10-22-2015, 02:14 PM | #561 |
yes. i have 245 wide tires with 17x9+35. 100% stock suspension. 235 should work fine as well.
The Following User Says Thank You to mixxxx For This Useful Post: | xsnapshot (10-29-2015) |
10-22-2015, 08:37 PM | #562 | |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
On a handling note, I've noticed that when I'm doing long sweepers and the back starts to kick out, accelerating through the sweeper will counteract that.
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread |
The Following User Says Thank You to Aztec For This Useful Post: | Kuri (10-23-2015) |
10-22-2015, 09:40 PM | #563 |
Drives: 10 Series
GUNMETAL: On TRD springs and stock struts. 225/45 dunlop direzza zii's. Was able to keep the max camber achieved using the 14mm bolt/spc combo b/c of my tire choice but I had these for autox already. Prob around -2 camber front and back. Front is flush on top or damn close to it. Never got an alignment, 6 months in, still near even tire wear. I needed extended lugs too. $1060 shipped from Oakos' ebay store using make an offer.
The Following User Says Thank You to Bimble Bamble For This Useful Post: | Astroboy (10-28-2015) |
10-23-2015, 09:06 AM | #564 | |
Drives: 2014 BRZ Limited SWP
splitter and alignment was new to me that weekend
#TrackDayBro
10-24-2015, 02:14 PM | #565 |
Miata traitor
Drives: 2002 Miata SE
17x9+35 on 235/45 on FA500's -1.5 square
10-28-2015, 05:27 PM | #566 |
What license?!
Drives: 2015 Scion FR-S
17x9 +35 245/40 Ventus V12
The Following User Says Thank You to 2JZ-GTE For This Useful Post: | Astroboy (10-28-2015) |
12-01-2015, 10:04 AM | #567 |
Drives: 2014 ASPHALT FR-S MT
Do I need more then -1 camber up front to clear 245/40/17 ?
12-01-2015, 09:40 PM | #568 |
The Following User Says Thank You to tyler_win_photo For This Useful Post: | el-92 (12-01-2015) |
12-01-2015, 11:19 PM | #569 |
Thanks 👍 . Just wanted to know before i ordered tires since I'm lowered about 1inch and have -1 camber up front my wheels are just sitting there hopefully have tires on them by the weekend now that I know ill clear
12-05-2015, 03:54 AM | #570 |
Drives: 86 GTS
with 255s
The Following 4 Users Say Thank You to 86•BRZ For This Useful Post: |
12-05-2015, 04:00 AM | #571 |
Drives:
12-05-2015, 04:08 AM | #572 |
Drives: 86 GTS
12-05-2015, 04:14 AM | #573 |
Drives:
Similar Threads | ||||
Wheel Directory: Enkei RPF1 17x9.0 +45 | LevinPhan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 265 | 06-04-2024 11:13 AM |
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** | LSD Motorsports | Groupbuys | 246 | 08-29-2013 01:35 PM |
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 | Touge Factory | Wheels and Tires | 2 | 02-05-2013 04:53 PM |
