| Engine Swaps Discussion of engine swaps. |
#43 | |
I Love custom Turbo kits
Drives: Limited BRZ
Very interesting, he is saying everything works. I guess it hasn’t been widely used because most people have swapped other LSs, would be cool if someone showed a video of everything working on the car. I’ll add this information to the OP when I get on a computer
#44 | |
Drives: 2015 FRS
I agree, some video would be awesome! I’ve tried to find some video of it but haven’t found any.
#45 |
Drives: 2013 Brz
Its been over a year with no updates???
My Mrs is still working flawlessly in my 6.2 Brz! Just about to start a 2JZ swap on a 2017 GT86... Ive been assured by ECUMASTER that they have the CAN figured out for everything but the cruise control for now... Any thoughts? New people? New Solutions? Lets revive this thread as swaps are only becoming more popular!!! -Pearl Brz
'13 Brz Drift Build - Junkyard 6.2 LS swap 396whp - CD009 Trans - R200 G35 3.5 diff and axles - Modded knuckles - FA500 Coilovers 10k/6k F/R - RIP FA20
'17 GT86 2JZ Build coming soon!! Last edited by Pearl_Brz; 12-20-2019 at 05:45 AM. |
#46 | |
Drives: 2013 Ultramarine FR-S
unfortunately my MRS has caused a CEL from the beginning. No codes, just a continual light, and it goes into limp mode while turning at parking lot speeds. Not big issues, just slight annoyances. I'm interested if it's just my car, or my device. That being said, switching to a 2jz and I also contacted ECU master. Hoping they are correct and it will just be connecting two of the wires. Wiring Specialties apparently has a new canbus converter/harness coming out for the LS swap into twins. Interested to see if they come out with a 2jz harness. I am an ecu/harness, and bellhousing away from having it in the car.
#47 | |
where did you hear about wiring specialties? |
#48 |
#49 |
I wonder why nobody is doing anything for 24x...
#50 |
More resolution in the crank sensor and newer engine is my guess. Probably just a start, enough interest and they may go to 24x
#51 | |
Drives: 2013 Brz
Im thinking that CEL might just be an issue with your car/adapter or just a fluke! Who knows... Im happy with mine and its staying with the v8 in my car. As for the 2JZ Ecumaster setup, ive heard ther same thing for them... Just plug in 2 wires. As for the Wiring specialties, they are making a cantrolls harness that will basically satisfy the canbus of the car, while using a non canbus ECM such as stock or whatever else. They told me they wont be offering a swap harness yet specifically for Canbus Ecus, all the harness will have the cantrolls module. Sorry for my jumbled up paragraphs haha
'17 GT86 2JZ Build coming soon!! |
#52 | |
Drives: MR2, Sliver BRZ
So, ECUmaster ive talked to them but no one has confirmed yet if it works. It would still need some physical signals. ive asked them if they have a wiring diagram but they dont. they just said it supports canbus. So if someone is making a "box" + a wiring harness is usually a easier solution for most people. Similar to what the pure-automotive guys do. I did a system were you replace the old ecu with a solution then rewires everything to the AC1 connector. Helps reduce wiring needed as it uses the stock fuses and relays. But its still limited on what ecu will be running the new engine. Some ecus allow for example Traction control. older ecus might not. etc...
Always looking to tinker with something..
| It doesn't work!! | Photomikes garage | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 1 | 03-06-2017 01:23 AM |
| Another Backup Cam Doesn't Work Thread | ChrisJ | Electronics | Audio | NAV | Infotainment | 5 | 07-01-2016 10:09 PM |
| Error Code, Nav doesn't work | slyphen | Issues | Warranty | Recalls / TSB | 2 | 12-04-2015 03:37 PM |
| Installs, Service, Maintanance, Repairs, Custom work, Tuning, Dyno Database! | Infamous Performance | Mechanical Maintenance and Tools | 521 | 10-30-2015 11:58 AM |
| USB port doesn't work | brianc901 | Electronics | Audio | NAV | Infotainment | 2 | 08-15-2014 05:40 PM |
