Old 08-27-2018, 01:25 AM   #29
86MLR
86MLR's Avatar
From asking people at track days their replies was look into MCA, with that I've got their Street performance coils and also their traction mod coming to me in the post.
Worth a look, they are in Australia but you can give them a call or message them.
Lots of experience and development have gone into them.
Alot of the quick cars over here are running them in one form or another, lots of options to choose from, they can pick your spring rates or you can chose whatever you feel best suits your needs.
https://mcasuspension.com
Old 08-27-2018, 02:13 PM   #30
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
Took the coilover off the car to try and work with it isolated. Collars are not budging, and the small spanner wrench has bent. Fucking over this. Putting stock struts back on TODAY.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
The Following 4 Users Say Thank You to Lakitu For This Useful Post:
chaoskaze (08-27-2018), Lynxis (08-28-2018), Tokay444 (08-27-2018), Tristor (08-31-2018)
Old 08-27-2018, 04:16 PM   #31
Tokay444
They're much better dampers to begin with.
The Following User Says Thank You to Tokay444 For This Useful Post:
norcalpb (08-28-2018)
Old 08-27-2018, 04:38 PM   #32
dobbrz
Drives: RB v1 FRS
Try spraying with a penetrating oil and then using a flathead and a hammer.
PROPΔGΔNDΔ
DRIVEN TO INFLUENCE
instagram: @andrewdobbie93
dobbrz is offline   Reply With Quote
Old 08-28-2018, 09:23 AM   #33
evomike
Drives: frs
I am just amazed that you have never had this car set up or aligned and everyone is still blaming parts, changing to stock struts is not going to fix this either without going and getting an alignment.
evomike is offline   Reply With Quote
Old 08-28-2018, 09:43 AM   #34
Tokay444
They're BCs. There's no fixing the car with them still on it.
Old 08-28-2018, 10:49 AM   #35
evomike
Drives: frs
you right my car drives like complete shit and is a hazard to the public, just keep ignoring the fact that OP changed suspension components and lowered his car without aligning it. Its totally the parts fault not OP being too cheap or lazy to get an alignment.
Old 08-28-2018, 11:42 AM   #36
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
i think it is something with how your car is setup rather than the coilovers, i have had BC's on my car for 30k miles and it isn't bouncy or floaty at all.
edit: also l;ooked through your build thread has your car even been aligned yet? if it has not been set up properly and aligned changing the coilovers is not going to do a thing.
The alignment won't do much for comfort but yeah this guy is right. I too have BC's and I don't have the bouncing issues you're talking about. Did you preload all 4 corners before install? What is your stiffness set to?
Edit: read the rest of the post. If you wanna go back to stock that's fine, but it does seem like the issue was preload. BC's website does specify that the coilovers do not come preloaded out of the box. Sorry you're having so much trouble bud.
MCTeeJ is offline   Reply With Quote
The Following User Says Thank You to MCTeeJ For This Useful Post:
evomike (08-28-2018)
Old 08-28-2018, 04:36 PM   #37
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
+1 on the Tein Flex A. I don't have CSG spec but I have zero complaints about the Flex A.
N1rve
Old 08-28-2018, 05:50 PM   #38
norcalpb
norcalpb's Avatar
I think this guy as the BC super lows. Most people have the BRs.
Old 08-29-2018, 02:01 AM   #39
86MLR
86MLR's Avatar
I've run BC on my MX5, OK on the track, OK on the street, it's all to do with damping adjustments for intended use, if recall I had them near on full soft for the street, and somewhere in the middle for the track.
That was a few years ago now a quite a bit of Whiskey has gone under the bridge.
TL;DR Play with your dampening settings, start at full soft and adjust from there to dial in your required settings.
From memory I was 2 or 3 clicks softer on the rear IRT the front.
Don't forget to write your settings down and how the car handled at them, it will save alot of time and headache.
Old 08-30-2018, 07:38 AM   #40
Tokay444
Part of the issue with them IS the damping adjustments.
There really isn't any discernible difference in any settings between the two extremes, but if they offered a damper with onlu two clicks, they wouldn't be able to call it, "32 way adjustable!!!!"
Old 08-30-2018, 07:40 AM   #41
Tokay444
Once he's got some quality components on the car, we'll be able to guide him the rest of the way. Thanks bud.
Old 08-30-2018, 08:21 AM   #42
86MLR
86MLR's Avatar
I agree, the only noticable difference I found was near on full soft and somewhere in the middle, any harder and they handled like rubbish, both on or off the track.
They do only cost 1k though, compromises are expected when you buy cheap stuff.
I've learnt alot from them though, IRT paying more for something that actually works well is definitely worth the outlay, both in performance and comfort.
Exhaust Upgrade Suggestions hosfordbrandon Engine, Exhaust, Transmission 6 03-27-2016 12:47 AM
Looking to upgrade rear sway bar, any suggestions? Str8Ghostin Tracking / Autocross / HPDE / Drifting 8 02-22-2015 10:40 AM
Suggestions for more horsepower! Turbocharger upgrade + more! forzajuve Forced Induction 14 04-10-2013 08:51 PM
Michelin/Enkei upgrade + more. Community suggestions welcome! forzajuve Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 03-29-2013 07:14 PM
