Old 05-10-2016, 09:28 PM   #533
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
Originally Posted by eSOLOR View Post
This just happened to me. I unplugged the OFT while the car was running and got the check engine light. There's no other way of getting rid of it other than unplugging the battery?
Nah it will go away. I did this too and check engine light came on.
I just turn the car off for like 2 mins and turn it back on. Sometimes it takes 2 or 3 tries but it will go away. Always has for me at least
Kronos is offline   Reply With Quote
The Following User Says Thank You to Kronos For This Useful Post:
eSOLOR (05-10-2016)
Old 05-10-2016, 09:49 PM   #534
steve99
or unplug ecu fuse
or use torque android app.
either way ecu will be reset
eSOLOR (05-10-2016)
Old 05-10-2016, 10:28 PM   #535
eSOLOR
eSOLOR's Avatar
Drives: Subaru BRZ
Thanks! It took me three tries.
eSOLOR is offline   Reply With Quote
The Following User Says Thank You to eSOLOR For This Useful Post:
Kronos (05-11-2016)
Old 05-23-2016, 12:08 PM   #536
tdotBRZ
tdotBRZ's Avatar
Drives: 2014 BRZ Limited SWP 6MT
Been running the new stg2OFH tune on my car for a few weeks now just live monitoring data seems to be doing healthy, so decided to datalog it on the track this weekend for few laps and 3rd gear pull (time 17 to 31.2sec in the datalog below).
Mods on the car: Greddy intake (MAF scaled using @steve99 greddy MAF scale guide), Tomei UEL header, Nameless 2.5" Overpipe and Frontpipe, Tomei Type80 catback.
Other slight tweaks to the stg2OFH tune that i did other than MAF rescaling was @Wayno radiator fans tweak and @steve99 tweaks for reduced bogging in low RPM (under 2k) with high load in primary open loop fueling, and throttle response tip-in enrichment from 2.4ms to 1.6ms.
Here's the datalog from the few laps on the track and 3rd gear pull (time 17 to 31.2sec): http://www.datazap.me/u/rebel2010/td...1?log=0&data=1
If @steve99 and @Wayno and any others could please take a look and see if the tune is running healthy, would greatly appreciate it
From what i noticed FBKC is pretty much constantly at 0, IAM is constantly at 1 and never seen it drop below 1. The only thing i noticed which seems a bit weird to me is during 3rd gear pull both FBKC and FLKC are 0 however later on during the laps FBKC stays at 0, but you see some FLKC from 6400-7400RPM, is this an issue?
Sorry for the long post, any feedback is greatly appreciated.
tdotBRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to tdotBRZ For This Useful Post:
Ahsila (05-23-2016), D_Thissen (05-23-2016)
Old 05-23-2016, 12:25 PM   #537
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Looks to be a touch too aggressive for extended track abuse but likely perfect everywhere else.
FWIW the old 91 octane Stage 2 tune I'm using never knocks on the street but gets little blips (-0.65) here and there on track even with 93 octane fuel.
Up to you if you want the slight extra risk of the small-ish FLKC you're seeing on track for the extra performance everywhere else.
The Following 2 Users Say Thank You to DocWalt For This Useful Post:
solidONE (05-23-2016), tdotBRZ (05-23-2016)
Old 05-23-2016, 12:27 PM   #538
tdotBRZ
tdotBRZ's Avatar
The old 91 octane Stage 2 tune I'm using never knocks on the street but gets little blips (-0.65) here and there on track even with 93 octane fuel.
thanks for the fast reply
Ye it's the only time i've noticed any FLKC, but just weird that FBKC is constantly at 0 and IAM is always 1. Using 94 octane btw. Just wondering if it is safe to run with occasional track (2-3 times a season).
Old 05-23-2016, 01:08 PM   #539
D_Thissen
D_Thissen's Avatar
I'd say so man. -0.67 isn't a whole lot of knock. If you want, you could always pull a little bit of timing from those areas and that should help. I wouldn't worry too much though.
