Old 06-24-2014, 10:23 PM   #4831
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Originally Posted by DeliciousTuning View Post
Our 69mm pulley should get you a few ponies closer (5-7). We are just finalizing our new tune which will be good for 80-69mm pulley sizes. We are also testing the Innovate supplied belt with the 69mm pulley on our development car and there is no slipping.
Which intake is on your car also? The Airaid one definitely adds a couple ponies also. And how hot was it in the dyno room when making pulls and in what gear was the pull made? This will all have an affect on the final number.
Cheers,
William Knose
Stock intake. I need to do either a DIF or the Airaid. After talking with you the other day, the 69mm might be in my near future. It was pretty warm. Texas heat, gotta love it. About 90ish degrees outside and a bit warmer inside. Pull was done in 4th gear.
Dustin is offline   Reply With Quote
Old 06-24-2014, 10:42 PM   #4832
jflogerzi
jflogerzi's Avatar
Any who @Dustin that curve is beautiful. I bet the car feels like a nice sized V6 NA rather then a SC engine.
BTW Is this on a mustang or dynojet?
The Following User Says Thank You to jflogerzi For This Useful Post:
Dustin (06-25-2014)
Old 06-24-2014, 10:54 PM   #4833
Subzero
Old...
Subzero's Avatar
Drives: Subaru
You could cheat and run your tires at max psi .
Subzero is offline   Reply With Quote
The Following User Says Thank You to Subzero For This Useful Post:
Dustin (06-24-2014)
Old 06-24-2014, 10:58 PM   #4834
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I'm contemplating phenolic spacers. I noticed the intake runners were HOT the other day and I wonder if there might be some power there if the heat soak could be reduced.
Hmm, I wonder if it would be possible to get a custom one made for the blower/manifold interface. That would be about 6mm more height though; including the spacers at the heads. Not sure there's clearance for that...
The Following User Says Thank You to Draco-REX For This Useful Post:
sato (06-25-2014)
Old 06-24-2014, 11:15 PM   #4835
Dustin
Twin Screw You
Dustin's Avatar
Dynojet
The Following User Says Thank You to Dustin For This Useful Post:
jflogerzi (06-24-2014)
Old 06-25-2014, 10:22 AM   #4836
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Can anything be gained or lost by removing the factory snorkel tube?
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 06-25-2014, 02:13 PM   #4837
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Well that shows the tune is reliable and consistent even in pretty hot conditions. Definitely a great test but if you want to hit the 300 mark I bet this will be the winning package.
Dyno Scenario
DynoJet with STD Correction as you have done
Cool dry day in the 60's-low 70's running 5th gear (1-1 ratio)
Vehicle Setup
Innovate Supercharger with Intercooler
Delicious Tuning 69mm Pulley (little more power overall)
Airaid Intake (little better flow on top end)
Remove the snorkel or make the hole opening larger (better air flow)
With all this in place I would expect 300+ whp, as each as a little power here and there and all of it together will net you the magic number and still on stock headers potentially.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Dustin (06-25-2014)
Old 06-25-2014, 03:20 PM   #4838
xxscaxx
Drives: 2013 SWP BRZ
@DeliciousTuning - Bill - is the 69mm pulley worth the upgrade from the 70?
Also, any word on the new map updates that you had mentioned a few days ago?
xxscaxx is offline   Reply With Quote
Old 06-25-2014, 03:39 PM   #4839
Dustin
Twin Screw You
Dustin's Avatar
Bill told me that the 69mm pulley should net about 5 more hp over the 70mm. I believe @CK_Bladesmith has it already and he said it's great.
xxscaxx (06-25-2014)
Old 06-25-2014, 03:42 PM   #4840
xxscaxx
Thanks. I just read back a page and didn't realize Bill said 5-7hp more.
Still would like to know about the new update though.
I'm also having an issue with startup, and the car dying out, but I've spoke with Bill about this (sent me maps to try out). Been so busy lately I haven't had a chance to do it though
Old 06-25-2014, 04:06 PM   #4841
Dustin
Twin Screw You
Dustin's Avatar
I just reread what I typed and it was a bit confusing. I meant CK_Bladesmith has the new update. Sorry I didn't clarify.
CK_Bladesmith (06-25-2014)
Old 06-25-2014, 04:07 PM   #4842
xxscaxx
No problem. Hopefully it gets pushed out, and then I can purchase the 69mm pulley.
Old 06-25-2014, 04:35 PM   #4843
xjohnx
Grip>Slip
xjohnx's Avatar
I flashed 8.59 at lunch today. Feels much smoother so far, but then again I've only driven a few miles since reflashing.
The Following 2 Users Say Thank You to xjohnx For This Useful Post:
Dustin (06-25-2014), whataboutbob (06-25-2014)
Old 06-25-2014, 04:55 PM   #4844
Dustin
Twin Screw You
Dustin's Avatar
I went to replace my Nameless intake tube with the plastic Innovate one yesterday so I could do some data logging and the hose came off where it connects in the middle to the factory line. Granted it was getting dark but I could not find the factory hose to connect it to. Could anyone either show a picture of the general area where I should look or verbally tell me? Thanks.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
