Old 03-25-2014, 10:19 PM   #519
1Cor10:23
1Cor10:23's Avatar
Originally Posted by Turkish View Post
So I just bought a Samsung Tab Pro 8.4", but haven't purchased a mount yet as I am still trying to determine the best place to mount it. I only intend to use it mounted when I am auto crossing, tracking, cruising certain twisty roads very spiritedly, or data logging. In my daily driving, it will not be used. I was thinking about getting a universal 8-10" suction cup mount and mounting it on my left side of the dash, in portrait orientation, blocking the left AC vent. It would also be convenient if it was mounted in front of the head unit and AC controls, but I am concerned about my hand potentially slipping off the shift knob and punching my tablet. Most people seem to have used the 7" nexus tablet with pretty good success, the larger size makes it a bit of a tight fit. Any suggestions before I go spend more money?
Check out the exogear tablet mount
The Following User Says Thank You to 1Cor10:23 For This Useful Post:
Turkish (03-26-2014)
Old 03-25-2014, 10:42 PM   #520
StuAU
Drives: 86 GTS
Mate this is by far the most popular version of our mounts, easy install and completely removable in one second when you leave the track. http://www.stuggracing.com/Tablet-Mo...let-mount.html.
If you have a want to use a tablet which isn't listed through the website then just get the generic one and but a hard shell case for your tablet, the kit comes with everything you will need to attach the shell and tell you how to attach it.
Most people do hit the tablet when mounted in front of the AC controls, plus it takes your eye down a long way when at the track.
StuAU is offline   Reply With Quote
The Following User Says Thank You to StuAU For This Useful Post:
Old 03-26-2014, 03:47 PM   #521
Tromatic
Does anyone know if the Transmission Temp is working? Torque Scan shows it as an active PID(?) and it receives data but shows the exact same temp as the coolant.
Tromatic is offline   Reply With Quote
The Following User Says Thank You to Tromatic For This Useful Post:
SSchifko (05-21-2014)
Old 03-31-2014, 10:10 PM   #522
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
The mounts I have designed are now for sale. Each set is individually designed for the specific tablet for perfect fitment and easy install. Right now I have sets for 1st gen Nexus 7, 2nd gen Nexus 7, and the iPad mini. 3M tape holds the mounts on. If you want to remove the mounts it takes a good amount of force but the tape doesn't leave behind any residue or marks.
www.gt86mounts.webplusshop.com
[ame]http://youtu.be/9VuvtibvEoo[/ame]
I can change the design of these mounts for other tablets if I get enough interest. So far it has sold very well to the Nexus and iPad mini family.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 04-02-2014, 02:26 PM   #523
Pacific
Pacific's Avatar
Drives: 5 Celica since 1978.Now a GT86
Regarding CARISTA, this work well but with few possibilities.
I don't Know whether is it possible to lock the doors when drive at around 10Kmh. It exist some external plugs which does this operations but no believe accurate for our GT86/FRS/BRZ.
Have you experienced such function.
On the other hand to validate a change you have to buy Pro version, it is not a problem but how do this and what is the complete list of possibilities.
Thanks your advice.
Pacific is offline   Reply With Quote
Old 04-04-2014, 08:39 PM   #524
2thdoc
2thdoc's Avatar
Drives: Scion FR-S
Originally Posted by dsrttigr View Post
I set mine for 0 and 500 for min and max temps, since I have it set for Fahrenheit not Celsius.
Is everything else the same? Eg equation AC-40
2thdoc is offline   Reply With Quote
Old 04-07-2014, 12:04 PM   #525
ToyoburuBRZ
ToyoburuBRZ's Avatar
Drives: Black BRZ
Originally Posted by normancw View Post
Looks great! Any cheaper options for shipping to Canada via USPS (it's $30)?
I just put this mount in my car this weekend. It cost me $45 (US) in total to ship to Toronto - $35 for the parts, $10 for shipping.
I highly recommend this part. It is so simple and looks like it just belongs there.
ToyoburuBRZ is offline   Reply With Quote
The Following User Says Thank You to ToyoburuBRZ For This Useful Post:
calispec (04-07-2014)
Old 04-07-2014, 12:07 PM   #526
ToyoburuBRZ
Drives: Black BRZ
I just got this all set up in my car this past weekend. Is there throttle position sensor that shows the true position of the throttle pedal?
The ones I have gone through so far either show 20% when at 0 and 80% when at full or 0% at 0 and 70% at full.
Anybody know?
Old 04-07-2014, 03:26 PM   #527
calispec
calispec's Avatar
Sorry about that. It should be $10 for shipping. I just fixed the website so you should be good to go.
www.GT86Mounts.com
Old 04-07-2014, 06:45 PM   #528
retrosmiths
Drives: Scion FR-S Whiteout
Anybody know?
AFAIK, it's not possible to get exact throttle (and brake pedal) positions with Torque, but those dedicated dataloggers ($$$) can.
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 04-08-2014, 01:33 AM   #529
TheRipler
Reap the BReeZe
Drives: 04 LandShark STi
Anybody know?
I'm not sure if it's addressable in Torque, but it sounds like you're looking for the accelerator pedal position sensor. There should also be 2 throttle position sensors. One will go from 0-100, and the other will be 100-0.
TheRipler is offline   Reply With Quote
Old 04-20-2014, 07:11 PM   #530
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Edit: NVM, working now.
Kostamojen is offline   Reply With Quote
Old 04-30-2014, 09:16 PM   #531
ML
ML's Avatar
Drives: 13 White MT FR-S
is LTFT and STFT working with torque?
Old 04-30-2014, 09:16 PM   #532
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Yes.
mikalem is offline   Reply With Quote
The Following User Says Thank You to mikalem For This Useful Post:
ML (04-30-2014)
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 05:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-23-2012 12:05 AM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 05:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 02:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 09:23 PM
