#43 |
Drives: frs
#44 | |
You’re* |
| The Following User Says Thank You to Tokay444 For This Useful Post: | Turbo (09-03-2018) |
#45 |
Drives: frs
is there a compromise over a full track coilover absolutely, but the root of OP's problem is changing suspension components and ride height and not aligning the car. I am amazed that he is even able to drive it without any of the nannies coming on constantly.
#46 |
A set of BCs, or anything from that same barrel of junk, is nothing but a compromise. They do nothing well.
I can't believe I'm having to debate people on this. |
#47 | |
How is an alignment going to fix a ride so harsh it's giving the OP a headache? If the car tracks funny, and won't drive straight, then sure it's the alignment, but an alignment isn't going to soften the ride or give it proper dampening.
#48 |
Drives: frs
He fucked up the pre load when installing and never got an alignment, it is bouncy and sketchy to drive because of his installation and lack of alignment. If he took it to a shop had the pre load set correctly and an alignment done OP would probably be completely ok with the coilovers. The fact that this thread is still going and OP hasn’t got an alignment blows my mind.
#49 | |
To me, valving, shock travel and spring rates are all areas that need attention. But then I'm no expert and am basing my veiws from past experience on playing with BC's on a MX5. |
#50 | |
LMGTFY
Drives: 13 FRS, 91 Miata
He had thrown the coils on without checking them first. One of the rear coils had over an extra inch of preload added to it. (not sure how else to word it) That's a ridiculous amount of difference on a single corner. And would definitely make it ride like shit. |
#51 |
My new MCA gear turned up
Coils come with swaybar links for front, traction mod cost extra but well worth it |
| The Following User Says Thank You to 86MLR For This Useful Post: | Tokay444 (08-31-2018) |
#52 | |
Because compromise ®
Drives: Red Herring
I have MCA Reds on my car but would not recommend them on this forum except for in the Australia sub-forum. Why? Because in the States there a gazillion options running from $200 junk items to 10k+ racing dampers with local support. Yeah, that last part. Local support. Last time I spoke to Josh they still hadn't organised a distributor/service center for MCAs in the States and as I've said before you won't appreciate local service until you need it. I mean seriously, why would anyone in the States want to send their dampers back to Aus to get serviced? /rant.
#53 | |
Drives: 2017 ISM PP BRZ
http://www.ft86club.com/forums/showt...=Tein+CSG+Spec http://www.ft86club.com/forums/showt...ins+road+track
Raceseng Circuit Sphere 100 shifter arm, Radium catch can and master cylinder brace, Perrin oil cooler, Vorshlag front camber plates, ACE A350 header & overpipe, Berk catted front pipe, CSGxMXP exhaust, Delicious NA Stage II tune & Flex Fuel
#54 | |
#55 | |
TRACKBREAD
Suggestions on suspension upgrade over BC
This. You can buy ST (KW), Tein, H&R, Tokico for the price of BCs and Bilstein PSS9s for $200 more. Why anyone would waste their money on the Chinese knockoff bullshit that is BC is beyond me. Like I said. Literally buy ANYTHING else. |
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | Tristor (08-31-2018) |
#56 |
The Fail Boat
Drives: CWP S.B.
| Exhaust Upgrade Suggestions | hosfordbrandon | Engine, Exhaust, Transmission | 6 | 03-27-2016 01:47 AM |
| Looking to upgrade rear sway bar, any suggestions? | Str8Ghostin | Tracking / Autocross / HPDE / Drifting | 8 | 02-22-2015 11:40 AM |
| Suggestions for more horsepower! Turbocharger upgrade + more! | forzajuve | Forced Induction | 14 | 04-10-2013 09:51 PM |
| Michelin/Enkei upgrade + more. Community suggestions welcome! | forzajuve | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 03-29-2013 08:14 PM |
