Old 08-13-2014, 05:38 AM   #477
steve99
Drives: FT86
Originally Posted by troek View Post
-10 ignition advance seems a little strange
@troek Well spotted mate, missed that one :-)
Thats is weird it should be like +20 or so something is off @clintavo check your timing tables in your tune. did you do any editing ??
Old 08-13-2014, 05:39 AM   #478
Kodename47
Kodename47's Avatar
Drives: UK GT86
Depends on the situation Could just be on a cold start...
If it's bogging, it could be a few things. AFR or ignition timing, so base timing or transient. Or it could be that FBKC is causing a timing drop enough to be noticeable.
IMO just don't boot it from that low RPM. The engine is knock prone at low RPM high load anyway. I really think flooring it below 2.5k is a bit pointless. You never need to floor it that low apart from in 1st and maybe 2nd and then you won't have the issue anyway as you'll fly through the range.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
lucid215 (08-13-2014), steve99 (08-13-2014)
Old 08-13-2014, 07:26 AM   #479
d1ck
Drives: Black 2013 FRS
I too have the bogging problem. I was pulling out of a gas station across two lanes when I noticed a car approaching quicker than I thought. "No problem I thought, I'll just apply more throttle and avoid being in the way." The car basically stopped and bucked across the road, and I was lucky I wasn't t boned.
d1ck is offline   Reply With Quote
The Following User Says Thank You to d1ck For This Useful Post:
Lytheum (08-13-2014)
Old 08-13-2014, 07:45 AM   #480
steve99
Drives: FT86
Have a look at a srock D00C rom and a modded D00C see if any of the drive by wire throttle tables have been altered, might be another cause of that type of thing
stock roms in tactrix thread below.
Old 08-13-2014, 09:37 AM   #481
troek
troek's Avatar
Drives: 2012 Toyota 86
yeah, i didnt think about that, makes sense too as his rpm is 1300 ish.
troek is offline   Reply With Quote
Old 08-13-2014, 11:18 AM   #482
lucid215
i just uploaded the stage 2 uel e85 rom. right off the back i can tell its better. the throttle response is a lot more accurate then the 93 rom. i know its still learning but from what i saw while under throttle my stft is around 3-6% and ltft is at 0%. off throttle stft is 0% and ltft is about 14%. i just barely put 9 miles on the car so i know theres a lot of learning for it. cant wait to go wot haha
lucid215 is offline   Reply With Quote
Old 08-13-2014, 01:05 PM   #483
nocturne1
nocturne1's Avatar
Drives: 2013 BRZ Limited WRB
Running OFT 2.02 91 stage 1, and having a heck of a time trying to get IAM up. Running California 91 gas from Costco - not sure if this is the issue? Anyways, if someone can take a look below, I'd appreciate it.
http://www.datazap.me/u/nocturne1/se...g=0&data=1-8-9
nocturne1 is offline   Reply With Quote
Old 08-13-2014, 03:15 PM   #484
clintavo
It was a cold start. I have not modded anything in the tune.
Admittedly, flooring it a such a low rpm is rare, but kind of like d1ck said, I was about to get backed into. Flooring it resulted in zero acceleration, and REALLY got my attention.
I'll make a log of the bog.
clintavo is offline   Reply With Quote
Old 08-13-2014, 04:12 PM   #485
JB86'd
JB86'd's Avatar
Drives: JAWS
You live in Foothill Ranch?! So do I I think I've seen you driving before! I'm on the 2.01 maps and I only run Chevron or Shell. I've done 5 datalogs and have driven pretty hard on all of them and haven't got the IAM to drop below .78. I think you should run that Costco gas empty and try Chevron or Shell.
JB86'd is offline   Reply With Quote
The Following 2 Users Say Thank You to JB86'd For This Useful Post:
nocturne1 (08-13-2014), steve99 (08-13-2014)
Old 08-13-2014, 04:48 PM   #486
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
I had the same issue. I was running E85 for a while, with it IAM never dropped below 1.00. After flashing to the 2.0x 91 map, it stayed at 0.88.
After putting on my high flow catted front pipe, the IAM dropped as low as 0.46 at one point on the 91 tune with Shell 91. It now hangs around 0.58. I'm going back to E85 as soon as possible.
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
Old 08-13-2014, 06:30 PM   #487
steve99
Drives: FT86
as the other guy said try different brand of gas you can see the fbkc and flck knock all over the place. Its going to come down to finding a better brand of gass runing better octane fuel, running octane booster or pulling some timing out of the map see links below
Old 08-13-2014, 06:33 PM   #488
nocturne1
nocturne1's Avatar
Yep, pretty darn sure we've briefly seen each other before! Damn, just filled up this morning again (figured it might have been a bad tank before), but I'll certainly try Chevron or Shell. Thanks - see ya around!
Old 08-13-2014, 07:58 PM   #489
Vanilla
This has happened to me twice as well..stage 1 93 oct tune.
Vanilla is offline   Reply With Quote
Old 08-13-2014, 08:31 PM   #490
Turdinator
Señor Member
Turdinator's Avatar
My guess is the cold start routine is causing your issues. Generally speaking you shouldn't floor it during warm up or at such a low RPM. As Kodename47 suggested, full throttle below 2.5k is not a great idea. If you need to accelerate from that low an rpm at least slip the clutch little to bring the revs up. Its not a V8.
1974 TA22 Celica
2013 86 GT
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
