go_a_way1
Old 01-30-2020, 03:08 PM   #4201
Vital
Drives: 2015 BRZ
And i would add Firehawk Indy 500 to the mix too. I have those right now and they are a great tire for the price especially if you're just using them for DD.
Vital is offline   Reply With Quote
The Following User Says Thank You to Vital For This Useful Post:
Leonardo (01-30-2020)
Old 02-14-2020, 10:15 PM   #4202
hpanju
hpanju's Avatar
Drives: 2016 Subaru BRZ
Does 18x8.5 +45 fit on stock suspension? Wheel it fit says I have 1mm of suspension clearance and I feel like that might not be enough lol
hpanju is offline   Reply With Quote
Old 02-17-2020, 11:31 AM   #4203
Vital
Drives: 2015 BRZ
It will fit fine on stock suspension
Leonardo (02-17-2020)
Old 02-18-2020, 11:39 AM   #4204
HaXx
Drives: jrsc_brz
Is a 275/35 on a 18x11 par for the course? looking for rubber for a new set coming in.
HaXx is offline   Reply With Quote
The Following User Says Thank You to HaXx For This Useful Post:
Leonardo (02-18-2020)
Old 02-18-2020, 12:29 PM   #4205
Leonardo
Country Boy 4 Life
Leonardo's Avatar
285/30 is the OEM diameter. 275/35 will work too.
here is a 275 rear tire... (post #2465)
http://www.ft86club.com/forums/showt...41083&page=177
18x10.5 +47 will fit stock rear fenders (post# 18370) He ends up adding a 3mm spacer to the 18x10.5 +50
https://www.ft86club.com/forums/show...1036&page=1313
18x11, IMO, will need wide body or lots of camber. This is a 17x11 rear, so comparable.
http://www.ft86club.com/forums/showthread.php?p=3153084
I LIKE TIRES!
Vital (02-19-2020)
Old 02-18-2020, 01:17 PM   #4206
HaXx
Drives: jrsc_brz
ok, thx, yes its overfender setup. cant believe theres people on 18x10.5 stockbody honestly, thats mental aggressive. i suppose id like the 275/35 series because its a touch more than 10mm taller than the 285/30 series. that added sidewall should make an already rough ride an ounce nicer. plus theres more tires to choose from in 275/35/18. thanks for the help, i remember you helped me before too. hoping to keep -2* all around
Old 02-18-2020, 01:31 PM   #4207
HaXx
Drives: jrsc_brz
im on 18x8+45 and it was fine on eo susp. Your wheel is a touch taller and you will have a shorter tire, but not any closer to the suspension, so i think ull be good. i use wheel-it-fit a ton, but real world is always different than it is on paper.
Old 02-18-2020, 01:43 PM   #4208
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Nope. A 18x8.5 +45 is 6.3mm closer to the spring perch than a 18x8 +45. Offset is measured from the middle of the wheel.
I LIKE TIRES!
HaXx (02-18-2020)
Old 02-18-2020, 02:32 PM   #4209
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I am always happy to talk wheels and tires.
I LIKE TIRES!
Vital (02-19-2020)
Old 02-18-2020, 02:44 PM   #4210
HaXx
Drives: jrsc_brz
me too. in that case, what do you think about my proposed plan to be rallybacker v2 (+50mm front/+75mm rear) on 18x11-6 5x100 with 275/35? 50mm wheel spacers rear. coils,-2*, gentleman's ride height.
Old 02-18-2020, 03:20 PM   #4211
Leonardo
Country Boy 4 Life
Leonardo's Avatar
If my calculations are correct, you only need a 20 mm spacer in the rear.
Most guys run a 18x9.5 or 18x10 in the front. Because of the geometry of the center of the wheel compared to the width. Anyway, I think it will steer really weird if you do an 11" wheel in the front with a -6 offset. I don't have experience with this though... Just the math. So, maybe a 18x9.5 -25 wheel.
This guy suggests 18x9.5 -15 front and 18x11 -20 rear with -3 camber front and rear. I added 10mm to his calculations for fenders that are 10mm less. (makes sense to me!)
http://www.ft86club.com/forums/showthread.php?t=102357
My aggressive calculations are only about 10mm more of poke from what he suggests. I think that if you want less aggressive camber, you should go with less poke.
I LIKE TIRES!
HaXx (02-18-2020)
Old 02-18-2020, 04:42 PM   #4212
HaXx
Drives: jrsc_brz
I dont know why I didn't think of it like that. If the rear is exactly 25mm wider, then I will need a 25mm spacer to have the exact fitment as the fronts. Why am i so weirded out by staggered setups, should i be?
Old 02-18-2020, 10:00 PM   #4213
equachie
Drives: Subaru Brz - WRB
Does 18x9.5 +35 with 255/35/18 fit on stock suspension? or would it be safer to go with 245/35/18 or 245/40/18.
equachie is offline   Reply With Quote
Old 02-19-2020, 10:40 AM   #4214
Vital
Drives: 2015 BRZ
Yes it will fit stock suspension and it will poke a bit in the front the rears shouldn't be an issue. It will be close fit up front the tire sizes that will work are 245/35 or 235/40. I suggest getting coilovers otherwise it will look like a 4x4. Also, you can definitely add a 3mm spacer up front if its too close to the stock spring perches.
Leonardo (02-19-2020)
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
