Old 05-04-2013, 03:58 PM   #43
Blake
Drives: Ravin Scion FR-S
I have them installed...just don't know how or where to tap into the wires... :/
I want to tap into the Parking lights & use the blue wire so they can be high or low. Don't know where though??? Also I was wondering if they are high power and then low power when the headlights are on or the other way??
Blake is offline   Reply With Quote
Old 05-06-2013, 06:41 PM   #44
FR-Shadow
FR-Shadow's Avatar
Drives: 2013 Scion FRS
ok if you want to tap into the parking lights then you tap the red wire into the power wire of the parking lights, keep in mind they will only turn on when you turn on your parking lights though.
as for the blue wire, this wire enables the high low function these have. they will be high power when you turn on your parking lights however when you turn on your headlights it will switch to low. To do this you tap the blue wire into the power wire of the headlight.
FR-Shadow is offline   Reply With Quote
Old 05-31-2013, 01:31 AM   #45
myd_lyf_crysys
myd_lyf_crysys's Avatar
Drives: 2013 Asphalt FR-S
I get that when you connect the blue to the headlight that it dims when the headlights are on. But do they come back to full power with the headlights on high beam?
I want to get rid of the cross-eyed look of the DRL's by turning them off at the ECU, which should leave the high-beam functionality in place. Here's what I'm shooting for....
Parking Lights = LED-High
Low beams = Low beam headlight + LED-Low Power (DRL's off)
High beams = Low beam headlight + LED-High Power + DRL-High Power
myd_lyf_crysys is offline   Reply With Quote
Old 05-31-2013, 01:43 AM   #46
FR-Shadow
FR-Shadow's Avatar
I dont think its possible for it to transfer back to high just by turning on the high beams. Someone else more informed on wiring may be able to figure it out but the way its presented currently does not allow that option.
Old 05-31-2013, 11:55 PM   #47
myd_lyf_crysys
Thanks for the quick response! I'll see if I can find the schematics and post it up if I figure it out.
Old 06-25-2013, 03:30 PM   #48
JDM FRS
JDM FRS's Avatar
Drives: Scion FRS(Whiteout)
Originally Posted by howsouknow View Post
Thanks for the DIY! I followed everything except I actually went with what Tylub did and tapped to the parking light wire. Works like a charm, and gives the option that I can turn it on or off.
SOrry bad ipod cam. :P
Soo weird question... doesn't connecting to the Parking Light/Turn Signal make them blink when you turn the turn signal on?
I saw a video of someone with these installed with Switchbacks installed too and it looked like they might have wired it to their Parking Lights as well because when the turn signal turned on the DRL was blinking out of sync with the Amber. Which looked odd to me. Can anyone confirm or deny this?
JDM FRS is offline   Reply With Quote
Old 06-29-2013, 03:00 AM   #49
FR-Shadow
FR-Shadow's Avatar
Can you provide that video?
Old 06-29-2013, 09:31 PM   #50
JDM FRS
JDM FRS's Avatar
I'll try to find it, just have to remember where it was first lol
Sent from my HTC VLE_U using Tapatalk 2
Old 07-01-2013, 11:44 PM   #51
JDM FRS
JDM FRS's Avatar
So I can't find it but I am thinking it was set up with the power to the parking light wire and the blue to the turn signal wire. Which would be stupid and cause the both DRLs to dim when the turn signals were on.
Old 07-04-2013, 03:13 PM   #52
howsouknow
Drives: 2013 Scion FR-S - Whiteout
I tapped it to the "running" wire of the parking lights. I've had it for several months now, no issues with dimming lights or blinking when signal is switched on. And i think the DRL dimming issue only exist if you have LED switchbacks due to its low current draw. Which to me kind of defeat the purpose of these DRLs if u already have switchbacks.
howsouknow is offline   Reply With Quote
Old 07-15-2013, 03:38 PM   #53
Eh-Tee
Drives: 2013 FRS - Asphalt
I always drive with my headlights on and want the LED DRLs to stay on high power all the time. So I'm thinking that the side marker is the best tap source and just want to confirm that the red wire from the kit should be connected to the white wire from the side marker and the black wire connected to any metal body part?
Eh-Tee is offline   Reply With Quote
Old 09-19-2013, 08:55 PM   #54
jdub512
jdub512's Avatar
Drives: Whiteout SCION FR-S
I bought an interior switch separately and will wire the whole thing by tapping into the power mirror connector in the fuse box right behind the driver dash where the interior dimming light botton and trunk release is. Had to buy some extra wire but now I can completely turn the led lights off if I want. I connected the blue wire to the "dash dimmer switch" in the fuse box (also in same area). That way when you flip the headlights on, the dash will dim accordingly and the led dlr's will switch to low power just as the original install called for. I will try to write up a DIY and add pictures for reference.
jdub512 is offline   Reply With Quote
Old 11-18-2013, 09:20 PM   #55
kALMIGHTY
Drives: TRD Ultramarine '13
Reviving an old thread, but if I want these to be on high power at all times, I only need to connect the red wire right? Is there a ground wire somewhere I still need to connect?
Old 11-19-2013, 01:10 AM   #56
kALMIGHTY
Also, where did you get the overlays for the LED's? I'll probably want to go stealth with mine as well.
