Old 09-22-2013, 02:25 AM   #43
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
i use channel locks. Just crush the filter, and turn.
bkblitzed is offline   Reply With Quote
Old 09-22-2013, 10:12 AM   #44
Pablitomarrero
Pablitomarrero's Avatar
Drives: FR-S 10 series
Originally Posted by chulooz View Post
Ok, for the men too manly to buy specialized tools and want their oil changed 5 min ago here is your plan.
About 1 1/2 inches down the filter take a long screwdriver and go all the way through her. Your filter now has a handy handle that you can either muscle into release or hammer loose. Youll never need a tool again (assuming youve bought the worth while fumoto valve). Any questions ask youtube and google.
That valve is awesome... I dont know if I can change the oil without actually lifting the car as some have said
Pablitomarrero is offline   Reply With Quote
Old 09-22-2013, 11:12 AM   #45
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by VietnamPhenom View Post
Just get an oil filter plier. Its like $5-$20 at local parts store or even at wal-mart. You get the grip you need and leverage to take off the filter. I'm a mechanic and this is what I use on 90% of the cars for oil changes. Unless its a stupid new Toyota or European car with the stupid canister filter.
I have, and use these pliers. Highly recommended.
Old 10-08-2013, 08:58 AM   #46
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Actually, all cars used to use a cartridge filter inside a metal canister. Spin on oil filters were developed to save labour costs and leaks.
Well designed canister filter housings are good for our environment which is why they are coming back.
Suberman is offline   Reply With Quote
Old 10-08-2013, 09:00 AM   #47
Suberman
Only for removal of a really stubborn filter. Band wrench should be enough.
ALWAYS install the new filter ONLY by hand. ALWAYS ensure the mounting surfaces are perfectly clean of anything but a thin film of clean engine oil.
The Following User Says Thank You to Suberman For This Useful Post:
Calum (10-08-2013)
Old 10-08-2013, 09:05 AM   #48
Pablitomarrero
I usually tighten by hand as much as I can and then proced to give a slight turn with the wrench, about 1/8 of a turn to secure it firmly
Old 10-08-2013, 01:06 PM   #49
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
The proper sequence for tightening an oil filter is to first move it until it's spin tight, and then give it 2/3 to 3/4 a turn. It is also important to use oil or anti-seize on the gasket.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
The Following 2 Users Say Thank You to Gary in NJ For This Useful Post:
Calum (10-08-2013), Pablitomarrero (10-08-2013)
Old 10-08-2013, 01:47 PM   #50
Pablitomarrero
What do YOU know!?
Old 10-08-2013, 05:09 PM   #51
Calum
That Guy
Yes the bolded is correct.
I always use the wrench for removal. Why, you may ask. Because I can. Why would I bother chancing using a strap wrench just to have to climb out from under the car to get another tool
Old 10-08-2013, 07:29 PM   #52
Suberman
You should stop doing this. The flat rubber gasket can be distorted if over tightened. Also, a very tight filter can seize onto the engine.
Using any type of wrench is fine for removing a filter.
Installing a filter should be hand tight only.
The Following 2 Users Say Thank You to Suberman For This Useful Post:
finallyfi (10-12-2013), Pablitomarrero (10-08-2013)
Old 10-08-2013, 10:40 PM   #53
Pablitomarrero
Ill keep this in mind next time I change the oil. Thank you!
Old 10-08-2013, 10:57 PM   #54
joop1987
Drives: 2013 FRS, Raven, Auto
Good thing Subaru doesn't use flat rubber gaskets on their oil filter.
joop1987 is offline   Reply With Quote
Old 10-08-2013, 11:59 PM   #55
SXE10
SXE10's Avatar
Drives: Altezza RS200-Z 6MT
Get a proper cup type tool, they're the best by far.
SXE10 is offline   Reply With Quote
Old 10-09-2013, 01:01 AM   #56
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
Same tool I use effortless lol
BRZtoni is offline   Reply With Quote
DIY ECU removal Hawaiian DIY (Do-It-Yourself) Guides 21 02-05-2023 02:19 AM
Scratch Removal? feldy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 05-15-2014 11:12 PM
Buzzer removal Micene DIY (Do-It-Yourself) Guides 33 03-14-2013 11:51 PM
Does anybody know exactly what filter the injen Sri uses? I want to get a new filter Frsexxxy Engine, Exhaust, Transmission 13 02-19-2013 11:04 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 03:40 PM
