#43 | |
Drives: unlimited cheap build N/A track car
#44 | |
Drives: Track preped NA FRS
Good luck on your problem, it was my problem as well until I swapped engines
| The Following 2 Users Say Thank You to Icecreamtruk For This Useful Post: | ML (12-21-2021), RedReplicant (12-10-2021) |
#45 |
I would be kind of curious to see what failsafe mode is like on the units we have. Normal assist or turns off completely?[/QUOTE]
If you are referring to the stock 86 EPS unit, i can tell you exactly what it is like. The electric assist suddenly turns off. It does this at very high load moments, so the steering effort instantly becomes MUCH harder. Its not a good feeling, and can make it difficult to maintain a smooth line as it turns off and then back on. I am use to it now, but still hate it. |
#46 | |
Drives: 2022 GR86 (was 2013 BRZ)
I experience almost the exact same thing on my 2013 when switching to higher grip tires, in high g corners. Almost stock ride height w/ 7k/8k springs. It feels like the electric assist just stops completely during heavy trail braking or cornering.
No sign of rubbing inside the fender well. Quote:
#47 | |
The steering issue and rear wheel hop when power sliding in the rain are the two things that bother me the most with my car. I have been unsuccessful fixing either of those issues. |
| The Following 4 Users Say Thank You to ROADRACER For This Useful Post: |
#48 |
Drives: 2013 BRZ sprintex SC
guessing this was not sorted for anyone,
happans to me also now after upgrading to sem-slick tyres... really scary and really not safe. someone knows the reason? maybe givving the EPS direct power line from the battery trough a relay can solve the issue? does someone has the equipment to measure the power to the EPS and see if there are major drops due to high current draw? if that will be the cause than we can have "easy" fix. did someone tried givving the EPS power directely from the battery before? really need to fix this issue.... |
#49 |
Drives: None
I was able to lessen it by fixing some interference, but it didn't go away.
edit: Ordered a 2017+ module to test, worth a try since they are cheap
#50 |
Drives: 2014 GT86
#51 |
At the track
Drives: '14 FRS - Former e92 M3
Has anyone attempted to run an air duct up toward the location of the unit and get some cool air there? A friend of mine had a similar issue on a C7 Z06 and a air duct helped
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
#52 |
I think it's and overload issue, not an overheating issue, because it seems to happen as much in the beginning of track session as the end (on cool days).
The good news is I found a fix: Buy a 2022!
#53 |
Drives: 22 BRZ
Had this happen on a 2022 yesterday. Not a good feeling approaching a corner at high speeds!
#54 |
Drives: '22 BRZ
Yup, keeps happening on my 2022 too. Some corners are worse than others.
#55 |
Drives: None
My car is still in pieces, but I want to try what Icecreamtruk is doing before I swap in the newer module I bought. It sounds like you can run it with no CAN integration, just power, and it no longer has cut out. I don't know what this means for an otherwise stock car since we are both on standalone ECUs, mine a Haltech with stock CAN integration.
It is pretty terrible to hear this is an issue in the new gen too.
#56 |
Drives: 2022 brz rr660 -2.8/2 camber
Dont mean to revive a dead thread, but its pretty obvious on the new gen as well and I'm hoping to ID a fix.
So while I don't have a fix. I'm able to replicate every time give exception to cool down laps. It only happens to me while I'm entering a turn where the track is graded downhill [so the majority of the weight of the car is on the front-end] while I'm trailbraking. It happens while I'm turning both right or left and I'm not turning the wheel past 9/3 o'clock [validated by video] and it only happens on the downhillish turns between 70-80mph [via video/gps]. Running a 2022brz, hats/RLCA -2.8/2 camber on 17" rt660s. |
| Steering issue under braking ! | AJ PwR | Tracking / Autocross / HPDE / Drifting | 146 | 04-25-2023 06:47 PM |
| Possible Steering Issue ? | TJB_902 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 06-24-2015 02:38 AM |
| power steering | ender2664 | Engine, Exhaust, Transmission | 32 | 03-21-2015 05:16 PM |
| Steering wheel issue | Khalis | Issues | Warranty | Recalls / TSB | 1 | 05-04-2013 02:19 AM |
| Electric power steering | madfast | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 10-13-2011 11:11 AM |
