Northern California NorCal
Old 09-13-2020, 08:36 PM   #43
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
Originally Posted by norcalpb View Post
Very clever! On my install I needed to remove the entire shifter rod to get a good hammering position on the other side of the pin, but once the whole shifter is out you can easily move the reverse contraption up and down.
If I didn't suck so bad at hammering and using foreign objects as a "punch", I most likely would've had to do what you did.
Oh dude, this is a job where using the right tool is everything! I initially tried using an Allen key...just ended up bending it. Lol!
Gave up, went to Ace Hardware and bought the appropriate size punch. I also used the below setup the brace the shifter against the dash, including rags so it wouldn’t scuff anything.
Bastard came out in LITERALLY less than 5 seconds after that.
Victory was mine, until I screwed it up and dropped the reverse cable.
BlueWhelan is offline   Reply With Quote
The Following 3 Users Say Thank You to BlueWhelan For This Useful Post:
norcalpb (09-14-2020), Ohio Enthusiast (09-13-2020), Wally86 (09-14-2020)
Reverse lockout rattle fix clintavo DIY (Do-It-Yourself) Guides 24 06-17-2020 12:27 PM
Raceseng reverse lockout installed OICU812 Cosmetic Modification (Interior/Exterior/Lighting) 22 08-05-2015 10:33 AM
FS: Beatrush Reverse Lockout TONY_BRZ Interior Parts (Incl. Lighting) 10 05-15-2015 12:04 PM
Beatrush Reverse Lockout Lever simpleisbest Cosmetic Modification (Interior/Exterior/Lighting) 37 04-16-2015 11:19 PM
Reverse lockout vibration SubaSteve Issues | Warranty | Recalls / TSB 4 03-23-2013 02:26 PM
