#561 |
Drives: White 2014 BRZ
Damn a 104 trap??
Yes the 13.8 was on e85 and I can do better yet with practice. On 93 I ran 14.2 @ 99. NA e85 I ran 14.3 @ 96. So as you can see its mostly in the launch. Best I can do is a 2.15 60' so far on my pss. These cars are just sprung too hard for drag. Without drag radials I doubt I can do sub 2.0.
JDL Turbo kit - Ecutek, HRI tuned.
#562 | |
I have an original kit but with the latest batteries. I see 4.5-4.8 psi @ ~3.5K.
#563 |
Drives: BRZ Limited; GR86
no clue. I thought the newer ones were able to produce a bit more boost. I have the 1.5 dump pack and i can only hit low 4, high 3s. once these batteries go bad i will defiantly upgrade to the new batteries
#564 | |
Note my boost was MAP sensor reading in ecutek. Not sure what a gauge would read haven't installed mine yet. (should be the same I'd assume)
#565 | |
#566 |
Drives: SWP BRZ
#567 | |
#568 |
Same psi as me except my voltage is 28.5 -28.7 but close enough lol. Do you have the latest big crank batteries?
#569 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
The voltage actually fluctuates due to the meter not so much the batteries. As for psi... When I was running v3 I was getting around 4.8-5.0 psi. Steve Sent from my iPhone using Tapatalk
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#570 | ||
Drives: SWP BRZ
#571 |
#572 |
Drives: 86 GT MT
I feel like quoting Monty Python. "you are lucky"
I only get up to high 3 psi. Perhaps my RHD car is a factor due to the longer dump cables required. |
#573 |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Aren't there two different types of compressor wheel used in the old and new Phantoms? I thought the newer Phantoms have the lighter compressor wheel, enabling them to spool up higher and faster, making more pressure.
If I say yes, will that make you think I understand?
#574 | |
Yup. Sent from my iPhone using Tapatalk
| Jackson Racing Supercharger Owners Thread | enivid | Forced Induction | 6049 | 06-25-2026 10:40 PM |
| Full throttle Electric Supercharger Build Thread | fenton | Forced Induction | 11315 | 04-07-2025 06:42 PM |
| Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4310 | 04-07-2025 01:12 PM |
| phantom supercharger restrictions? | Shinigunz | Forced Induction | 12 | 05-13-2014 03:28 AM |
| Drift-Office : Phantom Supercharger - Tuned! | Drift-Office | Forced Induction | 67 | 10-25-2013 09:51 AM |
