Old 07-11-2018, 09:36 AM   #43
celek
Resident Gear Head
celek's Avatar
Originally Posted by Dr. BRZ View Post
I aint gonna pay $600, yeah nope! But I'll pay $200! Now thats a good deal.
The Tilton component alone is $300
celek is offline   Reply With Quote
The Following 2 Users Say Thank You to celek For This Useful Post:
Hyper4mance2k (08-26-2018), soundman98 (08-08-2021)
Old 07-11-2018, 12:23 PM   #44
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
How does this affect the clutch pedal travel? Can the pedal position be adjusted the same as on the stock setup?
tehShirt is offline   Reply With Quote
Old 07-11-2018, 01:42 PM   #45
fika84
fika84's Avatar
Could probably have China make you one for $200 that will fail over and over again.. then the $600 price point might not seem half bad.
I think $600 is a great deal considering the pain that bent forks and jacked up TOB's cause.
fika84 is offline   Reply With Quote
The Following 5 Users Say Thank You to fika84 For This Useful Post:
celek (07-11-2018), Jonsey (07-23-2018), KoreanJesus (04-02-2019), soundman98 (08-08-2021), Ultramaroon (07-11-2018)
Old 07-11-2018, 01:42 PM   #46
celek
Resident Gear Head
celek's Avatar
Nothing was touched in the stock pedal besides removing the helper spring. Everything can still be adjusted if need be.
The Following User Says Thank You to celek For This Useful Post:
tehShirt (07-11-2018)
Old 07-11-2018, 04:36 PM   #47
celek
Resident Gear Head
celek's Avatar
Or depending on the damage
buy a new snout for $86
The New EO TOB for $55
New Fork for $26
Change trans fluid for $40
new Exedy Clutch assembly $200
Spend 2-3 hours of time pulling the trans every time it fails.
Worst failure I have seen to date was a bad TOB jammed and the fork broke the pivot ball out of the Trans case housing. Requiring a new transmission Bell housing case. $420
fika84 (07-12-2018), Joesurf79 (07-11-2018)
Old 07-12-2018, 08:35 AM   #48
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
New Fork for $26
I just went through clutch replacement due to a failed TOB on track, and I can vouch for all of the above needing replacement - the input shaft snout, the fork, clutch assembly.
What I cant agree with is 2-3 hours for pulling and re-installing the trans. For me with no lift, on maxed out jackstands, and a makeshift floorjack converted to trans lift status - it was 8 to 10 hours haha! Full weekend job in 95+ degree 80%+ humidity Houston hellacious summer misery.
$600 to never do it again for a TOB failure? I cant throw the money at the solution fast enough...
Joesurf79 is offline   Reply With Quote
The Following 6 Users Say Thank You to Joesurf79 For This Useful Post:
ermax (07-12-2018), fika84 (07-12-2018), gravitylover (07-25-2018), KoreanJesus (04-02-2019), Pointmutation (08-02-2018), Turbo (07-12-2018)
Old 07-12-2018, 11:59 AM   #49
fika84
fika84's Avatar
New Fork for $26
Son of a biznitch.. looks like I need to do this upgrade.. there are many more track days in my future and I don't want this happening!!
Old 07-12-2018, 12:12 PM   #50
Joesurf79
Joesurf79's Avatar
The crappy part was - after 25K miles on the car, 8K+ of which were track laps, there was still 1/2 a usable clutch wear plate left. The TOB death, when bad enough - kills the input shaft protective snout AND the pressure plate fingers. So in theory - you loose a bunch of clutch life that you should have had because the pressure plate get gacked, while the wear plate is happy as a clam.
Super frustrating PITA.
Old 07-12-2018, 01:41 PM   #51
cfordart
cfordart's Avatar
Drives: 2014 FR-S
Just replaced my TOB (along with pristine clutch components) for $1100 at 60K miles. How much longer will the bearing part of yours last compared with a stock TOB?
cfordart is offline   Reply With Quote
Old 07-12-2018, 02:12 PM   #52
fika84
fika84's Avatar
Are you boosted?
Old 07-12-2018, 02:17 PM   #53
celek
Resident Gear Head
celek's Avatar
A lift and a transmission jack definitely helps. Just slide the trans back and drop it about 4 inches. replace everything raise it and slide it back forward.
Old 07-12-2018, 02:18 PM   #54
celek
Resident Gear Head
celek's Avatar
This is what we are testing right now is bearing life. beating it up.
Drakiv (08-18-2018)
Old 07-12-2018, 02:44 PM   #55
Joesurf79
Joesurf79's Avatar
Are you boosted?
Nope. Bone stock motor wise. Headers and a ectutek tune that went in at the same time as the new clutch (500 miles ago), were the first power related modifications.
The Following User Says Thank You to Joesurf79 For This Useful Post:
fika84 (07-12-2018)
Old 07-12-2018, 06:09 PM   #56
fika84
fika84's Avatar
Damnit.
failure, hydraulic conversion, throw out bearing, tob
TOM'S 2013 JDM Converted for USDM DOT/SAE Approved LED Tail Lights in RED Lense willfong Exterior Parts (Aero, Lighting, Etc.) 0 01-22-2017 05:31 PM
Push Button Install (for BRZ Limited/10 Series/Converted FR-S or BRZ Premium) brz_star21 DIY (Do-It-Yourself) Guides 10 12-21-2016 03:41 PM
Buddy Club Race Spec Coilover Problems on Problems on Problems mpross Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 09-05-2016 12:18 AM
Hydraulic Handbrake ChrisD Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 01-20-2015 11:17 PM
