Old 03-21-2014, 07:14 AM   #407
Victor Draken
Drives: Toyota Gt86
Originally Posted by Kodename47 View Post
I add 0.5-0.7 deg to the advance table above 2600 and load over 1/1.1. I use the advance map as it makes it easier to keep track of. Do it in steps; add a bit, test, repeat if applicable.
The reason I would only touch those areas as that is where you are WOT. Then if you see any FBKC/FLKC, back those cells off by 0.35 deg.
Do you mind telling me the exactly name of the tables, I srsly never edited one in my whole life.
So you are suggesting to just make the change that affect WOT and not partial throttle, why this kind of choice??
btw: i can't open the rom in romraider checksum 2 fail edit table has been disabled : /
Victor Draken is offline   Reply With Quote
Old 03-21-2014, 08:49 AM   #408
steve99
Originally Posted by AL008 View Post
I'm running 98 Octane.
fix is here
http://www.ft86club.com/forums/showp...&postcount=387
AL008 (03-21-2014)
Old 03-21-2014, 09:01 AM   #409
Victor Draken
Drives: Toyota Gt86
Is aussie fuel fake 98octane? Is it calculated like in Europe so it's 98ron?
It's quite strange that you guys are having knock with 98ron. I'm using a 100ron fuel ( probably 98) and my IAM is steady at 1.
Old 03-21-2014, 09:03 AM   #410
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Could be temperature or elevation differences.... Pretty sure it's warmer down under than Italy.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 03-21-2014, 09:09 AM   #411
steve99
Appears to be differences in fuel formulation 98RON is supposed to be equivalent to 93 AKI USA but it appears its not quite as good hence were having to pull some timing or run 100 RON which is not readily available to most. even on 100RON I was getting IAM drop on occasions.
Old 03-21-2014, 09:12 AM   #412
steve99
On 100RON in OZ it was pretty good IAM=1 most of the time, but you could get it to drop if you punch the throttle in the 2000-3500 RPM range under load a few times in a short period. on 98 RON it did it much more often.
Old 03-21-2014, 09:26 AM   #413
Victor Draken
Drives: Toyota Gt86
I'll try to do few wot pulls from 2000 to 3500
Only in 4th and 5th gear to increase load. Will see.
Steve do you know the advance timing table full name. I want to increase timings a bit and see if I can run a little more aggressive tune.
I went to advance timing category but don't understand what table in the folder should I touch.
Old 03-21-2014, 09:37 AM   #414
steve99
"Base Timing B" I believe or "Advance max A"
Old 03-21-2014, 09:47 AM   #415
Kodename47
Kodename47's Avatar
Drives: UK GT86
@Victor Draken the advance table is Knock Correction Advance Max A in RR.
As for partial throttle areas, I suppose this comes down to a couple of things. Do you feel you want more go for when you're just cruising? Cruise areas also appear to be the more knock prone with tip in knock. Seeing as Shiv has spent time developing the maps I don't see the need to push them in the areas when you're not going for it. If you look at the logs and see when you hit loads of 1 and above, you'll realise that for any decent throttle angle you're pushing through them anyway so load<1 is usually just cruising and the start of the pedal going down.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-21-2014, 10:15 AM   #416
Kodename47
Kodename47's Avatar
Drives: UK GT86
I've just noticed that Shiv's advance table isn't flat. You can help yourself by making a flat table and then you can easily see what changes you've made.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-21-2014, 10:52 AM   #417
s2d4
s2d4's Avatar
Look at your log, you are not immune to fbkc.
Old 03-21-2014, 01:11 PM   #418
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
What point(s) in the log are you referring to exactly.
Old 03-21-2014, 01:57 PM   #419
steve99
he has some minor fbck in the 2000-3200 range about what I had on 100 ron
Old 03-21-2014, 02:04 PM   #420
steve99
@shiv@vishnu
here is a log using Tactrix with a few more parameters.
http://datazap.me/u/steve99/98-knock-map-3-runs
I'm a bit concerned re the flck (as opposed to fbck) that I'm logging at 5000-7000 rpm. Also do you know the significance of flck_offset ??
I'm back on 98 RON again. This is the map with 0.35 pulled from areas in the 2000-3200 rpm range.
bit worried about the higher rpm flck though
AFR seems slightly rich (stock intake and exhaust)
Are the trims out far enough to warant maf scale ??
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
FS: Openflash Tablet Sgt.Beardface Engine, Exhaust, Bolt-Ons 8 01-04-2014 11:12 AM
FS: Openflash tablet nguyen_er Engine, Exhaust, Bolt-Ons 6 12-30-2013 12:31 PM
new OpenFlash tablet autobrz Engine, Exhaust, Bolt-Ons 5 12-23-2013 09:05 AM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
