#43 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
I like that idea but I am not sure there is room, it is a 19row core so it would hit the rad I bet. I am going to try cardboard fist before the snow to see if that helps then just cut a truck winter grill thing to size. Edit: I also would like to not remove the bumper again. |
#44 | |
Drives: 15 BRZ LTD, 05 FXT
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
#45 | |
Drives: 2015 Steel FR-S MT
My plan was to get the Jackson Racing kit and then order the 200F from Mocal so the oil might have a chance of hitting 212F when pushing it a bit to get the water to vaporize in it. Plus right around 200F is where my oil likes to sit in day to day driving before it gets higher and the block starts heating up the coolant. This is also what I am looking to finish up. Already got the Scan Gauge, just need to figure out a good spot for an oil pressure gauge of sorts in the interior that's not in the way.
17x9 RPF1 wrapped in 245/40 RE-71R = Mo Low Required
#46 | |
Not Bаnned Anymore
@Mishimoto all though they seem to be taking forver to respond which is weird. They are normally really good. On hot days with a 200 thermostat you will probably beable to get 212 just sitting in traffic haah! Yeah my plan "B" is to remove the sandwich plate for the winter :/ |
#47 | |
@boomslang, I plan to do your setup but a friend mentioned that where you placed the oil pressure sensor may not be reliable since this is far from the oil pump.. can you give your opinion on this? thanks!
2013 Toyota 86
Sterling Silver Metallic IG: @pcuerpo.images |
| Cyberstork gauges | ANREX | Cosmetic Modification (Interior/Exterior/Lighting) | 53 | 08-11-2016 06:07 PM |
| WTB: Gauges | AtlasMick | Engine, Exhaust, Bolt-Ons | 2 | 03-29-2013 12:04 AM |
| Ecu and displays/gauges | stockysnail | Engine, Exhaust, Transmission | 7 | 03-02-2013 06:23 PM |
| gauges where the radio is? | J-Money | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 02-05-2013 10:11 PM |
| Gauges | CyberFormula | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 07-24-2010 06:26 PM |
