#43 |
@midnight23 are you having oil temp issues? We only really have problems canyoning or tracking...
#44 | |
Drives: 2013 Black FR-S
Thanks for the preview! |
#45 | |
dying bird under the hood
Drives: 2013 SWP Limited BRZ
#46 | |
It certainly works. |
#47 |
Drives: Dodge Stealth
That brings up a good point...ducting plays a huge role in any sort of temps whether it be coolant or oil. Just throwing a cooler in front of where air goes isn't the same as surrounding it by ducting to really force the air into it.
#48 |
Track Day Update...
We are down at NJMP Today and it's not ridiculously hot ambients. Hit 275*F Oil Temps again on track after a few hot laps. Coolant is steady at 195-200*F with the Koyo Aluminum Radiator MUST GET our Oil COOLER INSTALLED! -Mike Paisan ![]() Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
#49 |
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
Interesting. We have used them quite successfully on some big power turbo cars - do you have any pictures / details on your installs? I'm curious what was different in this instance.
#50 | |
Do you use restrictor/plugs in the main channel of the laminova? The cores we received and installed didn't have restrictors. ![]() Here is a DIY thread. http://www.ft86club.com/forums/showthread.php?t=42511
#51 |
#52 |
#53 | |
#54 |
The reason I ask is because the lower revving engines generally put out less oil heat. Now if you were using a 3SGE BEAMS and adding a turbo, you'd have some pretty major oil temp issues...
#55 |
Drives: WRB BRZ Series.Blue
That greddy kit looks yummy. 1 or 2 rads?
I'm definitely considering the jackson racing oil cooler. But I'm debating between an exhaust or oil cooler first. So far, it looks like I'll do a max of 6 track days a year. My heel toe is slowly getting better, so as time goes on, I'm sure I'll push harder and harder. @CSG Mike Will you guys be at the AROSC for Buttonwillow on the 27th and 28th? Would love to see that CR S2000, and your BRZ shop car! |
#56 | |
We'll be at Buttonwillow on the 30th. Do you want to sound fast or keep the oil cool? :p |
| Should I be worried ? | Brooklyn | BRZ First-Gen (2012+) — General Topics | 8 | 03-12-2014 12:18 PM |
| No CEL Should I be worried?? | Mr.Jay | Issues | Warranty | Recalls / TSB | 5 | 04-05-2013 10:51 AM |
| a bit worried | MontrealFRS | Issues | Warranty | Recalls / TSB | 7 | 09-14-2012 06:46 PM |
| 5k oil change, worried about changes.... | bloomy116 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 09-11-2012 08:23 PM |
| Anyone worried about not fitting in the car? | budakajana | AUSTRALIA | 35 | 06-27-2012 07:55 AM |
