Old 10-22-2015, 02:14 PM   #561
mixxxx
mixxxx's Avatar
Originally Posted by xsnapshot View Post
Having trouble finding the answer to this. (Did search but was confused)
I'm planning on going with these 17x9 RPF1's with 235 tires. Will they clear on a 100% stock BRZ suspension setup? Do I need a different offset to make it work?
yes. i have 245 wide tires with 17x9+35. 100% stock suspension. 235 should work fine as well.
mixxxx is offline   Reply With Quote
The Following User Says Thank You to mixxxx For This Useful Post:
xsnapshot (10-29-2015)
Old 10-22-2015, 08:37 PM   #562
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Originally Posted by Kuri View Post
Pretty well. I track pretty often so this was the track mechanic recommended because I kept rolling my tire in long sweeper/carousel type turns. I have also a slight toe out on all wheels. (Better rotations) [Track stuff]
I did -2 for a good awhile. It's flush with the fender.
Yeah I know the whole toe stuff as well, good for track, not so much for DD haha. I'm getting slight poke at the fronts with -1.4; only problem is I don't have any clearance with lowering springs to go more negative ;_;
On a handling note, I've noticed that when I'm doing long sweepers and the back starts to kick out, accelerating through the sweeper will counteract that.
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
The Following User Says Thank You to Aztec For This Useful Post:
Kuri (10-23-2015)
Old 10-22-2015, 09:40 PM   #563
Bimble Bamble
Drives: 10 Series
GUNMETAL: On TRD springs and stock struts. 225/45 dunlop direzza zii's. Was able to keep the max camber achieved using the 14mm bolt/spc combo b/c of my tire choice but I had these for autox already. Prob around -2 camber front and back. Front is flush on top or damn close to it. Never got an alignment, 6 months in, still near even tire wear. I needed extended lugs too. $1060 shipped from Oakos' ebay store using make an offer.
Bimble Bamble is offline   Reply With Quote
The Following User Says Thank You to Bimble Bamble For This Useful Post:
Astroboy (10-28-2015)
Old 10-23-2015, 09:06 AM   #564
Kuri
Kuri's Avatar
Drives: 2014 BRZ Limited SWP
learned real quick that lifting will let me cut grass. Lifted too much to throttle steer and rotated off. I was leading a pack of 86s in my run group and they all watched me spin.
splitter and alignment was new to me that weekend
#TrackDayBro
Kuri is offline   Reply With Quote
Old 10-24-2015, 02:14 PM   #565
KevinK121
Miata traitor
KevinK121's Avatar
Drives: 2002 Miata SE
17x9+35 on 235/45 on FA500's -1.5 square
KevinK121 is offline   Reply With Quote
The Following 4 Users Say Thank You to KevinK121 For This Useful Post:
Astroboy (10-28-2015), dattran86 (10-27-2016), SG02WRX (10-24-2015), YangerD (11-21-2015)
Old 10-28-2015, 05:27 PM   #566
2JZ-GTE
What license?!
2JZ-GTE's Avatar
Drives: 2015 Scion FR-S
17x9 +35 245/40 Ventus V12
2JZ-GTE is offline   Reply With Quote
The Following User Says Thank You to 2JZ-GTE For This Useful Post:
Old 12-01-2015, 10:04 AM   #567
el-92
el-92's Avatar
Drives: 2014 ASPHALT FR-S MT
Do I need more then -1 camber up front to clear 245/40/17 ?
el-92 is offline   Reply With Quote
Old 12-01-2015, 09:40 PM   #568
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Typically to clear the spring, you'd want less camber, not more. I think you should be good with -1 degree and that set up though.
tyler_win_photo is offline   Reply With Quote
The Following User Says Thank You to tyler_win_photo For This Useful Post:
el-92 (12-01-2015)
Old 12-01-2015, 11:19 PM   #569
el-92
el-92's Avatar
Thanks 👍 . Just wanted to know before i ordered tires since I'm lowered about 1inch and have -1 camber up front my wheels are just sitting there hopefully have tires on them by the weekend now that I know ill clear
Old 12-05-2015, 03:54 AM   #570
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
with 255s
86•BRZ is offline   Reply With Quote
The Following 4 Users Say Thank You to 86•BRZ For This Useful Post:
JMon85 (10-03-2017), N234 (12-05-2015), slow15frs (02-18-2016), Walldodger (01-19-2016)
Old 12-05-2015, 04:00 AM   #571
N234
N234's Avatar
Drives:
Originally Posted by 86•BRZ View Post
with 255s
Nice! It looks good with that inside tire trying to lift off.
Is it on coilovers?
Is that a staggered or square set?
N234 is offline   Reply With Quote
Old 12-05-2015, 04:08 AM   #572
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Is it on coilovers?
yep, 255 square.
Old 12-05-2015, 04:14 AM   #573
N234
N234's Avatar
Drives:
yep, 255 square.
And what suspension do you have on it?
Old 12-05-2015, 04:17 AM   #574
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
The great stuff from down under, MCA suspension
The Following User Says Thank You to 86•BRZ For This Useful Post:
N234 (12-05-2015)
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 265 06-04-2024 11:13 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
