Old 07-14-2013, 06:05 PM   #43
choi0706
Drives: t
https://www.isma-isaac.be/past/conf/...a2010_0514.pdf
this article may shed some light..
choi0706 is offline   Reply With Quote
Old 07-14-2013, 06:16 PM   #44
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
I can't speak for anyone else, but my crickets have been dying slowly over the course of ownership. I got the car last May, but only have around 8k miles on it. If they do end up going away I will feel even more sorry for people who have been letting dealership monkeys take apart their car for the last year instead of enjoying it
blu_ is offline   Reply With Quote
Old 07-14-2013, 06:43 PM   #45
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
Originally Posted by choi0706 View Post
Choi, nice find but the article discusses vibration reduction techniques to address a DI System ticking, which is normal, not the high frequency chirping; which seems to be in the case of the FT86 a design issue.
mwjcyber is offline   Reply With Quote
Old 07-14-2013, 07:45 PM   #46
Stephens
Stephens's Avatar
Drives: 2013 Scion FR-S - MT - Asphalt
My crickets started within two days of ownership. I always run 93, and I have tried ethanol free to no avail.
The first week I had the car I was picking up a part for another car at my dealership and spoke to the assistant manager in the service department about it. She basically told me what I already knew.
She said that they can order the new pump and install it, but the crickets will ultimately return and that I would be without my car for a day or so for no point.
After getting that confirmation from my dealer I just stopped caring. I don't even notice the sound anymore. I think at this point if it were to go away I would think something is wrong.
To succeed in life, one must go through it with a tenacious fiery spirit of twerk.
Stephens is offline   Reply With Quote
Old 07-15-2013, 12:22 PM   #47
DatApex
Drives: 2013 WRB BRZ Limited
There's already a thread with over 100 pages of discussion on this subject, why do people keep opening new threads? Good lord.
http://www.ft86club.com/forums/showt...=9836&page=105
DatApex is offline   Reply With Quote
The Following User Says Thank You to DatApex For This Useful Post:
strat61caster (07-15-2013)
Old 07-16-2013, 12:00 AM   #48
Nemesis
H. Badger Cares About Him
Nemesis's Avatar
Drives: BMW 335i coupe w/ man.6 spd
normal noise for GDI HPFP.. everyone has it ford/gm/toyota/lexus/mazda/etc.. its more a matter of adding sound deadening..
my ford ecoboost f150 has crickets too..
No. I've owned two direct injection sports cars: 2007 sky redline and 2007 335i. I've removed all "sound deadening" from both cars engines. Which on the sky was made from the same material that lines most hoods and then a plastic engine cover. On the 335i, it's a plastic engine cover with rubber seals on the side. The normal sound of a HP fuel system is a ticking sound, much like a ticking valve. NOT the crickets heard in many YouTube videos. And it certainly doesn't get better or worse with the type of fuel you use. I bought my sky prior to the big fuel change to 10% ethanol. There was a decrease in HP with the new fuel mix, but no change in the noise or the sound of crickets. This was on a turbo 2.0 4 cylinder DI engine created by GMs European division back in '07. So there is NO reason any of you should be experiencing crickets on a 2013 DI engine put together by two engine geniuses like Subaru and Toyota. Personally, I hope they get it fixed for 2014. Anyone that says this is a normal noise, is either inexperienced, or buying-in to the stall tactics the dealerships are feeding them. Don't beat the car for this tiny flaw, but certainly don't dismiss this as normal and delay a fix any further.
Nemesis is offline   Reply With Quote
The Following User Says Thank You to Nemesis For This Useful Post:
strat61caster (07-16-2013)
Old 07-16-2013, 02:04 AM   #49
YDNA
YDNA's Avatar
Drives: Raven FR-S
fuel pump issue? its more like a sound system issue. you arent playing your music loud enough.
YDNA is offline   Reply With Quote
The Following User Says Thank You to YDNA For This Useful Post:
thill (07-16-2013)
Old 07-16-2013, 08:14 AM   #50
kevman_101
Drives: 2013 Scion FRS
I find it funny. I have them too and I don't hear them when driving. Only at a red light and even then, having your radio at regular voice levels, you don't hear them. It's like it's the end of the world for some. If you can't stand it, either get a header and catback or maybe it's time to switch to an electric car.
kevman_101 is offline   Reply With Quote
Old 07-16-2013, 11:39 AM   #51
choi0706
Drives: t
I've seen quite a few DI cars come through my shop.. They all have some kind of noise.. You can google "(insert GDI car here) ticking noise" and you'll see we aren't the only ones.. The popping rear deck is much more annoying than this DI noise..
Old 07-16-2013, 11:49 AM   #52
mwjcyber
mwjcyber's Avatar
You fail. Everyone knows ticking is normal for DI, ft86 is only car with loud chirping.
Old 07-16-2013, 11:53 AM   #53
choi0706
Drives: t
Funny.. However its not the only car that chirps/ticks/clicks whatever you want to call it ..
Old 07-16-2013, 11:56 AM   #54
mwjcyber
mwjcyber's Avatar
Really, show me another car that chirps.
Old 07-16-2013, 11:59 AM   #55
choi0706
Drives: t
Come to houston, my ford makes the same noise.. Impossible to hear inside the cabin, but you certainly hear it outside..
Old 07-16-2013, 12:03 PM   #56
mwjcyber
mwjcyber's Avatar
Who cares about your Ford and your misinformation trying to down play a defect.
Again, show me a link to some other car with chirping, not DI ticking.
The Following User Says Thank You to mwjcyber For This Useful Post:
ITR Expo 2013 - Mid Ohio - Sept 9th/10th 2013 - 2 day HPDE Dave-ROR Tracking / Autocross / HPDE / Drifting 2 03-16-2013 06:13 PM
2013 FRS fuel pump sound MosesFRS Issues | Warranty | Recalls / TSB 9 02-23-2013 09:01 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
White LTD MT BRZ Available South Florida, ETA July 10th Sportsguy83 BRZ First-Gen (2012+) — General Topics 8 07-02-2012 06:46 PM
$135 Track Day @ ButtonWillow Raceway-July 10th in Socal Louie Southern California 2 06-27-2011 03:14 AM
