#43 |
Drives: 17 BRZ
Just made the move from Showas to Sachs and it’s slight different feel. I’d say overall I have more grip and the rear feels a little softer on sharp hard cornering. Front end is still nice and stiff. No confidence or balance lost in the cars ability. The car feels like it went from a more 50/50 approach of comfort and handling to a now mild sporty feel 60 sport/ 40 comfort. I did also install STI springs off a Ts model so that may play a roll in my experience on the rear feel.
#44 |
Drives: '15 BRZ RA
How many miles do you have on the 2015 Showas?
#45 |
Drives: FR-S Whiteout
lets see.. looking at my records I have roughly 30,000 miles and almost 2 years on them. Thats not including the miles the original owner put on it. He said about 2000 miles, but I'm pretty sure that's bullshit.
Intent > Content
cowardice is the mother of cruelty. |
#46 |
My two cents regarding label colors on the shocks: they are 5 of the 7 rainbow colors.
![]() Could it be a scale from softer to harder? Further investigations on Sachs replacement shocks revealed that they use blue label for OEM replacement shocks (Premium Touring) and red label for more stiff versions (Advantage). Last edited by gpvecchi; 04-28-2020 at 05:45 PM. |
| The Following User Says Thank You to gpvecchi For This Useful Post: | solidONE (04-29-2020) |
#47 |
Drives: BRZ 2018
Resistors use coloring for impedance so same way they may represent with two numbers the actual Kg of each spring!
http://www.sysrecon.com/wp-content/u...ColorChart.png |
| The Following User Says Thank You to JIM THEO For This Useful Post: | soundman98 (04-28-2020) |
#48 |
Drives: BRZ 2018
According to resistors impedance scale, my MY17-18 ts springs are Fronts 4,6Kg and Rears 3,7Kg
Hahaha...
#49 | ||
Intent > Content
#50 |
Drives: BRZ 2018
#51 |
Drives: 13 FRS
Which ones should I buy from Toyota/Subaru to give me the 1inch drop but with still good daily driveability? The PP?
#52 | |
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
There is no OEM/STI spring that will give a 1 inch drop. The pinks will yield a 10-15mm drop. Matched with a solid set of dampers and the daily compliance will be more than adequate. Sent from my iPhone using Tapatalk |
#53 |
Drives: 2020 BRZ tS
Right, TRD is the only "OEM" Spring that will give you a 1" drop.
#54 |
| The Following User Says Thank You to BlueWhelan For This Useful Post: | Tcoat (05-16-2020) |
#55 |
Drives: 13 FRS
Thanks, I was leaning towards pro kit anyways. But which dampers are best paired with them? I don’t track, just spirited drives on the weekend.
I want the Showa evolution custom valved damped/spring set but I’d have to order it from Japan. Can bilstein deliver the same performance? |
#56 | |
The bilsteins will be more than adequate. Those get my vote, though if you can find a set of slightly used PP dampers those should match well too. Sent from my iPhone using Tapatalk |
| FS: Performance Package Sachs Springs and Dampers | Desai_N | Brakes, Suspension, Chassis | 3 | 01-15-2020 06:12 PM |
| Looking to purchase 2018 BRZ performance package Sachs | mitama | Want-To-Buy Requests | 0 | 07-01-2019 11:52 AM |
| Sold...2017 OEM Performance Package shocks | 86MLR | Australia Classifieds | 7 | 10-06-2018 12:56 AM |
| WTB: 2017 performance package Sachs dampers | panand | Want-To-Buy Requests | 1 | 03-16-2018 01:57 PM |
| FS; 2017 PP Struts performance package shocks brz | sokol | Brakes, Suspension, Chassis | 3 | 08-30-2017 08:26 PM |
