#477 |
@troek Well spotted mate, missed that one :-)
Thats is weird it should be like +20 or so something is off @clintavo check your timing tables in your tune. did you do any editing ??
#478 |
Drives: UK GT86
Depends on the situation
Could just be on a cold start...If it's bogging, it could be a few things. AFR or ignition timing, so base timing or transient. Or it could be that FBKC is causing a timing drop enough to be noticeable. IMO just don't boot it from that low RPM. The engine is knock prone at low RPM high load anyway. I really think flooring it below 2.5k is a bit pointless. You never need to floor it that low apart from in 1st and maybe 2nd and then you won't have the issue anyway as you'll fly through the range.
.: Stealth 86 :.
#479 |
Drives: Black 2013 FRS
I too have the bogging problem. I was pulling out of a gas station across two lanes when I noticed a car approaching quicker than I thought. "No problem I thought, I'll just apply more throttle and avoid being in the way." The car basically stopped and bucked across the road, and I was lucky I wasn't t boned.
#480 | |
stock roms in tactrix thread below. Last edited by steve99; 08-13-2014 at 08:57 AM. |
#481 |
Drives: 2012 Toyota 86
#482 |
i just uploaded the stage 2 uel e85 rom. right off the back i can tell its better. the throttle response is a lot more accurate then the 93 rom. i know its still learning but from what i saw while under throttle my stft is around 3-6% and ltft is at 0%. off throttle stft is 0% and ltft is about 14%. i just barely put 9 miles on the car so i know theres a lot of learning for it. cant wait to go wot haha
#483 |
Drives: 2013 BRZ Limited WRB
Running OFT 2.02 91 stage 1, and having a heck of a time trying to get IAM up. Running California 91 gas from Costco - not sure if this is the issue? Anyways, if someone can take a look below, I'd appreciate it.
http://www.datazap.me/u/nocturne1/se...g=0&data=1-8-9 |
#484 | |
Admittedly, flooring it a such a low rpm is rare, but kind of like d1ck said, I was about to get backed into. Flooring it resulted in zero acceleration, and REALLY got my attention. I'll make a log of the bog. |
#485 | |
Drives: JAWS
I think I've seen you driving before! I'm on the 2.01 maps and I only run Chevron or Shell. I've done 5 datalogs and have driven pretty hard on all of them and haven't got the IAM to drop below .78. I think you should run that Costco gas empty and try Chevron or Shell.
#486 | ||
aeiou
Drives: WRB BRZ
After putting on my high flow catted front pipe, the IAM dropped as low as 0.46 at one point on the 91 tune with Shell 91. It now hangs around 0.58. I'm going back to E85 as soon as possible.
#487 | |
#488 | |
#489 | |
#490 | |
Señor Member
1974 TA22 Celica
2013 86 GT |
| OpenFlash Tablet v1.42b maps now available | Shiv@Openflash | Software Tuning | 159 | 09-13-2016 12:29 AM |
| Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 05:23 PM |
| OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted | Shiv@Openflash | Software Tuning | 142 | 07-22-2014 10:21 PM |
| Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) | Shiv@Openflash | Software Tuning | 255 | 02-15-2014 04:43 AM |
| OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 08:45 PM |
