Old 06-12-2012, 05:27 PM   #43
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
Originally Posted by K2 View Post
I'm using a USB flash drive, one of these little monsters:
http://www.ebay.com/sch/i.html?_nkw=...rive&_osacat=0
The little door over the dash plug doesn't close completely over it but you can hardly tell it's there. It looks like the door just isn't snapped shut. And 32G holds plenty of road music.
I have one of these. The problem is I need my playlists. Folders are nice, but if you have to duplicate files just to have the same file in two folders, well eventually you're gonna chew up space fast.
MmmHamSandwich is offline   Reply With Quote
Old 06-12-2012, 05:33 PM   #44
Jayde
Jayde's Avatar
Originally Posted by jdrxb9 View Post
FYI, I got the 7cm 'iStubz' and found it to be too short to nicely reach a 4th gen ipod nano in the cubby.
I added one of these: http://www.angledcables.com/usb-20-e...le--4-inc.html and it is better, but still not perfect.
I also think the re-route suggested by sure74 sounds like a good idea.
Might give that a try, but I've just been using bluetooth to stream music off my ipod touch. No cables involved!
Jayde is offline   Reply With Quote
Old 06-14-2012, 05:10 AM   #45
OrbitalEllipses
Drives: Attitude
I could probably find this information, but someone help me out: does the BRZ headunit play .FLAC files? Ideally, I'd stick a bunch of them on a USB stick and just set/forget.
Old 09-15-2012, 11:15 PM   #46
D-VO
Drives: Whiteout FR-S, Evo 8 RS
Can't get mine to work. =( I wonder if it needs a driver loaded on the tumbdrive...
D-VO is offline   Reply With Quote
Old 09-15-2012, 11:23 PM   #47
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
No driver needed. Does your thumbdrive have a light on it? Do you see the light flash when plugged into the car?
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 09-17-2012, 02:38 AM   #48
D-VO
Nevermind; It sorted itself out. I had to plug it in a few times to get it to work. Thanks.
Old 11-07-2012, 09:10 AM   #49
Ingen
Drives: Ultramarine FR-S 6MT
Thread back from the dead for the following:
i got a new flash drive to use with the stock stereo and 90% of it works great. A few songs, for some reason, will only play back in slow motion while the rest of the tracks play back at full speed. The distribution of which ones are messed up seems pretty random.
Anyone have any ideas on this one?
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 12-29-2012, 12:47 PM   #50
jared_of
Drives: FR-S Firestorm
I have a question about playing from USB drive too. When I select a folder to play, I can't figure out how it sorts. It doesn't seem to do it alphabetically on file name or track name. Doesn't seem to do it based on any of the id3 tags or on file size. Is anyone else having this problem?
jared_of is offline   Reply With Quote
Old 12-29-2012, 02:13 PM   #51
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
It's sorted however you have the sorting set when you look at the drive on the computer. At least it does for me, there are about three folders on mine that are set to alphabetical order and that's how they play, while others are sorted by track number.
Sent via telepathy
Parting out HERE
Old 12-29-2012, 03:06 PM   #52
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
Sent via telepathy
check my thread on USB Audio Fixes. it should help you guys sort your files as you'd like: http://www.ft86club.com/forums/showthread.php?t=17141
mezdup is offline   Reply With Quote
The Following User Says Thank You to mezdup For This Useful Post:
Dadhawk (01-06-2013)
Old 01-02-2013, 09:15 PM   #53
jared_of
Thanks! I'll try it out. This seems really strange to me.
Old 01-03-2013, 10:32 PM   #54
RMStringer
RMStringer's Avatar
Drives: Scion FR-s Pearl White 6 Speed
Send a message via ICQ to RMStringer Send a message via Yahoo to RMStringer
I put in a UBS hub. I used my 64gig and then a 32gig USB drive in the non-powered hub and it would only read 1 usb stick.
RMStringer is offline   Reply With Quote
Old 01-03-2013, 10:46 PM   #55
BRZnut
Drives: BRZ DGM Limited
Has anyone noticed this...playing USB in randon, then go to am or fm radio, then back to USB and it won't play unless you select a new folder?? Mine does this and not sure in normal or not.
Old 01-04-2013, 01:42 AM   #56
Squishy
Drives: 2013 WRB BRZ
You answered your question with the bolded part.
The USB port only sends out enough power for one device comfortably. I doubt it can be consistent on what will be seen if too much is drawn from the single usb connector. You need a powered hub for more than 1 USB device to work properly and even then I would rather just use one big USB device as I do not see the radio having the logic to pick between usb devices - so probably not a good idea to use the hub.
Squishy is offline   Reply With Quote
The Following User Says Thank You to Squishy For This Useful Post:
RMStringer (01-04-2013)
NAV Radio suggestions Dadhawk Electronics | Audio | NAV | Infotainment 20 07-31-2013 02:25 PM
Aha Radio in the Subaru BRZ Chronogps BRZ First-Gen (2012+) — General Topics 3 02-21-2012 05:52 PM
Aha Radio Streaming to BRZ borge12 BRZ First-Gen (2012+) — General Topics 25 01-18-2012 09:47 AM
does this car get a radio/CD player ? beirouty Electronics | Audio | NAV | Infotainment 12 12-03-2011 11:06 PM
No AC/Radio option? blur Scion FR-S / Toyota 86 GT86 General Forum 53 04-10-2010 06:54 AM
