Old 04-26-2017, 12:41 PM   #463
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
2.5" back to 3" Greddy Exhaust. I may switch to 3" after it clear the subframe and everything in the future, but for right now I have the 2.5" on hand and the welding material for it.
The Following User Says Thank You to DustinS For This Useful Post:
Sportsguy83 (04-26-2017)
Old 04-26-2017, 12:56 PM   #464
all4spl
And you're saying there is no room to put a 3" vband on the header itself? I might need to see a picture to see how close it is to the steering shaft like youre saying.
all4spl is offline   Reply With Quote
Old 04-26-2017, 01:08 PM   #465
DustinS
DustinS's Avatar
I'll get the tape measure out and try and get better pictures if weather permits. If not, it may be tomorrow before I can get under the car.
edit: To clarify, Passenger side can fit whatever you want. TONS of room. The way the driver side header exits, it is extremely tight and not even enough space for a smooth 2.5" bend without a weird bend. I'll probably just get a video to try and show it better.
Old 04-26-2017, 03:31 PM   #466
all4spl
I'm wondering if this is a better option
https://www.summitracing.com/parts/h...FUw2gQodjhkJ6w
You can either have 1 7/8 and 2.5" collector or 1 3/4 and 3" collector with possibly no fitment issues as we all know corvettes have little to no room.
The Following User Says Thank You to all4spl For This Useful Post:
DustinS (04-26-2017)
Old 04-26-2017, 03:32 PM   #467
all4spl
and it looks like you wouldn't have any issues with plug wires on the C6 blackhearts.
Old 04-26-2017, 03:48 PM   #468
DustinS
DustinS's Avatar
Yes I think those would be a good set to go with.
Old 04-26-2017, 04:53 PM   #469
all4spl
a bit more expensive though haha I'm interested in seeing what you come up with.
Old 04-27-2017, 11:27 AM   #470
DustinS
DustinS's Avatar
Storming so I only got a little bit done last night. Wrapped the passenger side manifold. That was a nightmare. Assembled the fuel rails, and the pressure regulator.
[/url]
[/url]
[/url]
Old 04-27-2017, 01:54 PM   #471
DustinS
DustinS's Avatar
Well after drawing up a template for the Clutch Master adapter, I went ahead and ordered the Rywire one. Looked close enough to me and a few friends I trust. Guess we will find out here in a bit.
The Following 2 Users Say Thank You to DustinS For This Useful Post:
all4spl (04-27-2017), Zer0 (04-27-2017)
Old 04-27-2017, 03:26 PM   #472
Zer0
Drives: 2015 frs
[QUOTE=DustinS;2900110]Well after drawing up a template for the Clutch Master adapter, I went ahead and ordered the Rywire one. Looked close enough to me and a few friends I trust. Guess we will find out here in a bit.
If it doesn't fit just right you can machine aluminum with a router. I made a adapter for a Wilwood master cylinder for my FRS to get rid of the power brakes.
Zer0 is offline   Reply With Quote
The Following User Says Thank You to Zer0 For This Useful Post:
DustinS (04-27-2017)
Old 04-27-2017, 03:51 PM   #473
DustinS
DustinS's Avatar
That was the plan. Slot the holes a bit if it doesn't fit. If it isn't anywhere close, I will just have a friend machine one up. How does the car do without the booster?
Old 04-27-2017, 04:12 PM   #474
all4spl
how does the brake booster delete work? Do you still have abs? I'm interested in doing this.
Zer0 (04-28-2017)
Old 04-27-2017, 04:50 PM   #475
all4spl
also it looks like the CX racing kit wont work with the sway bar either. according to @Ryaquinn anyways.
Old 04-27-2017, 05:54 PM   #476
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
@Amir Ghadiri's car was used to design the CX racing kit, perhaps he could clarify about the swaybar fitment?
This is the only picture I could find on his journal that shows the swaybar..
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 03:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-21-2015 11:38 PM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 11:14 AM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 07:32 PM
