Old 05-10-2015, 05:01 PM   #43
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Originally Posted by wparsons View Post
17% is a huge correction factor, that's about the same as the drivetrain losses.
As for the dyno, did you miss my questions above?
What's the boost target before/after the new block? What's the new C/R?
What oil are you running on the new block?
To get the same hp with significantly lower C/R, you're going to need a lot more boost, and it'll spool later in the RPM range.
Sorry I've been busy. I was wanting to run a 20 and 25 psi map. 20 for e50 and lower and 25 for e51 and up. I'm currently at 23 psi at around 4500 as you can see from the dyno. All of these issues started after the new built block. I started running 0w40 motul, this last oil change was 5w30 purol. Here soon I'm going back to the 0w40 but with the purol.
texasbound972 is offline   Reply With Quote
Old 05-10-2015, 05:02 PM   #44
texasbound972
USMC
What's the boost target on both runs? What's the c/r on the new block? If you've dropped a couple points you're going to need a lot more boost to make the same power you were before.
Sorry, c/r is 10.5:1
Old 05-10-2015, 05:04 PM   #45
texasbound972
USMC
We had a run at 25 psi but the hp didn't go up a whole lot. Since the boost spiked like it did, Bill from delicious tuning and Mike at infamous performance figured it would be safer at 23 psi incase I have 91 in the car.
Old 05-10-2015, 05:35 PM   #46
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
The efficency island was probably just south of 25 psi.
Cams Fabron757 Forced Induction 10 01-13-2015 06:30 PM
HKS cams JesseTheFlash Engine, Exhaust, Transmission 4 01-09-2015 07:42 PM
Wtb oem cams midnight23 Want-To-Buy Requests 0 03-19-2014 12:07 PM
Cams? Sonolin Engine, Exhaust, Transmission 10 05-21-2013 10:49 PM
Cams Surok Engine, Exhaust, Transmission 10 01-01-2013 08:30 PM
