Old 10-29-2013, 03:10 AM   #1
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Raceseng reverse lockout installed
I have Racesengs full pulley kit and this little gem "Reverse Lockout"
repeats their commitment to quality. Of course this is a cosmetic item more then anything and to me, the feel is just great as well being metal versus plastic.
You will need a 3/32 punch to remove the stock roll pin and a small hammer. I did this myself not difficult. However if you had a lending had to hold the wire carrier (below main boot) it would help a ton. Took me over a half hour cause I was fiddling trying to get the carrier up and weird angles to hold it to be able to insert the included threaded bolt for the Raceseng RL to hold & go throuhg the wire carriers top hat. Overall a nice piece, great finish and a just a great touch up piece for the interior to IMO. One last bit of advice is before installed Raceseng lockout, put some grease inside bore to keep friction minimal against the plastic sleeves riding inside the lockout.
Old 10-29-2013, 07:51 AM   #2
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Now you just need a drift knob.
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 10-29-2013, 10:49 AM   #3
tennisfreak
Drives: 2018 BMW M240i
Without the knob your lockout looks lonely
Old 10-29-2013, 10:52 AM   #4
husker741
I want to get the Beatrush one in red. Mainly cuz it doesn't have a huge "R" on it, and it's like 20 bucks cheaper. Thanks for the info on how to install. I heard you have to have guts to hit it hard enough.
husker741 is offline   Reply With Quote
Old 10-29-2013, 11:43 AM   #5
robot
There are now 2 carseats!
Drives: 2013 DGM BRZ
Agreed. I'd want a non-branded one.
robot is offline   Reply With Quote
Old 10-29-2013, 03:16 PM   #6
tennisfreak
They make the 86'er. Its beautiful with an 86 logo instead of the R
http://ft86speedfactory.com/raceseng...b-mt-1103.html
http://ft86speedfactory.com/raceseng...b-mt-1102.html
Old 10-29-2013, 03:31 PM   #7
husker741
Originally Posted by tennisfreak View Post
We're talking about the reverse lockout, not the shift knob.
Old 10-29-2013, 03:53 PM   #8
OICU812
Just a dude
OICU812's Avatar
I understand why some do not want or wouldn't want the branding, to me no biggie. I got all their pullies under hood all marked etc, etc..
Just had not seen any threads or mentions of the lockout so thought to share was all.
Old 10-29-2013, 10:15 PM   #9
swift996
swift996's Avatar
Subtle and I like the black, I might have to do this too. I need the STi shift knob as well.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 10-29-2013, 11:07 PM   #10
husker741
I need your wheels in my life.
Old 12-10-2013, 12:01 AM   #11
nyfries
Drives: 14 FRS Whiteout
just installed this, I did it with the shifter in reverse so there is no need to fiddle around trying to lift it up while install the pin. Took a a while to thought of it, end it up shifting it in and out of gear a few times trying to get the pin in (bad idea with the car not on).
Should of had it in reverse from the beginning
nyfries is offline   Reply With Quote
Old 08-08-2014, 05:34 PM   #12
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
This Raceseng Ashiko shiftknob and Reverse Lockout feels amazing!
Jmonty is offline   Reply With Quote
Old 09-03-2014, 03:34 PM   #13
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Bit of a newb question, but what kind of grease do you use for this? And where do you put the grease...just basically all over the inside of the new reverse lockout?
Phaedrus29 is offline   Reply With Quote
Old 09-04-2014, 02:08 AM   #14
OICU812
Just a dude
OICU812's Avatar
Just some basic white lithium grease and on the outer plastic sleeve that will see friction against inner bore of the Rev lockout assembly.
Beatrush Reverse Lockout Lever simpleisbest Cosmetic Modification (Interior/Exterior/Lighting) 37 04-16-2015 10:19 PM
Shift Knobs and our Reverse Lockout Chewie4299 Cosmetic Modification (Interior/Exterior/Lighting) 19 07-28-2013 12:23 PM
FR_S/BRZ Reverse Lockout Lever brzadrian BRZ First-Gen (2012+) — General Topics 20 06-20-2013 04:07 PM
Reverse lockout vibration SubaSteve Issues | Warranty | Recalls / TSB 4 03-23-2013 01:26 PM
Aftermarket Reverse Lockout Ring Available? was385 Cosmetic Modification (Interior/Exterior/Lighting) 9 02-17-2013 02:28 PM
