Old 05-13-2013, 09:48 AM   #533
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
I already have decided to go Vortech so thanks to reinforce my decition!!!
kombatlion is offline   Reply With Quote
Old 05-13-2013, 10:18 AM   #534
nix
nix's Avatar
Drives: AVO BRZ
Originally Posted by Supermassive View Post
not like my car which rockets up to 9k rpm and if you aren't careful (and quick) will hit the rev limiter there.
You're running to 9k?
nix is offline   Reply With Quote
Old 05-13-2013, 01:40 PM   #535
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
I can hear the SC winding up when I drive aggressively (windows up). when the windows are down, you can really hear it. My aunt was outside when I got on the throttle down the road and she said it sounds like a jet engine winding up.
This may sound absurd but my only grip about the kit is, it deletes the sound tube.
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE
277hp 93 octane
370hp on E-85
draggin_az is offline   Reply With Quote
Old 05-13-2013, 05:39 PM   #536
Supermassive
Supermassive's Avatar
Yeah my rev limiter is set at 9k.
Supermassive is offline   Reply With Quote
Old 05-13-2013, 08:57 PM   #537
nix
nix's Avatar
Drives: AVO BRZ
Nice. What kind of head work and do you have a link to a dyno?
Old 05-13-2013, 09:19 PM   #538
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I believe he is stock heads.
http://www.ft86club.com/forums/showthread.php?t=27176
He's one of the first Visconti tuned turbo cars.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
nix (05-13-2013)
Old 05-13-2013, 09:25 PM   #539
Amadeus
Amadeus's Avatar
Drives: White MT FR-S
Amadeus is offline   Reply With Quote
The Following User Says Thank You to Amadeus For This Useful Post:
nix (05-13-2013)
Old 05-14-2013, 01:58 AM   #540
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
New update from Gem.
I've got some news
thanks to the header begging me to squeeze more power out of it, I'm wrapping up the tuning of wastegate controller duty cycles at different altitudes. The car drives awesome, theres just no power dip and it pulls to 7000 in all gears, a bit past 7000 in 2nd keeps you 'well seated'. I am trying to get it to run as well at 7000 feet as at 1000 feet
This is mostly in thanks to the wastegate project with Perrin which has been a whopping success and I will baseline the car BEFORE adding WMI, so it will be a redo of my last dyno day that got screwed up by a boost leak etc-in about a week I should have that dyno redone. Creating tables for duty cycles has been a several week ongoing task that precludes any further 'work' since that mishap
Then I'm officially ready to share my next project for June: Factory ECU driven Intrinsically fail-safed WMI tuned, a project thats ecutek and Perrin are making happen.
raising 91 to feel like 93 on both track and dyno using WMI thats factory ecu driven, so boost, timing, everything is run with ecutek, no need for an aem failsafe, ebcs pro works off ecu, and future potential for e85 integration remains one of my intents, and the wmi offers IAT cooling and protection, plus a few ponies
There is a ongoing project about to go into test in weeks ahead using
an Ecutek/Perrin/Howerton joint effort, where factory ECU is controlling WMI
http://howertonengineering.com/produ...ection-system/
http://howertonengineering.com/plastic-tanks/
http://howertonengineering.com/produ...toring-system/
Parts are shipping as we speak, I appreciate all the posts citing interest and am pleased to share my work. I have no intention on returning to the forum as a member, but rest assured I am online reading everyone posts daily. For the record MPG with 3.48 pulley was better than 26.5, with 3.33 was around 25, with 2.85" is 22MPG driving it hard.
Thanks for your interest and support
-Gem
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
The Following User Says Thank You to Hawaiian For This Useful Post:
whataboutbob (05-14-2013)
Old 05-14-2013, 07:39 AM   #541
2forme
Oh gem, wmi doesn't raise your 91 to 93. It moves it well past 93. And practically no one will want the hassle and cost of running that.
Can we just get some consistent test result? Please?
Old 05-14-2013, 08:41 AM   #542
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
I dont think he was implying that WMI will raise the octane level to 93 but rather allow him to get timing where the rest of the country would be able to with readily available 93 octane. Of course running WMI would allow for much more aggressive timing but knowing Gem he is going conservative and just trying to obtain similar results that someone with access to better fuel would see. WMI is probably one of the best alternatives to combat our climate and fuel availability here in the pacific southwest. I can tell you I have been using it for almost 15 years and I have never looked back.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 05-14-2013, 08:53 AM   #543
mad_sb
Drives: 2013 Asphalt FR-S
I may just be harping over terminology but I would argue that he will still need a failsafe trigger device such as the Aquamist DDS3 (http://www.aquamist.co.uk/press/DDS3-v8-web.pdf) or the AEM WMI failsafe gauge.
Even if the Ecu handles the map switch, it still needs to be told to switchmaps, which is the function both the DDS3 or AEMWMIG. That is unless they are going to integrate a flow sensor in with the stock ecu.
Old 05-14-2013, 09:14 AM   #544
2forme
He's looking for the highest numbers to possibly post. No where in any of my many conversations with him, did he mention anything about being conservative. He wants the numbers. That's why he's running a very small pulley and wastegated setup with WMI (which DOES provide knock resistance well beyond 93 octane).
Old 05-14-2013, 09:49 AM   #545
skatery1989
Drives: BRZ Limited
Do you know any of his new numbers lately?
skatery1989 is offline   Reply With Quote
Old 05-14-2013, 09:52 AM   #546
Hawaiian
That guy
Hawaiian's Avatar
He's guessing that he's at 270 because he was having the leak on his last dyno. When he gets new numbers I will post them up.
Ultramarine mt FR-S
P&L stage 1 turbo
Front pipe / Quad Tip Exhaust / Light Weight Race Exhaust / Unequal Length Headers JonMotoring Engine, Exhaust, Bolt-Ons 314 01-22-2016 01:19 PM
Pete's Perrin Vortech build thread Pete Member's Car Journals 91 06-04-2013 02:38 AM
*PHASTEK* Perrin Tuned Vortech Supercharger Install Thread (3 Vehicles, 3 Kits) PhastekSport Forced Induction 425 04-26-2013 11:06 AM
