Old 02-23-2015, 01:10 PM   #435
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
Correct me if I'm wrong but doesn't the water in the block circulate, and there for through the OEM style oil cooler, because of the water pump whether the radiator thermostat is open or not?
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Old 02-23-2015, 01:18 PM   #436
Guillaume
Guillaume's Avatar
Drives: Exige S 240
That's my understanding too. And from personal experience, the oil does warm up quicker with the Forester-style cooler (compared to stock).
Old 02-23-2015, 02:12 PM   #437
sstfnv
sstfnv's Avatar
This is correct. If you use the plug on the block to get the coolant and return it somewhere in the heater circuit it will circulate regardless of the thermostat. But if you are getting and returning the coolant from/to the radiator hoses.... it will work only when the thermostat is open.
sstfnv is offline   Reply With Quote
Old 02-23-2015, 03:11 PM   #438
FLYFISHR
FLYFISHR's Avatar
But wouldn't it still work as a radiator bypass then? Sorry if I'm asking dumb questions.
Old 02-23-2015, 03:58 PM   #439
Koa
no.. the cooler is tapped into the radiator hoses. Therefore the argument is, when the t-stat is not open, the oil cooler isn't receiving any coolant.
no bypass here?
Old 02-23-2015, 04:01 PM   #440
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Trust me you're not the only one.. Wouldn't what work as a radiator bypass the oem oil cooler? If using the Cusco which simply taps to the coolant hoses then it'll only allow for oil cooling when the car's thermostat has opened but then this wouldn't allow for the oil to get hotter quicker during warm up as its just getting the colder water from the radiator. So then the Cusco uses the coolant to cool the oil but not to warm it up unlike the OEM one which gets the coolant from the block so it'll warm up quicker and then keep it cool once the thermostat opens. All this crap im writing is a question im asking trying to answer it self. Feel free to correct lol. Thanks
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 02-23-2015, 05:35 PM   #441
nunonuna
nunonuna's Avatar
It may not be as good as OEM set up for warming up oil faster, but my personal experience shows that it still warms up oil faster than stock. My home to work is about 4 miles drive. When I had no cooler, the oil temp was about 155-160° when I arrive work, but after I installed by replicating Cusco type, oil temp always is about 175° when I arrive at work.
nunonuna is offline   Reply With Quote
Old 02-23-2015, 06:48 PM   #442
yomny
yomny's Avatar
That's works for me, honestly down here in Miami I don't have any issues warming up the oil, cooling it is the deal.
Old 02-23-2015, 10:10 PM   #443
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Doesn't matter where you live, its not 200 degrees anywhere on the planet so the ambient temp of your oil is too cold when the motor first starts...
Faster warming ALWAYS helps.
Kostamojen is offline   Reply With Quote
Old 02-24-2015, 08:22 AM   #444
yomny
yomny's Avatar
It will always be too cold whether you have the oil cooler/regulator or not smart guy, the fact that it warms it up quicker doesn't take away that oil is always too cold for startup. What I was trying to say before you stated the obvious in a rude way is that Im not as concerned with oil start up temps as people living up north.
Old 02-24-2015, 12:59 PM   #445
Ultramaroon
not playing cards
Ultramaroon's Avatar
I didn't see it as rude at all. It was simply a direct statement that it is always better to bring the oil/engine up to normal operating temp as quickly as possible to minimize wear.
And absolutely correct, btw.
Relax.
Old 02-24-2015, 01:07 PM   #446
yomny
yomny's Avatar
Relax.
Are you a lawyer, were you hired..? I was confused there for a second then realized you weren't involved.
And I understand the fact that oil temps need to climb as fast as possible, still doesn't call for "no where on this planet its 200 degrees" which is far more obvious than what temp oil needs to be when starting up and btw mind your own damn business before you go telling others to relax.
Oh and in any case Mr. District attorney, saying that it isn't 200 degrees anywhere on this planet to reference is never warm enough for startup oil temps is FAR from being a direct statement.
Old 02-24-2015, 01:15 PM   #447
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
wtf just happened...
tigermack is offline   Reply With Quote
Old 02-24-2015, 01:17 PM   #448
yomny
yomny's Avatar
lol started on post 443. Just don't get it why some people have to make a thing out of nothing. Aside from all that, im here for the info so I'll refrain from making comments not related to the OP.
brz, fxt, oil, oil cooler
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 05:28 AM
Bought a 2014 Subaru Forester EAGLE5 Other Vehicles & General Automotive Discussions 10 10-02-2013 12:54 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
BRZ 2.0L Turbo in 2014 Forester Sleeperz BRZ First-Gen (2012+) — General Topics 37 03-21-2013 06:42 PM
Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… 2013GTRNate BRZ First-Gen (2012+) — General Topics 12 02-01-2013 12:29 PM
