Old 09-18-2021, 02:41 PM   #43
gcranston
Drives: 2015 Subaru BRZ Limited DGM
Originally Posted by ZDan View Post
Do you have a sawzall?
And an angle grinder, jigsaw, files, deburring tool, dremel...
edit: and a dark grey metallic rattle can that's close enough for under-hood stuff. Also, I have aerocatch to install, so if there's hood cutting to be done I'd rather do it all in one day.
gcranston is offline   Reply With Quote
The Following User Says Thank You to gcranston For This Useful Post:
ZDan (09-18-2021)
Old 10-12-2021, 04:15 AM   #44
Shoebox
Shoebox's Avatar
Drives: 2013 Subaru BRZ
Oil analysis would tell me what's going on in my engine, which would be good info. I might do it but honestly I'm not that worried.
Adding an oil cooler when it isn't necessary is not "cheap insurance". You're adding some risks, but you're not ensuring you won't have issues. Engines (particularly '13s) have had oiling-related failures while running an oil cooler. The oiling-related problems FA20 engines have had seem to me to be more related to oil delivery rather than oil temperature.
Most common cause of oil delivery issues is dropping oil pressure at high rpm because hot oil has less viscosity. The oil pump design does this no favors. But hey, you know better than the rest of us🤷🏽*♂️
Shoebox is offline   Reply With Quote
Old 10-12-2021, 08:59 AM   #45
ZDan
ZDan's Avatar
Drives: '23 BRZ
For the hundredth time, you choose oil viscosity based on operating temperature, and 30-weight at 275F has the same viscosity as 20-weight at 250F. I wouldn't track this car with no oil cooler, running 275F oil temp, with 20-weight oil.
Clutch pedal - "squishy/squeeky" sound? tanner Engine, Exhaust, Transmission 16 07-27-2017 03:59 PM
Running light "Tail" fuse in foot well keeps blowing **Fixed** paintdude258 Electronics | Audio | NAV | Infotainment 0 04-12-2017 04:59 PM
Who's tired of the "Pedal Dance" and wants to be in real control of their car? FT-86 SpeedFactory Tracking / Autocross / HPDE / Drifting 61 10-01-2015 08:44 PM
Just changed pads and fluid; brake pedal has more "dead space" ryoma Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-13-2015 03:56 AM
Additional "pedal dance" testing. CSG Mike Tracking / Autocross / HPDE / Drifting 55 08-27-2013 04:02 AM
