Old 03-13-2016, 10:47 AM   #673
raven1231
Originally Posted by stevo585 View Post
You mean an intercooler? There way less than that for an off brand:
http://www.ebay.com/itm/27-x-7-x2-5-...-/272138518898
Damn that's real cheap. If I still had this I'd probably fab up some piping and give it a shot lol
Old 03-14-2016, 02:35 PM   #674
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Well, the ACE header is on. I am quite happy.
And this morning i received my new(used) ESC kit from Lord09. Once I get some extra pieces(some battery tray bits, and maybe a new pedal switch harness) from either Rob or Shiv, I will get this badboy installed. I may not go back down to Cobb right away (it may cause a divorce) but, I can use a local dyno here and do a before and after on the ESC. I think i will be the first person on the forum to be running an ACE header with an ESC.
It is good to be back in the ESC family though. Anytime you can bolt easy and clean power to your car, its always fun. I also snagged an OFT(from Lord09) for my buddies Miata. I am trying to get him to go the ESC route.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
The Following User Says Thank You to brzaapi For This Useful Post:
Lord09 (03-14-2016)
Old 03-14-2016, 02:45 PM   #675
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Nice! As per the usual let me know if you need anything and I keep us informed. The esc is pretty spectacular on the Miata. I think it fits that engine better than the ft86.
Installed Mods:
Old 03-14-2016, 02:56 PM   #676
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Well, if you have the battery tray parts and a new pedal/switch/fuse harness I will take those.
I am hoping Rob or Shiv get back to me soon.
Daily: Audi TT RS
Old 03-14-2016, 03:09 PM   #677
brzaapi
CAR-AHOLIC
brzaapi's Avatar
I was making an assumption that the power made on the Miata would make a bit more of a difference, or at least it feels that way. I was trying to tell my buddy the same thing.
Since you are adding power to a lighter car, and also since you are starting with less power to begin with, the added power would have a more significant impact. Correct?
Daily: Audi TT RS
raven1231 (03-14-2016)
Old 03-14-2016, 03:14 PM   #678
Sojhinn
Sojhinn's Avatar
I'll take a look. I may have an og harness.
Installed Mods:
Old 03-14-2016, 03:45 PM   #679
raven1231
yes correct. It makes more power on the small engine. So Miata users should definitely feel like it's a big upgrade.
Old 03-14-2016, 03:46 PM   #680
Sojhinn
Sojhinn's Avatar
Yeah more power.
Installed Mods:
Old 03-14-2016, 04:16 PM   #681
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Just FYI: an ic/intercooler/fmic wont do anything for the phantom. A turbo/supercharger needs it since air heats up as it goes through them, but the phantom doesn't heat up the air much, at all (maybe a tiny bit...but nothing an IC would help with). Its not like an intercooler automatically makes air a certain temp, it just keeps temps from getting too high. (So having an IC doesn't turn 90f air into 40f).
90F air with a turbo pre-intercooler is gonna be mid-80's or higher after-intercooler.
90F air with turbo NO intercooler is like 100+after turbo.
90F air with phantom is still 90ish after phantom.
An intercooler won't help cool temps for the phantom, and adding one would just create more lag, pressure drop etc.
Old 03-14-2016, 04:42 PM   #682
DAEMANO
Time Traveller
The tray vendor and part# areposted somewhere in the main Phantom thread.
If you don't have this stuff, I may have some of it. Will have to dig a little.
Old 03-14-2016, 10:56 PM   #683
stevo585
Drives: White 2014 BRZ
So you have logged? Or guessing?
You know PV=nRT (ideal gas always applies). The air is being heated some amount and you could calculate it.
I do agree an intercooler is more trouble than its worth. Works does use that inline intercooler which is interesting but I have a hard time believing it does anything.
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Old 03-15-2016, 10:00 AM   #684
brzaapi
CAR-AHOLIC
brzaapi's Avatar
I could probaby make the batteries work. I am missing a few blocks, but i could probably rig something. As for the wiring harness, if anyone has an extra please let me know. I didnt think anybody would , but if you do then great.
I asked Rob about the harness. He mentioned i should just undo any mods done to the cable. But that is what i am trying to avoid. I would rather have a healthy one if at all possible. If not then, I can move ahead and do my best.
He also mentioned that my unit was a prototype unit. It looks like the one i had before, so I am not sure what has been changed.
Daily: Audi TT RS
raven1231 (03-15-2016)
Old 03-15-2016, 12:39 PM   #685
Sojhinn
Sojhinn's Avatar
This may be one of the first units... And it may be the one I've helped install several times already.
(By help I mean, email and texts) Does this have the relay?
Installed Mods:
Old 03-15-2016, 12:52 PM   #686
Namuna
Namuna's Avatar
One thing I have noticed in the few short months of owning the kit is the weather effects the performance alot. Also seems like its takes a couple bursts to get the batteries doing their best even if ambient temp is warm. Sometimes I barely feel the kick especially if you activate in the 5k rpm range. Seems like it needs wot around 3k to really feel it. I know the boost tapers...
70-80F weather is faster but meh. Even on e85.
40F weather is
Anyone agree? Maybe I'm just getting use to it. But its leaving me wanting more now...
Even though the topic is about Cold Air Intakes, this video goes through the actual math involved in figuring out the power difference when temperature differences are involved.
[ame="https://www.youtube.com/watch?v=Hiod1c2Py70"]Cold Air Intake - Explained - YouTube[/ame]
Bottom Line: Colder air is denser air, which equates to more power
Namuna is offline   Reply With Quote
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 03:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
