Old 04-24-2014, 05:31 PM   #4523
TM
TM's Avatar
Drives: DGM BRZ 6MT
Originally Posted by Boxer486 View Post
Like how heavy?
38lbs for both the single dump pack and start battery. Not too heavy. Just didn't expect the weight when I picked up the little box from FedEx.
TM is offline   Reply With Quote
Old 04-24-2014, 05:47 PM   #4524
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by Robftss View Post
PM's sent to individuals regarding May TQ250 kits(w/1.5 upgrade option) and standalone 1.5 dump pack additions.
Due to the demand of the 1.5 dump pack upgrade my initial target of May 5th to 9th my get pushed by a week.
Thanks all
Hey rob if there is anyone that wants to do the mod that I did to make the build easier for the 1.5 kits I can help them if they come down to San Diego.
Installed Mods:
Old 04-24-2014, 05:52 PM   #4525
Robftss
Drives: VW
Yes i got 37 when i weighed mine. The stock starter was 29.x lbs by itself.
Rob
Robftss is offline   Reply With Quote
Old 04-24-2014, 06:39 PM   #4526
Jac
Drives: Fiat Abarth
Will do a more in-depth write up but here's my dyno from today:
AFR between 2-3.5K was way too lean, hitting 15-18.
Jac is offline   Reply With Quote
The Following 3 Users Say Thank You to Jac For This Useful Post:
Boofneenee (04-24-2014), DAEMANO (04-24-2014), WRB5titch (04-24-2014)
Old 04-24-2014, 06:47 PM   #4527
jflogerzi
jflogerzi's Avatar
Is that with Shiv's tune for standard Stg 2 or the tune for ESC?
Old 04-24-2014, 06:51 PM   #4528
Jac
Drives: Fiat Abarth
Shiv's Phantom SC tune.
I was hitting about 4.5 psi peak.
Old 04-24-2014, 07:05 PM   #4529
fenton
Good results. For sure over 200whp with STD correction.
IMO 15 or so is okay down that low because it only last for a second and the load isnt that high.
Were you getting that reading off the tailpipe ? They read notoriously lean more often than not.
If you aren't getting any knock correction and your IAM is good I would say all is well.
If you have seen the stock tune it runs about 16 down low and 14 most of the way to redline.
@shiv@vishnu what's your expert opinion on this?
Thanks
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
Old 04-24-2014, 07:07 PM   #4530
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Careful with interpreting AFR data from Dynojet's tailpipe mounted o2 sensors. They will usually lean spike at low airflow rates due to fresh air contamination as they are usually not placed far enough upstream in the tailpipe. In this case, it's better to read AFR off the OFT since it measures that from the stock wideband located in the header. Also do you know what gear it was run in?
Also, 199 SAE correction is probably going to be around 205-206whp STD corrected depending on your conditions. So that's right around where it should be I think.
Cheers
shiv
Old 04-24-2014, 07:10 PM   #4531
Shiv@Openflash
Drives: 2013 FRS
Thanks
Ha.. you beat me to it
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
fenton (04-25-2014)
Old 04-24-2014, 07:11 PM   #4532
Jac
Drives: Fiat Abarth
Cheers
shiv
Thanks Shiv! I'll do some logs and send them over. I think i need one of your e-tune's anyway now since I've added a front pipe and intake.
4th gear pulls.
Old 04-24-2014, 07:19 PM   #4533
jflogerzi
jflogerzi's Avatar
@Jac do you have an aftermarket header?
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
Old 04-24-2014, 07:32 PM   #4534
fenton
Just doing my part to help out
Old 04-24-2014, 10:46 PM   #4535
Jac
Drives: Fiat Abarth
Negative.
Old 04-24-2014, 11:10 PM   #4536
jflogerzi
jflogerzi's Avatar
Negative.
Waiting for write up
The Following User Says Thank You to jflogerzi For This Useful Post:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
