Old 02-16-2016, 07:39 PM   #561
stevo585
Drives: White 2014 BRZ
Damn a 104 trap??
Yes the 13.8 was on e85 and I can do better yet with practice.
On 93 I ran 14.2 @ 99.
NA e85 I ran 14.3 @ 96.
So as you can see its mostly in the launch. Best I can do is a 2.15 60' so far on my pss. These cars are just sprung too hard for drag. Without drag radials I doubt I can do sub 2.0.
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Old 02-16-2016, 07:49 PM   #562
stevo585
Originally Posted by shaynek View Post
Hey guys, what's the max boost you are able to hit on the v3 phantom?
Is there even any difference why it would make more boost?
I have an original kit but with the latest batteries. I see 4.5-4.8 psi @ ~3.5K.
Old 02-16-2016, 08:02 PM   #563
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
no clue. I thought the newer ones were able to produce a bit more boost. I have the 1.5 dump pack and i can only hit low 4, high 3s. once these batteries go bad i will defiantly upgrade to the new batteries
shaynek is offline   Reply With Quote
Old 02-16-2016, 08:32 PM   #564
stevo585
Well elevation would matter too. I'm at 100 ft but your probably low too in CA? The batteries is probably the difference. Is your voltage 28.x like it should be?
Note my boost was MAP sensor reading in ecutek. Not sure what a gauge would read haven't installed mine yet. (should be the same I'd assume)
Old 02-16-2016, 08:42 PM   #565
shaynek
shaynek's Avatar
yea my battery voltage is usually 28.5-6. Elevation is about 52 here. I logged mine on the oft.
Old 02-17-2016, 05:37 PM   #566
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
mine usually reads at 28.3 - 28.5 depends on outside temperature.
i usually get 4.5 - 4.8 psi
Old 02-17-2016, 06:22 PM   #567
raven1231
Originally Posted by Target70 View Post
I think it's a good time. and not to be a downer, but beating 50 year old benchmarks is not really the best measurement of performance. That would be like a new smartphone manufacturer saying "It isn't as fast as the new I-phone, but compare it to the top of the line supercomputer in 196X that sent us to the moon and that really shows what it can do!"
Couldn't agree more. Comparing modern day devices to ancient versions is ridiculous...
Old 02-17-2016, 08:34 PM   #568
stevo585
Same psi as me except my voltage is 28.5 -28.7 but close enough lol. Do you have the latest big crank batteries?
Old 02-17-2016, 09:03 PM   #569
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
The voltage actually fluctuates due to the meter not so much the batteries.
As for psi... When I was running v3 I was getting around 4.8-5.0 psi.
Steve
Installed Mods:
Old 02-17-2016, 10:55 PM   #570
zc06_kisstherain
Drives: SWP BRZ
yes Odyssey battery
Steve
yeah as long as battery reads 28.x, i wouldnt worry anything
Old 02-18-2016, 12:31 AM   #571
shaynek
shaynek's Avatar
yes Odyssey battery
I'm hitting 4 wish on 1.5 dump pack. Probably due to weak batteries or elevation.
I still don't know how this forum works. lol i can't quote all of you for some reason.
Old 02-18-2016, 12:42 AM   #572
keen as
keen as's Avatar
Drives: 86 GT MT
I feel like quoting Monty Python. "you are lucky"
I only get up to high 3 psi. Perhaps my RHD car is a factor due to the longer dump cables required.
keen as is offline   Reply With Quote
Old 02-18-2016, 12:06 PM   #573
KoolBRZ
KoolBRZ's Avatar
Aren't there two different types of compressor wheel used in the old and new Phantoms? I thought the newer Phantoms have the lighter compressor wheel, enabling them to spool up higher and faster, making more pressure.
If I say yes, will that make you think I understand?
Old 02-18-2016, 12:27 PM   #574
Sojhinn
Sojhinn's Avatar
Yup.
Installed Mods:
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 03:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