Sent from my Nexus 6P using Tapatalk
The Following 2 Users Say Thank You to D_Thissen For This Useful Post:
Ahsila (05-23-2016), tdotBRZ (05-23-2016)
Old 05-23-2016, 01:24 PM   #540
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
It's actually not weird at all. Just means the computer is not recording enough knock to dial back IAM. It's a good thing. I've looked at the new OFH tune's ignition temp compensation tables, and its decently aggressive in dialing back timing for high temps. Looks like you are getting some FLKC past 6400rpm as the engine starts to warm up past normal operating temps (guessing since you are not logging any temps). You can trim back a half a degree or so at a time on the areas of 1.0 load and up from 6400~7200 where you are seeing more than -1FLKC if you want more knock resistance.
Intent > Content
The Following 3 Users Say Thank You to solidONE For This Useful Post:
DocWalt (05-23-2016), D_Thissen (05-23-2016), tdotBRZ (05-23-2016)
Old 05-23-2016, 01:26 PM   #541
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
That's exactly what I'd do. Back down timing a little when it's really hot on track. Best of both worlds.
Old 05-24-2016, 12:26 PM   #542
DarkSunrise
DarkSunrise's Avatar
Tried flashing the new OFH tune on my car:
- JDL catless UEL / OP
- Berk catted FP
- Perrin CBE
Drove 30 minutes on the highway to build some LTFTs, then logged a few pulls.
First impressions are it feels stronger than the old tune I was using (v. 2.074). It appears it's not running as rich as before and there's more ignition timing at the top of the RPM range (previously tapered to 25* at redline, now holds nearly 30*). I do see slightly more FLKC and KC on the log, but nothing alarming so undecided whether I'm going to use this at the track or not.
http://datazap.me/u/darksunrise/ofh-...zoom=4411-5121
http://datazap.me/u/darksunrise/ofh-...1&zoom=229-313
Going to do a few more data logs in the coming weeks and see how LTFT's and FLKC/KC looks.
2022 BRZ Build
2013 FR-S Build
Old 05-24-2016, 01:15 PM   #543
Wepeel
Drives: '13 BRZ Ltd
- Berk catted FP
- Perrin CBE
That pull in the 2nd log seems a little lean? And what was ambient temp?
Wepeel is offline   Reply With Quote
Old 05-24-2016, 01:18 PM   #544
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
- Berk catted FP
- Perrin CBE
Doesn't look bad. Definitely more aggressive and a touch on the lean side. I'd drive it until the LTFTs are fully set and see what the AFR looks like at WOT and maybe add a touch of fuel if it stays that lean (I'd prefer to see it at the command AFR or slightly richer for safety, it's not like we're out there trying to win races and set lap records)
Old 05-24-2016, 02:00 PM   #545
DarkSunrise
Yeah I noticed my LTFT in the 5000-7400 RPM range changed from +1.56 --> -1.56 in between those runs. That would explain why the first run was slightly rich and the second was slightly lean. Most likely my LTFT's are still adjusting. FWIW on the previous tune, LTFT settled around +2 to +3 in that range (and slightly rich).
Ambient temps were 70-75 F. Intake temps were 95-100 F.
BUT I WANT THAT HPDE TROPHY! Hahaha. Yeah I'm thinking the same thing as you, I'll let LTFT's settle and see how things look before June 11-12.
I will say, I'm getting less of that fuel smell around town so that's nice. I wonder if any changes were made to MAF scaling or if this tune just runs leaner for some reason.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
DocWalt (05-24-2016)
Old 05-24-2016, 04:04 PM   #546
renfield90
The Stig's German cousin
Highly recommend you run a higher octane at the track than what your tune was set up for, if at all possible. Extra insurance.
The Following User Says Thank You to renfield90 For This Useful Post:
Just how noticeable is OFT+OFH and stage 2 tune? BBYZILA Software Tuning 58 03-20-2018 11:56 AM
OFT 2.0 Stage 1 93 Tune MurderRider Software Tuning 57 03-21-2016 12:30 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
FA20club.com Turnaround Times On Modified Tune Files FR-S Matt Software Tuning 103 11-13-2013 01:48 PM
So whate does stage 3 tune do? I already have 2 Frsexxxy Engine, Exhaust, Transmission 17 05-14-2013 06:30 AM
