Old 04-09-2014, 11:16 AM   #43
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by HSayaovong View Post
Wait, I can't seem grasp this... by apply change evenly across a section of the maf scaling table..wouldn't this create skewed and inaccurate result?
I.e reducing from 1.16v to 1.7v down .03 would have more of an impact on the lower voltage then on the lager one wouldn't it?
So by tackling each given voltage column and adjust each one to the ltft readout should yield greater accuracy shouldn't it?
Please advise. Thanks
An example, if you reduce every data point to 97% of it's original, the curve will remain the same shape but it will be smaller. The whole point of what I was trying to say is that the end result should ideally be a curve. Going and adjusting each point individually isn't the right way to do it.
Here's an example of what I mean, this is my S/C car on an earlier MAF revision. This is % change from stock scale:
You can see that it slowly increases. If that line was all over the place, which it would be if you did every point individually, then the MAF curve will be all jagged and not smooth which isn't ideal. There will always be some error, there are other ways to get around those once you start looking into it. Remember that MAF scaling is a starting point, not the way to cure everything.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-09-2014, 11:44 AM   #44
HSayaovong
HSayaovong's Avatar
Drives: blk;2dr;rwd;fun
From the looks of it, maf scaling would be so much easier to dial in if we could see the affects from the changes in real-time and not just from loggs.. 15mins of adjustment in real-time would probably be equal to months worth of logging.
Anywho. Another question. If I'm only doing minor timing advancements and from the afr And fuel trim readout the affects looks minimal at the worst case scenario.
Is it safe for me to assume that it's okay to not chase after 0%ltft, besides, when i have something like a steady+ or -3%ltft and a +/- 3%stft the ecu have already compensated for the long term Rich or Lean automatically and as long my stft isn't going nutts it should be considered stable.
Life is like taking a dump, sometimes it's easy and other times its hard. But it always stinks
HSayaovong is offline   Reply With Quote
Old 04-09-2014, 12:02 PM   #45
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by Kodename47 View Post
The thing is that there is a lot of information already on the web. The Romraider lot have been doing Subaru ECUs for years now and most of the way our ECU works is on their site. There's a few minor changes, namely the fact we use PI and DI and that info is already posted here. I could create a thread, but it would just be links to RR or NASIOC.
This statement is why beginners like me need posts from experienced tuners.
Even if the post is nothing more than "to learn about such and such, read this excellent post from NASIOC but be aware that this and this are different on the twins." and what those differences mean.
That last bit is critical in some cases and not all of us have the collected knowledge to know these things.
Old 04-09-2014, 01:15 PM   #46
Tromatic
Very few people will give away their ideal fuel and ignition maps it seems at the moment and would you risk running someone else's maps anyway?
The way I see it, Google is your friend and have a deep look around what's around already with Subaru ECU information. If you have any questions then ask.... That's exactly how I learnt. Read info, compare maps which will inevitably lead to more questions which you then research. I found it quite satisfying.
I'm talking about a very basic, simple, start to finish how-to. All of the documentation that exists assumes you already know what you are doing. The OFT tablet itself is stone-simple, it's everything else.
Tromatic is offline   Reply With Quote
Old 04-09-2014, 02:10 PM   #47
shif7i7down
Erected Member
Drives: frs
I believe the lack of step by step tutorials on tuning efi engines like the fa20 is due to the fact that for people that knows how to tune, tuning is their livelihood and all information and knowledge that the tuners have are all proprietary information that they will not give out freely.
If you really want to learn, go buy a cheap Honda civic for 2grand and practice tuning the crap out of it.
It hurts less to destroy a 2g car the it does to destroy a25g car.
Just my .002
shif7i7down is offline   Reply With Quote
Old 04-09-2014, 02:57 PM   #48
Tromatic
Just my .002
Man, I'm not asking for proprietary info or secrets. I'm asking about a basic guide for beginners on how to use the various tools available. Yes, there is info on the web, but none of it aimed at stone-beginners starting from scratch.
Maybe I have to write the fucking thing.
Old 04-09-2014, 08:06 PM   #49
HSayaovong
HSayaovong's Avatar
My thoughts exactly, that's why I'm doing this "Basic tuning procedure" thread, you are welcome to join in with your findings. I hope to be able to learn enough to not destroy my engine at the same time to also provide layman's instruction to others that may want to follow in my footsteps.
Old 04-10-2014, 03:09 AM   #50
Kodename47
Kodename47's Avatar
Drives: UK GT86
3/4 months ago I was in the same boat as you lot but I took time to go and look into as much info as I could.
The problem with a basic tuning procedure is that everyone likes to have a different approach. What I like to do may not be the best way, but it works for me.
Go here:
http://www.romraider.com/forum/viewt...hp?f=33&t=5299
Direct Link - https://sites.google.com/site/asubie...gguide/ver-1-0
Then look through this:
http://www.romraider.com/forum/viewforum.php?f=33
Then read some of this:
http://www.ft86club.com/forums/showthread.php?t=30418
http://www.ft86club.com/forums/showthread.php?t=57279
http://www.ft86club.com/forums/showthread.php?t=53064
Have a trawl through that. The How To section on Romraider is pretty good as there are a lot of newbie questions on there.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 5 Users Say Thank You to Kodename47 For This Useful Post:
HSayaovong (04-10-2014), mid_life_crisis (04-10-2014), steve99 (04-10-2014), Turdinator (04-10-2014), Yobiwan (04-10-2014)
Old 04-10-2014, 07:06 AM   #51
HSayaovong
HSayaovong's Avatar
Thanks for the the links. Will definitely follow in your for steps and go through them.
Old 04-13-2014, 11:52 PM   #52
phrosty
The CL scaling howto mentions logging A/F Correction #1 (AFC) and A/F Learning #1 (AFL). Are these STFT and LTFT respectively?
So the basic idea, after filtering out any bad records, is that adding STFT and LTFT will give a percentage to adjust the grams/sec under the record's corresponding voltage bin?
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 04-14-2014, 02:16 AM   #53
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Yes, and yes.
Td-d is offline   Reply With Quote
The Following User Says Thank You to Td-d For This Useful Post:
phrosty (04-14-2014)
Old 04-14-2014, 02:52 AM   #54
Kodename47
Kodename47's Avatar
Drives: UK GT86
It really is that simple, you just need to know how to read the data and what to do with it. In CL don't go and change each value individually, look for trends. Try and adjust as much as possible as a flat value. General thoughts seem to be that you would rather it be slightly negative than positive.
If you don't know what to do, feel free to post graphs etc.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
Old 04-14-2014, 10:48 AM   #55
phrosty
Excellent. I've made an app to automate it for me -- even better than the linked howto because it properly interpolates between bins. If anyone is interested I can make it a little more user-friendly and throw it up on a webpage.
Old 04-14-2014, 11:14 AM   #56
shif7i7down
Erected Member
Drives: frs
Sounds like something that can be created in excel, and all you had to do was paste in your logg files.
Which would be awesome if someone with the excel technical know how could make one. And share it on here
Best Break-in Procedure xantonin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 198 02-11-2015 04:40 PM
Visual Basic and SQL Trashed675 Off-Topic Lounge [WARNING: NO POLITICS] 10 06-10-2013 12:18 PM
dyno numbers based on break in procedure. EZWood Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 06-09-2013 08:32 PM
Fr-s Break in procedure. Ontariofrs Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 03-14-2013 07:14 PM
Winter storage procedure wbradley DIY (Do-It-Yourself) Guides 20 10-31-2012 12:49 AM
