Old 08-15-2012, 02:24 AM   #43
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Nearly identical setup here:
http://www.ft86club.com/forums/showthread.php?t=10436
Originally Posted by FML View Post
18x8.5 +47 225/40/18 Toyo T1R
18x9.5 +38 245/35/18 Toyo T1R
1 Inch drop
Back poking out about 1/2 - 1 inch didnt really measure it
+47 in the front is pretty flush. I think +38 will poke out like the rear
Riding on 18s I notice the car seems a bit more sluggish during take off. I was worried about understeer with the staggered fitment but the handling does not seem to have been affected much other than having way more grip. I dont notice any understeer but this is just my daily driver and I'm not a track nut/expert
Hope this helps anyone trying to decide on offsets.
Old 08-15-2012, 02:26 AM   #44
DarrenDriven
NW Region Moderator
Another nearly identical setup here:
http://www.ft86club.com/forums/showthread.php?t=14438
Originally Posted by Luke.Cariveau View Post
Here are some Emotion CR Ultimates in Matte Black
Specs:
Front; 18x8.5 +47 Offset W/ Goodrich Sportcomp 2 235/40
Rear; 18x9.5 +39 Offset W/ ^ 245/40
Old 12-23-2012, 12:23 PM   #45
FRS2000
FRS2000's Avatar
Drives: whiteout frs
Work Emotion Ultimate "Kiwami" Bronze
18X8.5 +38 (F)
18x9.5 +38 (R)
-2 Camber(F)/-3 Camber(R)
*** Thanks Ravspec for the Wheels
FRS2000 is offline   Reply With Quote
Old 12-23-2012, 01:01 PM   #46
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
Your car looks great! Thanks for the pics.
Beyer Subaru is offline   Reply With Quote
Old 12-23-2012, 01:08 PM   #47
_F-R-S_
Drives: 13 whiteout scion frs
How low!?
_F-R-S_ is offline   Reply With Quote
Old 12-23-2012, 01:32 PM   #48
FRS2000
FRS2000's Avatar
Please see FRS2000's Members Journal for more specs/pics
Old 12-23-2012, 07:08 PM   #49
RavSpec
Drives: Rx7
18X8.5 +38 (F)
18x9.5 +38 (R)
Love it !!!! Can we use ur pics ?
Sent from my iPad using Tapatalk HD
RavSpec is offline   Reply With Quote
Old 12-24-2012, 12:02 PM   #50
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
@RavSpec What brand is the Vortex Generator found in your first post, CS
Thanks
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 12-24-2012, 12:19 PM   #51
FRS2000
FRS2000's Avatar
Surely, you can use them.
Old 12-26-2012, 04:58 PM   #52
RavSpec
Drives: Rx7
Thanks
That should be chargespeed
Old 01-22-2013, 07:38 AM   #53
Skurj
Drives: SOLD...
Looking at a set of these wheels, and curious about the statement that coil overs are needed... I am guessing at the rear, yet a lot of other members have installed similar or less poke offsets with only lowering springs. Is this something due to the design of the wheels vs other manufacturers?
looking at 18x8.5 +38 and 18x9.5 +38 225/40 fr, 255/35 rr on probably eibach pro kit springs.
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 01-22-2013, 10:00 AM   #54
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
I went with 18x8.5 +38 and 18x9.5 +38 with 225/40 & 245/35 and I'm only doing springs (eibach sportlines). You shouldn't need coil-overs, at least I hope not, I haven't test fitted anything yet since it's the middle of winter here.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 01-22-2013, 12:31 PM   #55
Skurj
Drives: SOLD...
In my case I need to know... the car is being delivered without tires.. I have to supply my own rims and rubber to be able to pickup the car (no i don't have to install em myself) I'd hate to drop them off at dealer for install after i've paid a fortune only to get a call 2 days later saying they don't fit...
Paid for Mar 2018
Old 01-22-2013, 12:36 PM   #56
f0rge
everyone running these rims with coil-overs is way lower than any spring will get you so there shouldn't be any issues with fender clearance.
the only thing i could possibly see being a problem is the diameter of the stock spring/strut setup being appreciably larger than a coil-over setup.
however other members are running the same setup on stock springs/struts, so i cant really see where you'd run into issues.
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +30 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 179 11-20-2015 12:12 AM
Wheel Directory: Work Emotion XD9 18x9.0 +38 / 18x10.0 +18 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 103 11-21-2013 03:28 AM
Work CR Kiwami/Ultimate danscar Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 09-11-2012 12:24 AM
WORK Emotion Kiwami - 18x8.5/9.5. Staggered For FRS/BRZ *** Available Now *** RavSpec Wheels and Tires 59 07-24-2012 12:07 PM
WORK Emotion Kiwami - 17x9.0 +38mm 5x100 *** BRZ/FRS Spec *** RavSpec Wheels and Tires 5 07-19-2012 06:44 PM
