Old 06-07-2013, 04:44 PM   #29
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Originally Posted by Hanakuso View Post
Why not ? I've done it in the past with no problems when I had no tools to remove the oil filter.
Then it wasn't stuck. The problem comes when the filter is stuck and now you have a half-ripped-off filter and an undriveable car.
In any event, there a half dozen good suggestions as to what to use in lieu of a proper filter wrench.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 06-07-2013, 05:25 PM   #30
996garage
996garage's Avatar
Drives: 03' NSX & 13' BRZ 6spd Ltd white
Have any of you guys used one of these on your FRS/BRZ? If so, were you able to get all of the oil out?
The reason I ask is because I've found that this pump doesn't work on some cars due to the way the dip stick tube is routed. (didn't work on my A6, but was perfect on my NSX and Supra)
996garage is offline   Reply With Quote
The Following User Says Thank You to 996garage For This Useful Post:
infinite012 (07-12-2013)
Old 06-07-2013, 05:50 PM   #31
Dezoris
Dezoris's Avatar
I could not get mine off. Took my F350 took the wench and strapped it to filter.
Cracked the fukin block in two. So much torque, could tow boats, mobile homes etc.
Got the filter off end of story.
Old 06-07-2013, 07:42 PM   #32
hushypushy
ビーアールゼット
hushypushy's Avatar
Drives: WRB BRZ '18
Originally Posted by AdamVR4 View Post
So... when I remove the filter, what kind of spillage should I be prepared for? It's been a couple days since I looked at it, is there a tray to catch most of the oil that spills out? I'm not exactly excited to dump oil all over the top of our ~300 mile engine, haha.
It's sitting in a little tray--no need to worry about spilling anything. When you unscrew it, most of it will be already drained out (because it's mounted "upside down") but a little oil will drip into the tray. This car is the easiest/cleanest oil change I have ever done
hushypushy is offline   Reply With Quote
Old 06-07-2013, 11:47 PM   #33
Bt216
Bt216's Avatar
Drives: Scion frs
Mine was stuck too.. I just beat it with a hammer till it came off hhaha
Bt216 is offline   Reply With Quote
Old 06-08-2013, 01:26 AM   #34
VietnamPhenom
Drives: 2013 FR-S WHITEOUT
Just get an oil filter plier. Its like $5-$20 at local parts store or even at wal-mart. You get the grip you need and leverage to take off the filter. I'm a mechanic and this is what I use on 90% of the cars for oil changes. Unless its a stupid new Toyota or European car with the stupid canister filter.
VietnamPhenom is offline   Reply With Quote
The Following User Says Thank You to VietnamPhenom For This Useful Post:
Calum (09-22-2013)
Old 07-12-2013, 01:37 AM   #35
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
i just use fat rubber bands for the grip i need.
mrlewistan is offline   Reply With Quote
Old 07-12-2013, 06:47 AM   #36
Perihelion
Unemployed DIY Ninja
Perihelion's Avatar
Drives: 2013 SWP BRZ, 1983 MB SD300
hehe this thread is still alive. I used my hand actually, I just wanted to make sure I could use force and not break anything
Perihelion is offline   Reply With Quote
Old 07-12-2013, 10:31 AM   #37
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
What would Jeremy Clarkson do????
Yeah, just hammer the living shit out of it
Old 07-12-2013, 10:52 AM   #38
Foobar
SLO NO MO
Foobar's Avatar
Use the force young padawan. Just like we did on your frontpipe/overpipe connection.
Originally Posted by TylerLieberman View Post
...Yeah, just hammer the living shit out of it
Exactly like that!
Old 09-21-2013, 03:31 PM   #39
Pablitomarrero
Pablitomarrero's Avatar
Drives: FR-S 10 series
Hey I lift, I also saw this thread earlier and thought that there were many pansies in this forum. TWIST THAT FILTER YOU BUNCHA AH PANSIEEES!!!
So I changed my oil today.... Had to go to pepboys to get a filter cap... but not before creating a little preassure sore on the palm of my hand. I screamed liked he-man, huffed and puffed, GIRAHHHHHHHHHH AHHHHHHHHHHHH GRRRRRAAAAAHAHAAHAAAJJGGFTT. Even tried a large plumbing wrench and badly deformed that damned filter... nope. Im a pansie. Took .2 seconds to get it off with the filter cap. 5$
Pablitomarrero is offline   Reply With Quote
Old 09-21-2013, 07:51 PM   #40
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
Screw-baru OEM filters are always *stupid* tight. This is my fourth new scooby and it was by far the easiest of the four (I guess the spin on the filter Sumo-giant on the line finally got carpal tunnel, uses his "weak" hand now, lol) but still too tight.
This http://tinyurl.com/ny25a69 has never been defeated... what I've used for last 15 years or so.
Ralph Spoilsport is offline   Reply With Quote
Old 09-21-2013, 08:17 PM   #41
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
First oil change I used an oil filter cap. You can find one at Auto Zone but I think Pep Boys has more to choose from. I would get a sturdy one, not the cheap plastics for they tend to strip. Good luck
Jolaessss is offline   Reply With Quote
Old 09-22-2013, 01:22 AM   #42
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Ok, for the men too manly to buy specialized tools and want their oil changed 5 min ago here is your plan.
About 1 1/2 inches down the filter take a long screwdriver and go all the way through her. Your filter now has a handy handle that you can either muscle into release or hammer loose. Youll never need a tool again (assuming youve bought the worth while fumoto valve). Any questions ask youtube and google.
chulooz is offline   Reply With Quote
DIY ECU removal Hawaiian DIY (Do-It-Yourself) Guides 21 02-05-2023 01:19 AM
Scratch Removal? feldy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 05-15-2014 10:12 PM
Buzzer removal Micene DIY (Do-It-Yourself) Guides 33 03-14-2013 10:51 PM
Does anybody know exactly what filter the injen Sri uses? I want to get a new filter Frsexxxy Engine, Exhaust, Transmission 13 02-19-2013 10:04 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
