#43 |
I don't want to derail the thread, but some of the guys in the CSG/RCE suspension thread believe this isn't actually the case with this car, even though it's a strut style front end. It has to do with the geometry of the LCA and strut, where the strut is tilted inward at 15° but the LCA is still level. In order for compression to impose positive camber on the wheel, the LCA would have to swing upward well past 15° to be 90° square relative to the strut. Until this point, it gains more negative camber.
#44 |
AKA Mugen Dom
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
Thats good practice, but really only need a line, not really 2. We use Torque marks on Aircraft and other important stuff.
#45 |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
So is this just a single user, single incident thing? Sounds like it.
| The Following User Says Thank You to fooddude For This Useful Post: | SLICVIC (02-07-2014) |
#46 |
Drives: 2JZ FRS
I run OEM camber bolt in the top hole, spc camber bolt in the lower hole. Both setup for Max negative camber. Its been about 8 months without any movement. I just checked today actually while I had the wheels off. I have ground control street series coilovers and neither hole is slotted. So my case is a little different but the info may help others
#47 | |
Glorious BRZ Master Race
Drives: Subaru Libird
That said, there are ways to make the 14mm OEM camber bolt work better as I've listed in my previous post.
| The Following User Says Thank You to switchlanez For This Useful Post: | CSG Mike (02-06-2014) |
#48 | |
You mean 1(as in yourself with this problem)/x-users, no? x = the rest of the frs/brz users using oem crash bolts on slotted/oversized holes. ie: if there were 500 using the oem crash bolts and 1 reported slippage problem so far, it would actually be 1/500 = 0.2% failure rate.. or, until more people claim they are having the same problem. |
#49 | |
Could be other things in play. Suspensions that see hundreds of miles on track or autocross won't undergo as many abrupt shocks as on terrible SoCal roads (where I live). Their suspension may see hard forces applied gradually rather than frequent traumatic jolts that jar bolts loose (think impact wrench).
#50 |
Not meaning to be a j*rk...but my point is..you shouldn't tell others not to do something, when you are the only case and when it is a single user incident. It causes major confusion and misinformation.
Torque specs doesn't matter much, because you can easily just increase it; the oem bolts have a high threshhold (even higher than the aftermarket ones from what i'v read). And, an aftermarket bolt is not much different than an oem bolt inside a slotted hole (doesn't rely on the cam lobe anymore since its' in a slotted hole now) in regards to its' friction design and bite onto the strut mount/knuckle. ..these things are marginal; unless you make a fuss about it...and it is only fair to include them in comparison. A poll asking who else has had this problem and whom has not, is the most fair way. And, so far, you are the only one...which is not a "100% failure rate" (sorry and correct me if I am wrong, if someone else has had the problem). Telling others that it is a 100% sure and a 100% failure rate that you will have the same problem if you use an oem crash bolt in a slotted hole.. is kinda like me with a chicken dinner for tonight, telling others that it is a 100% failure rate that you will not be eating a delicious pizza tonight (just because I am not). |
| The Following User Says Thank You to fooddude For This Useful Post: | MaXimus (06-11-2015) |
#51 | |||
I've snapped/cross-threaded/stripped/drilled out enough bolts and tapped/rethreaded enough bolts and holes to learn to avoid future overtorquing mishaps. I've spent enough late night hours undoing installation errors (mine or a mechanic's who didn't follow procedures) to convince me to go by the book. I've also taken a Materials Engineering course and did stress-strain lab experiments and have some respect for torque values. I'm aware they may have some "cushion" for deviation but that becomes a guessing game. When it comes to my suspension, I try not to leave anything to question. Don't want to "hope" it all holds. An STI owner posted: Quote:
#52 |
As I've said ahead of time, "sorry & correct me if I'm wrong..." Thanks for the links of other users with the same problems and all the other info.
My bad for making you sound like hitler, lol
| The Following User Says Thank You to fooddude For This Useful Post: | switchlanez (02-07-2014) |
#53 |
I think I'm going to just use the 16mm stock on the V3 top slotted hole. Should hopefully give enough camber.
#54 |
Drives: 2006 STi
i have BC coilovers which come with a slightly notched top hole, i notched it even more with a dremel and used aftermarket camber bolts i had from my old sti , (i believe they are maybe 12mm) and got around -9 degrees of camber up front. Had this setup since august of last year never any slips. The camber bolts use a special washer with teeth to prevent slipping -
![]() ![]() I didnt torque the nuts by spec just did it by hand as tight as i could , as well as the same on the bottom. i think i noticed on the first pic the washer/nut mark looks like the bolts werent originally tightened down in full Negative , when doing these bolts alot of people have problems when tightening the bolts, they slip when tightening. It makes it alot easier to have someone push the top of the rotor inwards and bottom of the rotor outwards and HOLD while u tighten. Another way, the way i did it, is to use the floor jack and place it right under the hub on the LCA and jack up. This force pushes the knuckle inwards to full max (rather than the theory of applying weight and it pushes full positive) and then tighten bolts. Not sure what happened in your case. Alot of the 240sx and GD impreza guys use this method for camber on mcpherson strut type suspensions. http://zilvia.net/f/chat/422487-max-camber.html Id also like to add that i dont drive my car hard, just cruise around. I know -9 could be a bit much , even for drifting, but just sharing ideas and my experiences
| The Following User Says Thank You to SLICVIC For This Useful Post: | N234 (10-30-2014) |
#55 | |
Drives: N/A
I installed my spc kit last night in the top hole like many others on here while putting my tools away I noticed the instructions said use the bottom hole contrary to the white line instructions that say use the top hole. after searching last night and all morning to make some sense of this it finally makes sense after reading your post. SPC kit is a 14mm bolt for the BOTTOM hole as per the instructions Whiteline is a 16mm bolt for the TOP hole. I confirmed this with part numbers Thanks again Ill be switching my bolt to the bottom when I get home I'm assuming that where you ended up with your camber bolt as well right? Lower hole Matthew
#56 | |
| The Following User Says Thank You to switchlanez For This Useful Post: | mweidner311 (06-27-2014) |
| Camber Bolt Help Please! | ft86Fan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 114 | 02-27-2019 11:13 AM |
| Camber bolt on KW V3 | derek1ee | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-25-2017 11:21 AM |
| slotted upper strut hole | hanabie | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 11-22-2013 10:31 PM |
| Camber bolt help | oofie | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 11-22-2013 01:36 PM |
