#407 | |
Drives: Toyota Gt86
So you are suggesting to just make the change that affect WOT and not partial throttle, why this kind of choice?? btw: i can't open the rom in romraider checksum 2 fail edit table has been disabled : / Last edited by Victor Draken; 03-21-2014 at 07:28 AM. |
#408 |
Drives: FT86
| The Following User Says Thank You to steve99 For This Useful Post: | AL008 (03-21-2014) |
#409 | |
Drives: Toyota Gt86
It's quite strange that you guys are having knock with 98ron. I'm using a 100ron fuel ( probably 98) and my IAM is steady at 1. |
#410 |
Drives: Pavement MT GR86
Could be temperature or elevation differences.... Pretty sure it's warmer down under than Italy.
GR86 MT premium
#411 |
Drives: FT86
Appears to be differences in fuel formulation 98RON is supposed to be equivalent to 93 AKI USA but it appears its not quite as good hence were having to pull some timing or run 100 RON which is not readily available to most. even on 100RON I was getting IAM drop on occasions.
#412 |
Drives: FT86
On 100RON in OZ it was pretty good IAM=1 most of the time, but you could get it to drop if you punch the throttle in the 2000-3500 RPM range under load a few times in a short period. on 98 RON it did it much more often.
#413 | |
Drives: Toyota Gt86
Only in 4th and 5th gear to increase load. Will see. Steve do you know the advance timing table full name. I want to increase timings a bit and see if I can run a little more aggressive tune. I went to advance timing category but don't understand what table in the folder should I touch. |
#414 | |
Drives: FT86
#415 |
Drives: UK GT86
@Victor Draken the advance table is Knock Correction Advance Max A in RR.
As for partial throttle areas, I suppose this comes down to a couple of things. Do you feel you want more go for when you're just cruising? Cruise areas also appear to be the more knock prone with tip in knock. Seeing as Shiv has spent time developing the maps I don't see the need to push them in the areas when you're not going for it. If you look at the logs and see when you hit loads of 1 and above, you'll realise that for any decent throttle angle you're pushing through them anyway so load<1 is usually just cruising and the start of the pedal going down.
.: Stealth 86 :.
#416 |
Drives: UK GT86
I've just noticed that Shiv's advance table isn't flat. You can help yourself by making a flat table and then you can easily see what changes you've made.
.: Stealth 86 :.
#417 |
Look at your log, you are not immune to fbkc.
#418 |
Drives: 2013 FRS
#419 |
Drives: FT86
#420 |
Drives: FT86
@shiv@vishnu
here is a log using Tactrix with a few more parameters. http://datazap.me/u/steve99/98-knock-map-3-runs I'm a bit concerned re the flck (as opposed to fbck) that I'm logging at 5000-7000 rpm. Also do you know the significance of flck_offset ?? I'm back on 98 RON again. This is the map with 0.35 pulled from areas in the 2000-3200 rpm range. bit worried about the higher rpm flck though AFR seems slightly rich (stock intake and exhaust) Are the trims out far enough to warant maf scale ?? |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
| FS: Openflash Tablet | Sgt.Beardface | Engine, Exhaust, Bolt-Ons | 8 | 01-04-2014 11:12 AM |
| FS: Openflash tablet | nguyen_er | Engine, Exhaust, Bolt-Ons | 6 | 12-30-2013 12:31 PM |
| new OpenFlash tablet | autobrz | Engine, Exhaust, Bolt-Ons | 5 | 12-23-2013 09:05 AM |
| WTB Openflash Tablet | Vlady | Want-To-Buy Requests | 0 | 10-25-2013 12:10 AM |
