#43 |
Kuruma Otaku
Carbon buildup smoothed out some transitions?
Because titanium. |
#44 |
Drives: car
Some variability in the equipment can be expected as well.
#45 | |
Drives: Asphalt Scion FR-S
For clarification, is lift correlated to air velocity? At higher lift (>0.25"), the air is traveling at higher velocity where the clean port shows a improvement as the air pressure moving it is all turbulent. Trying to pull from memory about my Fluid Dynamics course.
#46 |
Drives: GTS 86
So, is it worth it? I would love to have the time and do it myself before i go down the supercharger route!
#47 |
Señor Member
Wow, the exhaust port on the right isn't pretty. For reference, which port is closest to the fire wall?
1974 TA22 Celica
2013 86 GT |
#48 | |
Drives: FR-S 6MT
There was a write up on a scion xD that some engine builder used in his shop for errands and such. They removed the head on the 1.8L Toyota engine to see if they could improve flow and power. They didn't see anything they could do to improve flow thru the heads, valves.. Etc..(within reason). They remarked how well finished and thought out the design already was from the factory. The head already looked custom as it was.. In the old days.. There was always room to improve by cleaning things up or milling something... Not so much anymore.. |
#49 |
dedicated enthusiast
Drives: Surreptitious(AE71), & Grunt(AE95)
The best answer....
The carbon laid down smoothed the passages of the significant edy points. @ .25" lift the carbon became a restriction and so the flow was shut down quickly. Briefly on laminar flow, and golf balls, and why they don't really translate well to automotive porting..... in essence the different is laminar flow and golf ball flight is something measured over longer periods of time. Any golfers here?? Ever hit a golf ball "knuckle ball" a duff... how far does a duff usually go? A golf ball when properly struck rotates between 2000 and 4000 rpm... the dimples "carve" away at the air, and move it to the side.... golf ball analogy and head port flow just have no qualifier. At 7000 rpm the intake valve opens and closes 29+ times a SECOND! Between acceleration, deceleration, the shape of an engine port, and our period of time... laminar flow doesn't exist! This last bit is part of why you can't always trust a flow bench either.... the flow bench is running, testing over a much greater time period then an operating engine. A flowbench is just a tool. It is the operator of that tool, and the other tools in head porting, that must process the information, and work accordingly.
Information is POWER - LEARN the facts!
#50 | |
![]() from this thread - http://www.ft86club.com/forums/showthread.php?p=828393
| The Following User Says Thank You to oldeskewltoy For This Useful Post: | Turdinator (09-29-2013) |
#51 | |
#52 | |
#53 |
Drives: 2007 Impreza, 2013 BRZ
Wow, so much info in this thread! If the heads were to be port matched, would it affect the afr enough to require a tune? That was the case in my buddy's 2006 gti
#54 |
Drives: old
Carbon built up where there was stagnant air in the port. With carbon now taking up that space the air flowed at a higher velocity. Thus letting more air in the cylinder at a lower lift. I personally would like to see how much material could be "added" in the ports in the proper places without dropping cfm.
#55 | ||
Require a tune.... maybe.... but that would be pushing an extreme... Quote:
#56 |
Drives: Moped
| What did you wash/shine/polish/wax today? | tuckdaddy | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 3 | 03-04-2013 08:42 PM |
| Glass polish? | SubarooMike | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 11-08-2012 02:33 PM |
| Port and polish? Extrude hone? | mrha | Southern California | 0 | 07-11-2012 10:54 PM |
| Saving / Re-using polish and waxing supplies? | eikond | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 1 | 06-25-2012 05:25 PM |
