Old 04-21-2020, 03:30 PM   #1
NateP
Drives: 2016 Subaru BRZ Premium DGM (61K)
Standard Shocks vs Sachs Performance package
Hi all,
Does anyone know how significant a difference the PP Sachs dampeners really make over standard? I believe they were offered starting 2017 as part of the available Performance Package on limited models. Are they a noticeable improvement over the standard or just a slight change?
Thanks!
NateP is offline   Reply With Quote
Old 04-21-2020, 03:54 PM   #2
i8ur911
Drives: 17 BRZ Series.Yellow
IMHO they are too stiff for the street and not stiff enough for the track
Sent from my Pixel 3 using Tapatalk
i8ur911 is offline   Reply With Quote
Old 04-21-2020, 04:10 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I really enjoy them on the PP BRZ. I have a friend with a stock example, it is more crashy over bumps but nowhere near what a poorly sub-$1200 coilovers would be like. I think it's perfection for a street car that sees minor HPDE
Old 04-21-2020, 04:34 PM   #4
N_Raged
Drives: 2019 BRZ Sport-Tech RS
People either love the Sachs or hate them. If you search these forums you'll see plenty of people who couldn't wait to swap out the Sachs dampers for coilovers. The common complaint being that they are crashy.
On the other end of the spectrum is that people have said the Sachs dampers are very comparable to the Bilstein B6. So yes they are firm and have good damping for stock suspension.
N_Raged is offline   Reply With Quote
Old 04-21-2020, 04:50 PM   #5
The Sachs are actually more compliant while offering better control.
They only get crashy when you pair them with lowering springs.
Old 04-21-2020, 05:03 PM   #6
86MLR
86MLR's Avatar
The Sachs in my 2017 felt crashy with the OEM spings.
The suspension was the second thing I swapped, tyres were the first.
The roads here are quite bumpy though.
As with everything, Opinions may vary
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 04-21-2020, 05:09 PM   #7
NateP
When you say "crashy" what do you mean exactly?
Old 04-21-2020, 05:23 PM   #8
Decep
Drives: 2013 FR-S Series 10
Newer models with softer springs are far from crashy. Still firm, sure, but at least the rear doesnt skate around on potholes etc like the 2013 models.
The sachs are good if you can find them for cheap. I wouldn't pay $200+ a shock for em though.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 04-21-2020, 05:54 PM   #9
AngelGT86Racer
AngelGT86Racer's Avatar
Drives: 2013 FR-S, 2007 Acura TL 5AT
I have a 2013 FR-S which had standard shocks for some time.
Those definitely felt a bit overdamped and crashy.
I then switched to PP Sachs when one of my stock Showas started leaking at 65k miles.
My impression of the differences:
The Sachs have a bit more low speed compression, so initial turn in support is improved. The stock FR-S shocks like you would hit the rear bump stops with a higher shock velocity which I feel made the car more tail-happy. The Sachs mitigate this to some extent, also the bump stops are a different color and possibly have a different spring rate range.
The Sachs don't have a ride quality that I feel is leaps and bounds better than the FR-S. They both have a sensation of feeling overdamped, the Sachs maybe a little less so.
Neither is really what I'd call a track-ready shock/spring setup. On bumpy tracks and sticky tires(<=200tw), you will find the available travel is insufficient. On high-g corners with some bumps, the chassis will have some oscillations from that lack of travel. (Buttonwillow's Riverside comes to mind)
2013 FR-S Raven, AutoX/Track/Daily Driver
Build: Angel's Dual Duty FR-S Build
YouTube: Angel Christov
AngelGT86Racer is offline   Reply With Quote
Old 04-21-2020, 06:06 PM   #10
i8ur911
I've never felt that Subaru's suspension tech/tuning was great. Whether on my 06 STi, 11 WRX hatch or the newer WRX/STI, the suspension leaves a lot to be desired.
With that being said, I've been a long time BMW guy so that's my comparison. Not trying to sound like a BMW snob, but I think a lot can admit, manufactures have "chased" BMW for years....whether that's steering feel, suspension tuning, exterior styling, technology, etc, they've WERE the "benchmark" for many, many years (nowadays is different as they've seemed to lost their way).
The non PP suspension, IMO, is better on the street than the PP suspension. The PP suspension is over damped for most street applications (I live in NH). Yet, the PP suspension isn't great on track (very, very few stock suspensions are good on track).
Again, just my $0.02.
Old 04-21-2020, 08:13 PM   #11
with lowering springs, you get a much harsher ride because the damping curves are specific to the oem springs. You typically get overdamped compression and underdamped rebound.
Old 04-22-2020, 01:52 AM   #12
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
Yeah I can attest to this. Got lowering springs on Sachs. Don’t care for the ride at all. Wish I went with coilovers. Lesson learned.
Drifter X is offline   Reply With Quote
Old 04-22-2020, 03:47 AM   #13
LancePower
Drives: 2020 BRZ tS
Which Springs did you go with?
LancePower is offline   Reply With Quote
Old 04-22-2020, 07:55 AM   #14
ZDan
ZDan's Avatar
Drives: '23 BRZ
When test-driving new BRZs back in 2017, I found the PP cars to have noticeably more high-speed compression damping and 7/10ths handling felt more go-kart-like vs. non-PP. The non-PP cars seemed to me to have a smoother ride but still handled great. I really don't think the PP Sachs dampers are "better", just different. At the time I preferred the PP dampers but now I think the harshness in highspeed damping isn't warranted and gets kinda old sometimes. Anyway, I went with the PP primarily for the brakes. I hate changing pads with sliding calipers...
FS: Performance Package Sachs Springs and Dampers Desai_N Brakes, Suspension, Chassis 3 01-15-2020 06:12 PM
Looking to purchase 2018 BRZ performance package Sachs mitama Want-To-Buy Requests 0 07-01-2019 11:52 AM
Sold...2017 OEM Performance Package shocks 86MLR Australia Classifieds 7 10-06-2018 12:56 AM
WTB: 2017 performance package Sachs dampers panand Want-To-Buy Requests 1 03-16-2018 01:57 PM
FS; 2017 PP Struts performance package shocks brz sokol Brakes, Suspension, Chassis 3 08-30-2017 08:26 PM
