Old 05-12-2015, 01:34 AM   #43
Crazypinoy9
Drives: FR-S TRD RS1#1488
didn't need to shave at all. went with 235/40/18 tires,added whiteline camber bolts up front. no rubbing. note that i'm on TRD springs with stock shocks. I didn't have any rubbing issues before the camber bolts either. just wanted to eliminate a little bit of the poke by getting a little bit of negative camber.
Crazypinoy9 is offline   Reply With Quote
Old 05-14-2015, 12:25 AM   #44
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Originally Posted by Crazypinoy9 View Post
I'm pretty happy with the setup so far but will be installing my whiteline camber bolts soon. Am I glad I didn't shave them? well, I really wish the fronts didn't poke out as much as they do. I was hoping to have them tucked without having to use coilovers. But I'm sure the camber bolts will be good enough.
In regards to tires, I got Nitto Motivos. Mainly because I plan to do ZERO track time which means it's only a daily so I didn't need any performance tires. Why spend the extra money if I really didn't need to ya know? FWIW Im very happy with the Motivos right now. super quiet, 60k tread warranty... not bad for $120/tire
Motivo's are awesome tires, i have been running them for a couple years on my first FRS and a Cadillac ATS and no complaints at all. I may try the new Conti DWS 06 this time though. Going to run a similar wheel in 18x9 +35 with Swift springs and 235/40. Hope it doesn't poke too much up front.
JoeBoxer is offline   Reply With Quote
Old 05-14-2015, 06:01 PM   #45
Crazypinoy9
Ya i'm actually loving the motivo's. don't really have any complaints. it shouldn't be too bad in terms of poke. Camber bolts with -1.5 camber up front pretty much too care of the poke i had on my setup.
Old 05-14-2015, 08:47 PM   #46
JoeBoxer
JoeBoxer's Avatar
I ended up going with the new XXR 550 in 18x8.75 +36 so it should be pretty flush. Should have it all installed around this time next week. Really the only reason i went with the Continental was too save just a little weight and its a cleaner sidewall design.
Old 06-23-2015, 10:23 AM   #47
klearfade
klearfade's Avatar
Drives: Scion FRS
Question
I just ordered my forme 9's in this size and I'm going to pick them up next week. Going with that same tire size too. Since I'm already on TRD springs I can update you
Hey I just got my rims in, and Im debating on size. Did you ever try out the 245/40/18 on the springs? if so how did it turn out?
NVM I READ YOUR POST IM SORRY
Just here to learn.......and laugh
klearfade is offline   Reply With Quote
Old 07-10-2015, 03:11 PM   #48
Jaydawg86
Drives: 2015 Scion FR-S
Originally Posted by ZX88 View Post
Installed mine last week.
18x9.5+34 with 225/40/18s
Suspension: swift springs (stock camber - whatever from the drop)
Front poke is pretty narley but I have zero rubbing issues. Definitely need camber bolts or coil overs to get the fronts to look good.
Did you have to roll your fenders? I plan on doing the same set up, just hoping I didn't have to do any fender work
Jaydawg86 is offline   Reply With Quote
Old 07-10-2015, 06:16 PM   #49
Matey
Drives: Pearl White BRZ
Pretty much about to ask what he asked. I don't want to do any fender work (I'm doing literally everything myself with the exception of putting the rubber on the wheel)
Matey is offline   Reply With Quote
Old 07-10-2015, 06:22 PM   #50
thien
Drives: Scion FRS
I have 1 inch drop from springs running 18x9.5et35. I had to run 215/40 front and 235/40 clears no problem. I had 225 in the front and it didn't rub when sitting. It will probably rub off I hit a bump though lol. No fender work done or camber or anything like that.
Sent from my SM-G920T using Tapatalk
thien is offline   Reply With Quote
Old 07-11-2015, 01:02 PM   #51
Jaydawg86
Do you have any more pictures? Thanks for all the info btw
Old 07-12-2015, 11:49 PM   #52
thien
Drives: Scion FRS
Size:  62.7 KBName:  uploadfromtaptalk1436759318666.jpg
Size:  48.9 KBName:  uploadfromtaptalk1436759366818.jpg
Old 07-12-2015, 11:50 PM   #53
thien
Drives: Scion FRS
More pics on my IG if you wanna look. 86_shaomai.
Old 07-16-2015, 06:07 PM   #54
ZX88
ZX88's Avatar
Drives: 22 BRZ
My fronts are rolled the rears are stock. I did notice that my tire is rubbing the front fender well alittle. Im not to worried about it since ill be able to add some negetive camber with coilovers. Under normal driving conditions its totally fine.
ZX88 is offline   Reply With Quote
Old 07-16-2015, 11:42 PM   #55
shaunieboy77
Drives: gray 2015 scion frs
i just got these exact same rims, was looking for a tire size and type of tire that fit good no rubbing, was wondering what u have? im getting coilovers to eliminate wheel gap btw
shaunieboy77 is offline   Reply With Quote
Old 07-16-2015, 11:58 PM   #56
swarb
Maybe you should learn to read.
Wheel Directory: Volk Racing TE37 18x9.0 +45 Front / 18x9.5 +40 OmegaKnight Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-03-2016 08:09 AM
*** VORDOVEN Forme 9 Wheels - Special Pre-Order Pricing! Only @ Sonic Motor! *** Sonic Motor Wheels and Tires 41 01-07-2015 09:13 PM
Varrstoen ES 1 18x9.5 et34 Fl4t fun Wheels and Tires 9 01-05-2014 08:39 PM
18x9.5 +45 (square) VS 18x9.5 +35 Front 18x8.5 +40 Rear (staggered) Funky Fresh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 05-07-2013 09:52 AM
Wheel Directory: Volk Racing TE37 18x9.0 +45 / 18x9.5 +45 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 09-04-2012 12:25 PM
