Old 04-28-2017, 12:25 AM   #477
Zer0
Drives: 2015 frs
Originally Posted by all4spl View Post
how does the brake booster delete work? Do you still have abs? I'm interested in doing this.
No ABS . I'm eliminating most none essential functions. Basically turning it into a 1995 RWD basic car with a swap. It will still have power steering and AC
Zer0 is offline   Reply With Quote
Old 04-28-2017, 12:31 AM   #478
Zer0
Drives: 2015 frs
Originally Posted by DustinS View Post
That was the plan. Slot the holes a bit if it doesn't fit. If it isn't anywhere close, I will just have a friend machine one up. How does the car do without the booster?
It will be a while before I know I did that after I sold the engine and trans. Won't know until the swap is completed. It will be documented once I have all the parts. Early next year is my estimate.
Old 04-28-2017, 07:19 AM   #479
M1K3
M1K3's Avatar
Drives: vrooom...
also it looks like the CX racing kit wont work with the sway bar either. according to @Ryaquinn anyways.
It looks like Element Tuning got it to work
As for Ryan he is running a different control arm setup for drifting and that may be the reason why he cannot run a sway bar, image below is pre LS swap:
M1K3 is offline   Reply With Quote
Old 04-28-2017, 09:50 AM   #480
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
@Zero That I know of, without ABS Module, Power Steering won't work. So you will need to come up with a special wiring kit for it.
Everyone I have seen/talked to has been able to keep the sway bar, other than Ryan. Not sure why.
Worked on the car more last night.
Got the tunnel cut. I took a video instead just pictures, but I will toss some pictures I stole from the video until video is finished.
Used Grinder with cut off wheel to make the side cuts, and dremel to make the top cut. Bent it down and used dremel to cut the opposite side top from back side.
[/url]
Cleaned it up, hammered everything down and painted it (not cleaned or painted here)
Stainless Waterpump bolts.
Wired up!
Only issue is that the engine side of the harness is the one that passes through the firewall, so I have to under the harness -_- . Luckily it is really easy. Everything fits the transmission except the Speed Sensor plug, because the Trans uses a ford VSS. I have ordered the pigtail to fix that.
Not sure what the plug on the right goes to. Need to figure that out.
Now the difficult part of the body side of the harness.
Came with it's own Fuel Pump relay
I got the invoice for the rest of the payment for the MRS Canbus device. Excited to get that. I also bought a swivel thermostat housing, hoping it doesn't leak haha.
Looking at the harness and noticed the Back up lights and neutral position wires I left by the trans tunnel need moved. So I have to tear apart the wiring harness and pull those through the firewall. Joy.
DustinS is offline   Reply With Quote
Old 04-28-2017, 11:00 AM   #481
all4spl
doesn't appear to be much room for the heater core lines. How much room is there with the intake cover off? (piece that goes on top of the intake)
all4spl is offline   Reply With Quote
Old 04-28-2017, 11:03 AM   #482
Zer0
Drives: 2015 frs
I kept the electronic section of the abs. I just unbolted it from the aluminum block and tossed that section. Others have kept power steering this way. Once I know how to keep the power steering without that I will be doing a rewire of the entire car from the headlights to the taillights with the race pak smartwire.
Old 04-28-2017, 11:07 AM   #483
DustinS
DustinS's Avatar
That piece doesn't interfere at all with heater hoses. They will need trimmed down a tad, and tight 90 hoses put on. I will get better pictures on my lunch break.
I just got a call the driveshaft is ready, so I will run and grab that at lunch as well
Edit: Ignore the words "ABS Lines" and "Power Killing 90" lol
[ame="http://www.youtube.com/watch?v=RSPwsmrnR_E"]http://www.youtube.com/watch?v=RSPwsmrnR_E[/ame]
Old 04-28-2017, 01:06 PM   #484
all4spl
How about on the other side of the steering shaft? Make the exhaust hug the engine. And honestly get some pie cuts in there and you're good to go. I might do these headers and make them 3"
Old 04-28-2017, 01:25 PM   #485
all4spl
Also you might want to look into the VSS sensor as you might need to switch it out to a GM sensor. Not sure if the voltage range set is the same.
Old 04-28-2017, 01:25 PM   #486
MRS-Colin
Drives: 2001 Impreza 2.5 RS
ABS module is the other termination point for the CAN bus (ECU being the other). A bunch of nothing will work if the CAN bus isn't properly terminated.
Colin Beck
MRS-Colin is offline   Reply With Quote
Old 04-28-2017, 01:28 PM   #487
all4spl
Looking at his picture again. He does infact have a sway bar attached. Its not hooked to the strut though, its hooked to the control arm.
Old 04-28-2017, 01:57 PM   #488
Zer0
Drives: 2015 frs
And that's why I was going to be contacting you.
Old 04-28-2017, 02:09 PM   #489
DustinS
DustinS's Avatar
Driveshaft is in. I really like it, and they were really interested in the project.
Went to slide under the car (which may have been a mistake, the storms have covered the parking pad/driveway in a nice thin coat of mud. Didn't seem to get any on me this time) and found I couldn't get the driveshaft into the transmission. Had a mini-freak out session. I was trying to figure what I did wrong, or if I forgot something. It was hitting the body, but didn't think it was enough. Well it was...
Slight Persuasion upward on this body panel (part the old carrier bearing bolted to) with a small sledge and the driveshaft slid right in.
Checking clearance around the driveshaft and it is pretty tight. Nothing should be an issue except maybe the two center bolts. May remove and cut shorter, or source slightly shorter bolts:
and she is in:
@all4spl Pictures for you.
Edit: All4spl I believe it should plug in a be fine. Everything I have read says it's plug and play, just build a patch harness or repin it. I will definitely keep it in mind though.
Old 04-28-2017, 03:22 PM   #490
all4spl
Thanks buddy Also looking at that picture, why no oil pressure sensor? I know with my corvette, it will go into limp mode / wont start without oil pressure, temp, and level sensors.
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 03:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-21-2015 11:38 PM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 11:14 AM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 07:32 PM
