Old 08-12-2014, 05:18 PM   #43
@midnight23 are you having oil temp issues? We only really have problems canyoning or tracking...
Old 08-12-2014, 09:44 PM   #44
sw20kosh
Drives: 2013 Black FR-S
I think this is the first public post made about the latest cooling modifications on the car... here's a sneak preview until Ted makes a post.
Looks like a smallish unit. I am guessing the ducting plays a major role in its efficiency? Where does the air escape after going through it? Just the conventional path through the radiator?
Thanks for the preview!
Old 08-12-2014, 10:39 PM   #45
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Yes, PMd
Build Thread
Instagram
Old 08-13-2014, 01:19 AM   #46
Conventional path partially through and partially around the radiator; the stock air guide is deleted, so some of the air can escape around the radiator, but that also allows air to flow through the oil cooler. Basically, about 30% of the air going through the front bumper opening is directly ducted to the oil cooler, so it gets good flow.
It certainly works.
Old 08-13-2014, 11:16 AM   #47
Maximal
Maximal's Avatar
Drives: Dodge Stealth
That brings up a good point...ducting plays a huge role in any sort of temps whether it be coolant or oil. Just throwing a cooler in front of where air goes isn't the same as surrounding it by ducting to really force the air into it.
Maximal is offline   Reply With Quote
Old 08-13-2014, 04:31 PM   #48
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Track Day Update...
We are down at NJMP Today and it's not ridiculously hot ambients.
Hit 275*F Oil Temps again on track after a few hot laps.
Coolant is steady at 195-200*F with the Koyo Aluminum Radiator
MUST GET our Oil COOLER INSTALLED!
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 08-15-2014, 12:56 PM   #49
Boosted2.0
Boosted2.0's Avatar
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
Two of us tried the standard mocal 7" laminova and it performed worse than the 13 row setrab. Temps would increase rapidly when getting on it with no cap in sight.
Interesting. We have used them quite successfully on some big power turbo cars - do you have any pictures / details on your installs? I'm curious what was different in this instance.
Boosted2.0 is offline   Reply With Quote
Old 08-15-2014, 02:50 PM   #50
sw20kosh
Do you use restrictor/plugs in the main channel of the laminova? The cores we received and installed didn't have restrictors.
Here is a DIY thread.
http://www.ft86club.com/forums/showthread.php?t=42511
Old 08-15-2014, 05:40 PM   #51
Are these turbo cars high revving? Are the turbos oil or water cooled?
Old 08-20-2014, 01:10 PM   #52
Boosted2.0
Boosted2.0's Avatar
3S-GTE and 2ZZ-GE - not really "high revving" on the 3S, but the 2ZZs are.
We always use water cooled turbos. I am not a fan of oil cooling only.
Old 08-20-2014, 01:17 PM   #53
Boosted2.0
Boosted2.0's Avatar
No, we did not use the restrictors. I wasn't comfortable with that much restriction to the main engine coolant flow on cars here in Texas.
Old 08-20-2014, 01:34 PM   #54
The reason I ask is because the lower revving engines generally put out less oil heat. Now if you were using a 3SGE BEAMS and adding a turbo, you'd have some pretty major oil temp issues...
Old 08-24-2014, 10:53 PM   #55
cookiesowns
Drives: WRB BRZ Series.Blue
That greddy kit looks yummy. 1 or 2 rads?
I'm definitely considering the jackson racing oil cooler. But I'm debating between an exhaust or oil cooler first.
So far, it looks like I'll do a max of 6 track days a year. My heel toe is slowly getting better, so as time goes on, I'm sure I'll push harder and harder.
@CSG Mike
Will you guys be at the AROSC for Buttonwillow on the 27th and 28th? Would love to see that CR S2000, and your BRZ shop car!
cookiesowns is offline   Reply With Quote
Old 08-24-2014, 10:55 PM   #56
@CSG Mike
Which CR? And which S2000? We have multiple :p
We'll be at Buttonwillow on the 30th.
Do you want to sound fast or keep the oil cool? :p
Should I be worried ? Brooklyn BRZ First-Gen (2012+) — General Topics 8 03-12-2014 01:18 PM
No CEL Should I be worried?? Mr.Jay Issues | Warranty | Recalls / TSB 5 04-05-2013 11:51 AM
a bit worried MontrealFRS Issues | Warranty | Recalls / TSB 7 09-14-2012 07:46 PM
5k oil change, worried about changes.... bloomy116 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 09-11-2012 09:23 PM
Anyone worried about not fitting in the car? budakajana AUSTRALIA 35 06-27-2012 08:55 AM
