ACT full face or a Clutchmasters FX300. Will be interesting to see David's review.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | Nomed Alucard (03-08-2015) |
how much torque does the fx300 hold?
Drives: Limited BRZ
Drives: White FR-S
We use the Exedy Stage 1 Clutch on our 345whp, 257wtq FR-S. We can tell you with certainty, that it is the closest that you'll get to the stock clutch, in terms of range of modulation and overall feel. There is a little bit of clutch noise when idling in neutral, but it's very minor compared to most other aftermarket clutches. This clutch is 100% parallel parking friendly.
Please contact us, if you'd like any additional information. |
When I replace my clutch, which is an inevitability, I am probably going with the FX350 which is more aggressive than a single element clutch, but not as rough as a puck style clutch. I originally went with the FX400 due to most clutches being rated to hold "up to 300 ftlbs" of torque which is quite a bit lower than my goal and the FX350 hadn't been developed for the FR-S yet.
The FX400 isn't horrible, the clutch pedal effort is higher than stock but not that bad. The noise gets worse as the clutch breaks in and ages. I figure that I'll put another 10k miles on this clutch and then I'll swap it out, kinda curious how well it holds up and what the pucks will look like when I do! |
#10 | |
Drives: Limited BRZ
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | batlwagn (05-04-2016) |
#11 | |
Drives: storm black GT
#12 | |
The VividRacing FR-S had one in it way back when...at least they claimed that they did. |
#13 | |
Drives: Limited BRZ
But anyway, the 300 and 350 are rated for the exact same torque.
#14 |
Well if that's the case that kinda sucks...
| Clutch engagement issue. Possible clutch cylinders upgrade? | wu_dot_com | Engine, Exhaust, Transmission | 42 | 04-05-2016 01:11 PM |
| Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 01:22 PM |
| Clutch Masters Clutch Kits | Island Import Performance | IslandImportPerformance | Transmission and Driveline | 1 | 07-20-2012 01:06 PM |
| ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 04:48 PM |
